    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • K
      kaoru_komine
      I am commenting for the first time.
      Thanks to the author for the great plugin.
      I'm looking forward to the new version of "MSPhysics".
      Now, I have a question about "MSPhysics2".
      I use Ruby scripts that can be input from the UI to control the 3D model in the current "MSPhysics".Is it possible to do the same thing with "MSPhysics2"?
        Anton_S
        Yes, scripting will still be available with MSPhysics2. The scripting API will be different, however.
          Anton_S
          @jumpjack said:
          Does it exist a library of mechanisms for MSP? I can find only a dozen models on warehouse.
          As mentioned earlier, MSPhysics 1 has weak joints, in which case creating mechanical interconnections between rods, suspension, robotic arms, and what not, makes the resulting structure weak and loose, unless all interconnected groups have an identical mass. MSPhysics 2 should be able to address this issue. I haven't yet tested that, and I am a little behind with my promises on the development of the project, but as mentioned earlier, I am very exited to utilize the newer NewtonDynamics version for this, which showed promising results with the stable and robust interlinked joint behavior.
          • T
            tayyab2224
            I hope we will enjoy MSP2 this summer۔۔۔
            M. Tayyab
              daniabreu1
              Looking forward to see the new version of this plugin that it will work on new versions of SU. Keep updating us! Thank you! 😄
              • T
                tayyab2224
                What if flying simulation in msp2 ?
                M. Tayyab
                  Anton_S
                  You mean aerodynamics? I am planning to implement Newtonian drag (already developed in ClothWorks for simulating flags and parachute effects). Newtonian drag alone does not provide accurate results, as it does not involve turbulence and additional actors, but should yield useful results for simulating wings.
                    sheadacus
                    Hello is there anyway to combine a slider and servo motor. Similar to the corkscrew but I need it to move apart automatically in twisting and sliding a certain distance and angle. Whenever I do a slider I cant move the servo and vice versa.
                      Anton_S
                      Hi! Yes, there is. To do this, you need two groups. One way to do this is by having slider as a top level joint and servo as an inner level joint:
                      1. Create two box groups positioned next to each other.
                      2. Create a slider joint at the top level, next to group A.
                      3. Create a servo joint, one level inside group A.
                      4. Using the joint connection tool, connect servo to group B.
                      5. Then, connect slider to group A.
                        In this scenario, group A will be constrained to the slider and group B will be constrained to a servo, with respect to group A.
                        mauroa6
                        Good morning
                        I installed MSPhysic 1.0.3 and related AMS 3.6.0h libraries, but when opening SketchUp I get this error ...
                        Errore di caricamento del file C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                        Error: #<IOError: The required, staged c extension file, "C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
                        C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
                        C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                        C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                        C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/SketchUp 2019/Tools/extensions.rb:197:in require'
                        C:/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                        C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                        • T
                          tayyab2224
                          @mauroa6 said:
                          Good morning
                          MsP NOT WORKS IN 2017-2020.
                          M. Tayyab
                          • OxerO
                            Oxer
                            MSPhysic doesn't work in SketchUp > 2017 but in SU2017 works fine.
                              skeeterkalamazoo
                              Hello,
                              I saw a way to use this to create a walkthrough exactly like I used to be able to do it in an old architect software I had. I can't get it this, or the AMS library to work, just gets a list of errors. I have SketchUp 2020 on a Windows 10 Machine, I'm guessing it is a compatibility issue with either of those. Any ideas? If it requires an update to the plugins, do you have any plans to do that?
                              It will be a real bummer if I have to figure out a different way to do this. I have a lot of difficulty having animations turn out right just using the built in ability with scenes.
                              Thanks,
                              Skeeter
                                Anton_S
                                Hello, Skeeter. I mentioned this earlier, but MSPhysics is not compatible with 2019+. I am working on 2.0, from scratch. This is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                                • N
                                  nisel
                                  Is it possible to create an animation like that; Disappear or appear an object after 5 seconds?
                                  • U
                                    utsav1110
                                    Can anyone help me with this simulation of multiple plastic bottles over a conveyor?
                                    I need to know the flow of bottles over the conveyor. Whenever i run the simulation, it crashes.
                                    Don't know the reason.
                                    Also, if possible how can i model a simple flat belt that runs instead of this chain type belt. I have attached the file which i modelled in sketchup pro 2017.
                                    segmented conveyor.skp
                                    • C
                                      cristyan
                                      Hello ! utsav1110 here is an conveyor chain. You can use it if can help you.
                                      conveyor_chain.skp
                                        Jorgensen
                                        @anton_s said:
                                        .......is one of the reasons it takes too long to release. I hope to have a working version in June or July. Thanks!
                                        Hi Anton
                                        Is there some newsletter - or like, we can subscript to, to be informed when you release the next version? 😄
                                        Jorgensen
                                          Anton_S
                                          @jorgensen said:
                                          Hi Anton
                                          Jorgensen
                                          Hi Jorgensen,
                                          There isn't any newsletters. Looks like I am falling behind on schedule with this one. Will do my best.
                                          Thanks,
                                          Anton
                                            For your tests 😄
                                            Put your links as you want...
                                            Wanted 2 curves...
                                            25.skp
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 43 / 47
