    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
      @cadfather said:
      when i choose the select tools from the menu, I only get the rectangle selection.
      Menu or toolbar? Exactly what item do you select? Can you do a screenshot for me?
      • CadFatherC
        CadFather
        Menu. same thing if i assign a shortcut to them (polygon, freehand, etc)
          Ah! I see the same thing. That's a bug - thank you for reporting!
          • cmeedC
            cmeed
            this has probably been asked before - can I move the gizmo and have it snap to a point? in 10 years of questions I think this has been asked.... 'negative' will be the answer.
            maybe i need to ask why cant it?
            cheers
            c
              Not so.
              Right click on the gizmo, choose the option and hold Shift while clicking to place it.
              Click on the picture
                Because it's not been entirely clear what to snap to. The user grabs hold of the gizmo which is offset from the gizmo origin, so is snapping supposed to snap the origin to the point snapped? Or the point grabbed?
                There's been some conversations about this - this thread for instance: http://sketchucation.com/forums/viewtopic.php?f=323&t=66039#p606094
                Snapping is described to relate relative to the gizmo origin, and with improved control of setting the origin.
                If you have your own idea of how snapping should work with the Gizmo I'm happy to hear it. I'm not sure everyone has the same expectations on how this would work.
                Because of that the separate Move/Rotate/Scale tools has been the main means of precision adjustments. While the gizmo is more eyeballing it.
                I'd be curious to hear why you prefer the Gizmo to snap as oppose to using the separate Move/Rotate/Scale tools. (Maybe there's some improvements with them that you achieve the same thing?)
                  Oh wait, did I read that correctly?
                  Did you talk about snapping while positioning the Gizmo? Or snapping while using the Gizmo Move?
                  • N
                    nlipovac
                    Is it possible to add option, i.e. hold CTRL, when using vertex slide to copy moved vertices and this way I can add loops without exiting Vertex tools?
                    And one more wild one, plus if I hold Shift I get that copy to be parallel to ones I have made copy off.
                      It's already on the list for consideration.
                      Would this be different than switching Vertex Slide to Slide by Offset instead of Slide by Percent?
                      https://evilsoftwareempire.com/vertex-tools/manual/editing#vertex_slide
                      • N
                        nlipovac
                        Great for this one, would be very handy.
                        As for this one, I mean that when I select one cut loop and use Vertex slide to make a copy it would maintain parallel to one I made copy off and not conform to loop or edge I am pushing it to.
                        Hope it makes sense.
                        Also of the topic, I never learned to make those short gifs, what do you use for that?
                          I don't fully manage to visualize what you are asking for. Could you illustrate it by mocking up the desired result compared to existing Offset modes?
                          I use ScreenPresso, though it's not free. Though there is a number of free ones out there. This one looks interesting: https://www.screentogif.com/
                          • N
                            nlipovac
                            Sure, here is two examples, one when I copy and move vertex from center loop and one when I copy and move from edge loop. If not mistaken, at moment we get only proprtional movement.
                            Parallel to the edge
                            Parallel to the middle
                            Proportional
                              If you switch you Slide By Offset I think you will get what you are looking for. (Except that it moves and doesn't copy the loop.)
                              • N
                                nlipovac
                                [attachment=0:rmfcreq0]<!-- ia0 -->2020-08-19_21h27_42.gif<!-- ia0 -->[/attachment:rmfcreq0]
                                This would be my mistake then, thank you for clarification. 👍
                                Just add my self shortcuts for those two.
                                I am still upvoting on adding an option to copy and move selected vertex.
                                Loving new tools! 👍
                                  Click this link for see the video! 🤓
                                  • E
                                    Einstein
                                    Hi! May I have a couple suggestions for VT2 development?
                                    • more SketchUp-native-like manner of manipulating gizmo's handles. What I mean is that you have to click+drag gizmo's arrow to move a vertex and only then type a precise value. I wish I could click, let mouse go, type value and hit ENTER. This would be more "sketchuppish" behaviour. Maybe there could be a button to choose behaviour.
                                      Also, current behaviour leads to unwanted situations like: when you precisely adjust radius of your soft selection, then drag a gizmo's handle/arrow to move verts, the selection gets updated before you type desired value of move. I wish I could lock/freeze soft selection so it wouldn't update after a transformation is performed - only when I decide to manually change my selection. This could be an adjustable behaviour too and it would help a lot with precise modelling.
                                    • bevel vertices with more segments (like Fredo Corner but Fredo Corner doesn't work with flat faces)
                                    • BUGFIX - when you bevel vertices of a flat face, sometimes the face gets removed (but I'm unable to reproduce the bug now)
                                    • also make possible to bevel verts without manually dragging them, just by typing value and hitting ENTER
                                    • move vertices with snapping (to other vertices, edges, edge midpoints, guides)
                                    • soft selection profile edit and profile presets, like in Blender: dome, pinch, random etc. I know they are on the to-do list, just can't wait for them! 😄
                                      Rafhinha
                                      Hello, how are you..
                                      I bought Vertex 1 and right after that Vertex 2 was launched. When I install Vertex 2 and put my key the following message appears
                                      "There was an unexpected server error while trying to active the license. Please try again in a few moments. If the problem persists, please contact support."
                                      I've tried it several times, already install Vertex 1.
                                      At some point Vertex 2 was released I downloaded, installed and it worked, but it appeared that it was trial trial version
                                      My sketchUp 2020
                                      windows 10
                                      I am downloading Vertex 2 from the email I received with the license and even so it says it is Trial experied
                                      • E
                                        Einstein
                                        If you only bought Vertex Tools 1 licence, it doesn't work with Vertex Tools 2. 2nd version is way more elaborate tool and I guess that's why the Author charges more for VT2.
                                        • E
                                          Einstein
                                          What was added in v2.0.3?
                                          • tuna1957T
                                            tuna1957
                                            Go back to page 20 of this thread. There’s a short video posted that goes over the cool new stuff. A lot has been added 👍
                                            Just a thought for the admins... maybe this thread could be split ? One for all the existing and new Vertex1 questions and a new thread for Vertex2 starting with Thomas’s Vertex2 announcement ?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 31 / 34
