    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
      skeeterkalamazoo
      Hello,
      I saw a way to use this to create a walkthrough exactly like I used to be able to do it in an old architect software I had. I can't get it this, or the AMS library to work, just gets a list of errors. I have SketchUp 2020 on a Windows 10 Machine, I'm guessing it is a compatibility issue with either of those. Any ideas? If it requires an update to the plugins, do you have any plans to do that?
      It will be a real bummer if I have to figure out a different way to do this. I have a lot of difficulty having animations turn out right just using the built in ability with scenes.
      Thanks,
      Skeeter
        Anton_S
        Hello, Skeeter. I mentioned this earlier, but MSPhysics is not compatible with 2019+. I am working on 2.0, from scratch. This is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
        • N Offline
          nisel
          Is it possible to create an animation like that; Disappear or appear an object after 5 seconds?
          • U Offline
            utsav1110
            Can anyone help me with this simulation of multiple plastic bottles over a conveyor?
            I need to know the flow of bottles over the conveyor. Whenever i run the simulation, it crashes.
            Don't know the reason.
            Also, if possible how can i model a simple flat belt that runs instead of this chain type belt. I have attached the file which i modelled in sketchup pro 2017.
            segmented conveyor.skp
              cristyan
              Hello ! utsav1110 here is an conveyor chain. You can use it if can help you.
              conveyor_chain.skp
                Jorgensen
                @anton_s said:
                .......is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                Hi Anton
                Is there some newsletter - or like, we can subscript to, to be informed when you release the next version? 😄
                Jorgensen
                  Anton_S
                  @jorgensen said:
                  Hi Anton
                  Jorgensen
                  Hi Jorgensen,
                  There isn't any newsletters. Looks like I am falling behind on schedule with this one. Will do my best.
                  Thanks,
                  Anton
                    For your tests 😄
                    Put your links as you want...
                    Wanted 2 curves...
                    25.skp
                      As it's very easy to make this, ☀ it's a nightmare to make a simple grid with the same "Prismatic" module! 😮 (2 curvatures in the same time)
                      After tones of traying no success! I must miss something!
                      Have you some lights about that ?
                      scorpion_v6.skp
                        Sorry bad hypothesis ! 😳
                        That can't work with these prisms!
                        There are overlapings!
                        Works for 2 perpendicular "lines" but not for a checkerboard! 😛
                        Here with a pyramid with 5° basis
                          I found my error and won half of joints! 😉
                          No so evident to find the good angles following sizes! 🤓
                            azizxpx
                            Hello Anton_S
                            We thank you very much for this effort
                            I was hoping the work would Export in mdl format
                            Is there a way for that?
                            Thanks ..
                              cristyan
                              Hello ! How can i connect these sliders ( or can be a piston joint )in a way that if I move one the other will move in the opposite direction or to affect its position (without connecting them directly). Thank you!
                              connected slider.skp
                                mkurmanalinova
                                Hello, could you help me?
                                1. I need a command, a function that allows to find out the position of the pusher at any time by using the keys, for example. At the moment the position of the pusher is bound to the sensor. The box crosses the sensor, the sensor issues a task for the movement of the puher. Also, when we touch the sensor, we display the coordinates of the pusher. The command “puts” didn’t help, it show the text, but we need the changing value.
                                2. I need a command that is triggered by the condition: "sensor 2" = 1, "sensor 3" = 1, moreover, when the box leaves the sensor's range, "sensor 2" = 0. The pusher moves to a value of -70 when there are 2 boxes on the conveyor in the range of sensors 2 and 3.
                                  The problem is as follows: the pusher is triggered by the condition if laser2 && laser3> 0, fly = -70, written in the script of sensor 3.
                                  But when the box crosses the sensor 3, only one condition is triggered (laser3> 0), the boxes do not accumulate.
                                  Is there a function (onTouch, onUpdate, etc.) where you can write a condition via an if for two sensors?
                                для моделирования11.skp
                                • E Offline
                                  eosmontana
                                  Does anyone know of a work around to install on a mac in SKU2019?
                                    As per earlier posts in this thread, the extension doesn't work in versions later than 2018 so there's no point installing it for SketchUp 2019. The author is working on a new version and it'll be released as soon as it is ready.
                                      ak-sam
                                      Hello are there any updates on when this could be compatible with SU2020 & 2021?
                                        See: http://sketchucation.com/forums/viewtopic.php?f=323&t=56852&start=840#p656107
                                          pinyol
                                          Hi Anton,
                                          Any news on when you'll be able to release an updated version of this wonderful Plugin?
                                          Best,
                                          Juan
                                            kaoru_komine
                                            Hello.
                                            I have a question for the participants of this forum.
                                            I would like to use the videos I made with "mspysics" and "sketchup make" for commercial purposes, what do you guys do in such cases?
                                            If I have a "sketchup" license, am I not in violation?
                                            Or do I have to buy "sketchup pro 2017" somehow?
                                            I posted a question here because the terms and conditions of sketchup.com don't make sense to me.
                                            Please let me know what you think.
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
