    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • C
      Chelle
      Thanks for replying.
      I've attached the model as well for you to look at.
      Ruby Console was showing the following, however I was having the same issue where it was rendering the first frame on repeat/no movement :
      RENDERING INIT
      Status natural = {}
      Status thea = ;not_supported
      Status ambient_occlusion = ;not_supported
      Status sketchFX = ;not_supported
      Status twilight = ;not_supported
      VRAY Init
      Status vray = nil
      ;beg_time => 0
      ;end_time => 6.0
      ;frame_rate => 15
      ;speed_factor => 1.0
      ;reversed_play => nil
      ;transparent => false
      ;dimX => 1440
      ;dimY => 864
      ;dim_mode => "r5_3"
      ;filter => {
      }  (;filter)
      ;root_dir => (Don't want to post this bit publicly)
      ;movie_dir => "Cedar Garden Room Doors - 12-Apr-2020 10-18-12"
      ;movie_name => "Door Move"
      ;date_modified => 1586615101.854707
      ;movie_formats => {
         ;mp4 => true
         ;mov => false
      }  (;movie_formats)
      ;rendering_method => ;vray
      MOVIE PX = 1440 PY = 864 transpa = false
      VRAY Movie frame 1 animation time = 0.00s
      AFTER launching Rendering and Timer; status = true
      VRAY Status check - status = 6
      VRay rendering not finished yet elapsed = 2.00s
      VRay rendering not finished yet elapsed = 4.00s
      VRay rendering not finished yet elapsed = 5.99s
      VRay rendering not finished yet elapsed = 8.46s
      VRAY Status check - status = 4
      VRAY Finished after 10.47s
      VRAY Movie frame 2 animation time = 0.07s
      VRay rendering not finished yet elapsed = 1.99s
      VRay rendering not finished yet elapsed = 3.99s
      VRay rendering not finished yet elapsed = 7.99s
      VRAY Finished after 9.99s
      VRAY Movie frame 3 animation time = 0.13s
      VRay rendering not finished yet elapsed = 2.01s
      VRay rendering not finished yet elapsed = 4.01s
      VRay rendering not finished yet elapsed = 6.01s
      VRay rendering not finished yet elapsed = 8.02s
      VRAY Finished after 10.01s
      VRAY Movie frame 4 animation time = 0.20s
      VRay rendering not finished yet elapsed = 4.02s
      VRay rendering not finished yet elapsed = 6.02s
      VRAY Finished after 10.02s
      VRAY Movie frame 5 animation time = 0.27s
      VRAY Movie frame 6 animation time = 0.33s
      VRay rendering not finished yet elapsed = 8.01s
      VRay rendering not finished yet elapsed = 10.02s
      VRAY Finished after 12.03s
      VRAY Movie frame 7 animation time = 0.40s
      VRAY Status check - status = 1
      VRAY Error or Time out
      VRAY Movie frame 8 animation time = 0.47s
      INTERRUPT true
      VRAY STOP timer = 31539
      VRAY STOP timer =
      I stopped the render at this point as this is when there is a gap in the door which is easily visible to see if it is working.
      Thanks.
      Model I'm Using
        Serge73
        @fredo6 said:
        Could you post or PM the model.
        Also, when you run the video generation, could you leave the Ruby Console open. There are traces showing the processing of frames. And there may be errors as well.
        The problem appears on any primitive model. For example, rectilinear movement of a cube.
        The problem with SketchUP 2020 and V-REY 4.20.01
        Render only the first frame. The clip consists of the same frames, the duration is not important.
        there is a problem on the forum
        ;beg_time => 0
        ;end_time => 2.0
        ;frame_rate => 25
        ;reversed_play => false
        ;dimX => 740
        ;dimY => 416
        ;dim_mode => "r16_9"
        ;filter => {
        }  (;filter)
        ;root_dir => "C;/TEMP/Animator Videos"
        ;movie_dir => "test - 14-Apr-2020 23-57-29"
        ;movie_name => "Film 1"
        ;date_modified => 1586890168.103433
        ;movie_formats => {
           ;mp4 => true
           ;mov => false
        }  (;movie_formats)
        MOVIE PX = 740 PY = 416 transpa = false
        VRAY Finished after 1.99s
        VRAY Movie frame 2 animation time = 0.04s
        VRAY Movie frame 3 animation time = 0.08s
        VRAY Finished after 2.00s
        ......cut out........
