    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • C
      cristyan
      Hello ! utsav1110 here is an conveyor chain. You can use it if can help you.
      conveyor_chain.skp
        Jorgensen
        @anton_s said:
        .......is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
        Hi Anton
        Is there some newsletter - or like, we can subscript to, to be informed when you release the next version? ๐Ÿ˜„
        Jorgensen
          Anton_S
          @jorgensen said:
          Hi Anton
          Jorgensen
          Hi Jorgensen,
          There isn't any newsletters. Looks like I am falling behind on schedule with this one. Will do my best.
          Thanks,
          Anton
            For your tests ๐Ÿ˜„
            Put your links as you want...
            Wanted 2 curves...
            25.skp
              As it's very easy to make this, โ˜€ it's a nightmare to make a simple grid with the same "Prismatic" module! ๐Ÿ˜ฎ (2 curvatures in the same time)
              After tones of traying no success! I must miss something!
              Have you some lights about that ?
              scorpion_v6.skp
                Sorry bad hypothesis ! ๐Ÿ˜ณ
                That can't work with these prisms!
                There are overlapings!
                Works for 2 perpendicular "lines" but not for a checkerboard! ๐Ÿ˜›
                Here with a pyramid with 5ยฐ basis
                  I found my error and won half of joints! ๐Ÿ˜‰
                  No so evident to find the good angles following sizes! ๐Ÿค“
                    azizxpx
                    Hello Anton_S
                    We thank you very much for this effort
                    I was hoping the work would Export in mdl format
                    Is there a way for that?
                    Thanks ..
                    • C
                      cristyan
                      Hello ! How can i connect these sliders ( or can be a piston joint )in a way that if I move one the other will move in the opposite direction or to affect its position (without connecting them directly). Thank you!
                      connected slider.skp
                        mkurmanalinova
                        Hello, could you help me?
                        1. I need a command, a function that allows to find out the position of the pusher at any time by using the keys, for example. At the moment the position of the pusher is bound to the sensor. The box crosses the sensor, the sensor issues a task for the movement of the puher. Also, when we touch the sensor, we display the coordinates of the pusher. The command โ€œputsโ€ didnโ€™t help, it show the text, but we need the changing value.
                        2. I need a command that is triggered by the condition: "sensor 2" = 1, "sensor 3" = 1, moreover, when the box leaves the sensor's range, "sensor 2" = 0. The pusher moves to a value of -70 when there are 2 boxes on the conveyor in the range of sensors 2 and 3.
                          The problem is as follows: the pusher is triggered by the condition if laser2 && laser3> 0, fly = -70, written in the script of sensor 3.
                          But when the box crosses the sensor 3, only one condition is triggered (laser3> 0), the boxes do not accumulate.
                          Is there a function (onTouch, onUpdate, etc.) where you can write a condition via an if for two sensors?
                        ะดะปั ะผะพะดะตะปะธั€ะพะฒะฐะฝะธั11.skp
                        • E
                          eosmontana
                          Does anyone know of a work around to install on a mac in SKU2019?
                            As per earlier posts in this thread, the extension doesn't work in versions later than 2018 so there's no point installing it for SketchUp 2019. The author is working on a new version and it'll be released as soon as it is ready.
                              ak-sam
                              Hello are there any updates on when this could be compatible with SU2020 & 2021?
                                See: http://sketchucation.com/forums/viewtopic.php?f=323&t=56852&start=840#p656107
                                • P
                                  pinyol
                                  Hi Anton,
                                  Any news on when you'll be able to release an updated version of this wonderful Plugin?
                                  Best,
                                  Juan
                                  • K
                                    kaoru_komine
                                    Hello.
                                    I have a question for the participants of this forum.
                                    I would like to use the videos I made with "mspysics" and "sketchup make" for commercial purposes, what do you guys do in such cases?
                                    If I have a "sketchup" license, am I not in violation?
                                    Or do I have to buy "sketchup pro 2017" somehow?
                                    I posted a question here because the terms and conditions of sketchup.com don't make sense to me.
                                    Please let me know what you think.
                                      maddiebeck
                                      Hi Anton,
                                      I am also awaiting the release of an SKU2021 compatible version of MS Physics..Can we expect to see this soon?
                                        The terms of use for SketchUp 2017 Make are clear that it may not be used for commercial purposes. Having a license for an older version of SketchUp does not change the EULA for Make. If you need more clarification on that you should seek legitimate legal counsel.
                                        At this stage it's not likely that Trimble would sell you a license for SU2017 Pro. It's long out of support and they don't sell licenses for unsupported versions. The current version for which they are providing licenses is 2021.
                                        • F
                                          faust07
                                          Hello Anton,
                                          I hope you are fine and as a programming and physics genius you have a lot to do ... ๐Ÿ˜‰
                                          My questions:
                                          Is it feasible to make the existing (ingenious) MSPhysics compatible with SketchUp 2021 and what effort would that require?
                                          SketchUp and Ruby API have changed a few times in the meantime.
                                          Could outsiders with more or less programming knowledge help you? Possibly also financially.
                                          You're working on a new version. Can someone help you with testing?
                                          Otherwise, porting the last version v1.0.3 to SUp2021 would be very helpful, as you already have to keep 3 SketchUp versions:
                                          SUp2016 32bit for Sketchy Physics, SUp2017Make for MSPhysics and the current SUp version for daily work.
                                          I hope the users' interest in exercises and simulations on a physical basis for SketchUp does not wane.
                                          Since SketchUp is only available in paid versions anyway and since more and more professional plugins are chargeable, this would also be conceivable for MSPhysics.
                                          Well, moaned enough.
                                          Best regards, Andreas
                                            971jmd
                                            hello
                                            hi, i can't move the cart forward, do you have the skechup file to understand. thank you
                                            [url]]https://youtu.be/s2XaEboPQ7g?t=731[/url]
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
