    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      sheadacus
      Hello is there anyway to combine a slider and servo motor. Similar to the corkscrew but I need it to move apart automatically in twisting and sliding a certain distance and angle. Whenever I do a slider I cant move the servo and vice versa.
        Anton_S
        Hi! Yes, there is. To do this, you need two groups. One way to do this is by having slider as a top level joint and servo as an inner level joint:
        1. Create two box groups positioned next to each other.
        2. Create a slider joint at the top level, next to group A.
        3. Create a servo joint, one level inside group A.
        4. Using the joint connection tool, connect servo to group B.
        5. Then, connect slider to group A.
          In this scenario, group A will be constrained to the slider and group B will be constrained to a servo, with respect to group A.
          mauroa6
          Good morning
          I installed MSPhysic 1.0.3 and related AMS 3.6.0h libraries, but when opening SketchUp I get this error ...
          Errore di caricamento del file C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
          Error: #<IOError: The required, staged c extension file, "C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
          C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/SketchUp 2019/Tools/extensions.rb:197:in require'
          C:/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
          C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
          • T
            tayyab2224
            @mauroa6 said:
            Good morning
            MsP NOT WORKS IN 2017-2020.
            M. Tayyab
            • OxerO
              Oxer
              MSPhysic doesn't work in SketchUp > 2017 but in SU2017 works fine.
                skeeterkalamazoo
                Hello,
                I saw a way to use this to create a walkthrough exactly like I used to be able to do it in an old architect software I had. I can't get it this, or the AMS library to work, just gets a list of errors. I have SketchUp 2020 on a Windows 10 Machine, I'm guessing it is a compatibility issue with either of those. Any ideas? If it requires an update to the plugins, do you have any plans to do that?
                It will be a real bummer if I have to figure out a different way to do this. I have a lot of difficulty having animations turn out right just using the built in ability with scenes.
                Thanks,
                Skeeter
                  Anton_S
                  Hello, Skeeter. I mentioned this earlier, but MSPhysics is not compatible with 2019+. I am working on 2.0, from scratch. This is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                  • N
                    nisel
                    Is it possible to create an animation like that; Disappear or appear an object after 5 seconds?
                    • U
                      utsav1110
                      Can anyone help me with this simulation of multiple plastic bottles over a conveyor?
                      I need to know the flow of bottles over the conveyor. Whenever i run the simulation, it crashes.
                      Don't know the reason.
                      Also, if possible how can i model a simple flat belt that runs instead of this chain type belt. I have attached the file which i modelled in sketchup pro 2017.
                      segmented conveyor.skp
                      • C
                        cristyan
                        Hello ! utsav1110 here is an conveyor chain. You can use it if can help you.
                        conveyor_chain.skp
                          Jorgensen
                          @anton_s said:
                          .......is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                          Hi Anton
                          Is there some newsletter - or like, we can subscript to, to be informed when you release the next version? 😄
                          Jorgensen
                            Anton_S
                            @jorgensen said:
                            Hi Anton
                            Jorgensen
                            Hi Jorgensen,
                            There isn't any newsletters. Looks like I am falling behind on schedule with this one. Will do my best.
                            Thanks,
                            Anton
                              For your tests 😄
                              Put your links as you want...
                              Wanted 2 curves...
                              25.skp
                                As it's very easy to make this, ☀ it's a nightmare to make a simple grid with the same "Prismatic" module! 😮 (2 curvatures in the same time)
                                After tones of traying no success! I must miss something!
                                Have you some lights about that ?
                                scorpion_v6.skp
                                  Sorry bad hypothesis ! 😳
                                  That can't work with these prisms!
                                  There are overlapings!
                                  Works for 2 perpendicular "lines" but not for a checkerboard! 😛
                                  Here with a pyramid with 5° basis
                                    I found my error and won half of joints! 😉
                                    No so evident to find the good angles following sizes! 🤓
                                      azizxpx
                                      Hello Anton_S
                                      We thank you very much for this effort
                                      I was hoping the work would Export in mdl format
                                      Is there a way for that?
                                      Thanks ..
                                      • C
                                        cristyan
                                        Hello ! How can i connect these sliders ( or can be a piston joint )in a way that if I move one the other will move in the opposite direction or to affect its position (without connecting them directly). Thank you!
                                        connected slider.skp
                                          mkurmanalinova
                                          Hello, could you help me?
                                          1. I need a command, a function that allows to find out the position of the pusher at any time by using the keys, for example. At the moment the position of the pusher is bound to the sensor. The box crosses the sensor, the sensor issues a task for the movement of the puher. Also, when we touch the sensor, we display the coordinates of the pusher. The command “puts” didn’t help, it show the text, but we need the changing value.
                                          2. I need a command that is triggered by the condition: "sensor 2" = 1, "sensor 3" = 1, moreover, when the box leaves the sensor's range, "sensor 2" = 0. The pusher moves to a value of -70 when there are 2 boxes on the conveyor in the range of sensors 2 and 3.
                                            The problem is as follows: the pusher is triggered by the condition if laser2 && laser3> 0, fly = -70, written in the script of sensor 3.
                                            But when the box crosses the sensor 3, only one condition is triggered (laser3> 0), the boxes do not accumulate.
                                            Is there a function (onTouch, onUpdate, etc.) where you can write a condition via an if for two sensors?
                                          для моделирования11.skp
                                          • E
                                            eosmontana
                                            Does anyone know of a work around to install on a mac in SKU2019?
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
