    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      daniabreu1
      Looking forward to see the new version of this plugin that it will work on new versions of SU. Keep updating us! Thank you! ๐Ÿ˜„
      • T
        tayyab2224
        What if flying simulation in msp2 ?
        M. Tayyab
          Anton_S
          You mean aerodynamics? I am planning to implement Newtonian drag (already developed in ClothWorks for simulating flags and parachute effects). Newtonian drag alone does not provide accurate results, as it does not involve turbulence and additional actors, but should yield useful results for simulating wings.
            sheadacus
            Hello is there anyway to combine a slider and servo motor. Similar to the corkscrew but I need it to move apart automatically in twisting and sliding a certain distance and angle. Whenever I do a slider I cant move the servo and vice versa.
              Anton_S
              Hi! Yes, there is. To do this, you need two groups. One way to do this is by having slider as a top level joint and servo as an inner level joint:
              1. Create two box groups positioned next to each other.
              2. Create a slider joint at the top level, next to group A.
              3. Create a servo joint, one level inside group A.
              4. Using the joint connection tool, connect servo to group B.
              5. Then, connect slider to group A.
                In this scenario, group A will be constrained to the slider and group B will be constrained to a servo, with respect to group A.
                mauroa6
                Good morning
                I installed MSPhysic 1.0.3 and related AMS 3.6.0h libraries, but when opening SketchUp I get this error ...
                Errore di caricamento del file C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                Error: #<IOError: The required, staged c extension file, "C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
                C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/SketchUp 2019/Tools/extensions.rb:197:in require'
                C:/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                • T
                  tayyab2224
                  @mauroa6 said:
                  Good morning
                  MsP NOT WORKS IN 2017-2020.
                  M. Tayyab
                  • OxerO
                    Oxer
                    MSPhysic doesn't work in SketchUp > 2017 but in SU2017 works fine.
                      skeeterkalamazoo
                      Hello,
                      I saw a way to use this to create a walkthrough exactly like I used to be able to do it in an old architect software I had. I can't get it this, or the AMS library to work, just gets a list of errors. I have SketchUp 2020 on a Windows 10 Machine, I'm guessing it is a compatibility issue with either of those. Any ideas? If it requires an update to the plugins, do you have any plans to do that?
                      It will be a real bummer if I have to figure out a different way to do this. I have a lot of difficulty having animations turn out right just using the built in ability with scenes.
                      Thanks,
                      Skeeter
                        Anton_S
                        Hello, Skeeter. I mentioned this earlier, but MSPhysics is not compatible with 2019+. I am working on 2.0, from scratch. This is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                        • N
                          nisel
                          Is it possible to create an animation like that; Disappear or appear an object after 5 seconds?
                          • U
                            utsav1110
                            Can anyone help me with this simulation of multiple plastic bottles over a conveyor?
                            I need to know the flow of bottles over the conveyor. Whenever i run the simulation, it crashes.
                            Don't know the reason.
                            Also, if possible how can i model a simple flat belt that runs instead of this chain type belt. I have attached the file which i modelled in sketchup pro 2017.
                            segmented conveyor.skp
                            • C
                              cristyan
                              Hello ! utsav1110 here is an conveyor chain. You can use it if can help you.
                              conveyor_chain.skp
                                Jorgensen
                                @anton_s said:
                                .......is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                                Hi Anton
                                Is there some newsletter - or like, we can subscript to, to be informed when you release the next version? ๐Ÿ˜„
                                Jorgensen
                                  Anton_S
                                  @jorgensen said:
                                  Hi Anton
                                  Jorgensen
                                  Hi Jorgensen,
                                  There isn't any newsletters. Looks like I am falling behind on schedule with this one. Will do my best.
                                  Thanks,
                                  Anton
                                    For your tests ๐Ÿ˜„
                                    Put your links as you want...
                                    Wanted 2 curves...
                                    25.skp
                                      As it's very easy to make this, โ˜€ it's a nightmare to make a simple grid with the same "Prismatic" module! ๐Ÿ˜ฎ (2 curvatures in the same time)
                                      After tones of traying no success! I must miss something!
                                      Have you some lights about that ?
                                      scorpion_v6.skp
                                        Sorry bad hypothesis ! ๐Ÿ˜ณ
                                        That can't work with these prisms!
                                        There are overlapings!
                                        Works for 2 perpendicular "lines" but not for a checkerboard! ๐Ÿ˜›
                                        Here with a pyramid with 5ยฐ basis
                                          I found my error and won half of joints! ๐Ÿ˜‰
                                          No so evident to find the good angles following sizes! ๐Ÿค“
                                            azizxpx
                                            Hello Anton_S
                                            We thank you very much for this effort
                                            I was hoping the work would Export in mdl format
                                            Is there a way for that?
                                            Thanks ..
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