        VRAY Movie frame 49 animation time = 1.92s
        VRAY Movie frame 50 animation time = 1.96s
        VRAY Movie frame 51 animation time = 2.00s
        VRAY STOP timer =
        Command FFmpeg for mp4 = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -framerate 25 -i "U1586890672_Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
        ===> Status FFmpeg for mp4 = true
        Command FFmpeg for mov = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -i "Film 1.mp4" -acodec copy -vcodec copy -f mov "Film 1.mov" 2> FFmpeg_log_mov.txt
        ===> Status FFmpeg for mov = true
        • T
          TonyAU
          Before I get into my issue I would like to thank Fredo for the hard work in creating this plug-in, it's awesome!!
          Now I just need to check if anyone else is having issues with animating camera views, For some reason in this release the camera's seem to be glitching.. If I save a camera view in the animator, they start in the correct position then jump out to an unexpected view then finish on the correct location.. There's no fluidity to the movement, not sure if it's something I'm doing wrong though.. It definitely could be.. 😄
          Let me know your thoughts
          Cheers..
          • fredo6F
            @tonyAU
            It would help to have the model.
            Do you use only ONE camera or several?
            • T
              TonyAU
              Hi Fredo,
              File attached, I think it happens on all my files so don't know if it's my end or yours.. I can live without it, I just thought I would put it out there and give you the heads up.
              cheers for all your hard work..
              Animator Cam test.skp
              • fredo6F
                @TonyAU,
                Thanks for the model.
                It helped me to realize that there was a bug in the interpolation of cameras when they are in Parallel projection.
                I fixed it and it will go in LibFredo6 v10.1.
                • T
                  TonyAU
                  Your a legend..
                  Thank you Fredo
                    serland
                    Hi all,
                    Sorry but the problem persits, with LibFredo 10.1 and lastest Animator ver. when the VRay mode is selected it only renders the first frame in the final video.
                    I attach the skp file and the video.
                    Natural Animation
                    ;beg_time => 0
                    ;end_time => 1.0
                    ;frame_rate => 25
                    ;dimX => 1498
                    ;dimY => 856
                    ;dim_mode => "viewport"
                    ;filter => {
                    }  (;filter)
                    ;root_dir => "C;/Users/serland/Desktop/Animator Videos"
                    ;movie_dir => "Sin título - 29-Apr-2020 12-08-02"
                    ;date_modified => 1588154844.373782
                    ;movie_formats => {
                       ;mp4 => true
                       ;mov => false
                    }  (;movie_formats)
                    ;rendering_method => ;natural
                    MOVIE PX = 1498 PY = 856 transpa = false
                    NATURAL image 1 time = 0s Image01.png frame = 1 res = 1498x856
                    NATURAL image 2 time = 0.04s Image02.png frame = 2 res = 1498x856
                    NATURAL image 3 time = 0.08s Image03.png frame = 3 res = 1498x856
                    NATURAL image 4 time = 0.12s Image04.png frame = 4 res = 1498x856
                    ... cut ...
                    NATURAL image 24 time = 0.9200000000000003s Image24.png frame = 24 res = 1498x856
                    NATURAL image 25 time = 0.9600000000000003s Image25.png frame = 25 res = 1498x856
                    NATURAL image 26 time = 1.0s Image26.png frame = 26 res = 1498x856
                    Command FFmpeg for mp4 = "D;/FFMPEG/bin/ffmpeg.exe" -framerate 25 -i "Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                    Command FFmpeg for mov = "D;/FFMPEG/bin/ffmpeg.exe" -i "Film 1.mp4" -acodec copy -vcodec copy -f mov "Film 1.mov" 2> FFmpeg_log_mov.txt
                    VRay Animation
                    ;beg_time => 0
                    ;end_time => 1.0
                    ;frame_rate => 25
                    ;dimX => 1498
                    ;dimY => 856
                    ;filter => {
                    }  (;filter)
                    ;movie_dir => "Sin título - 29-Apr-2020 12-09-18"
                    ;movie_formats => {
                       ;mp4 => true
                       ;mov => false
                    }  (;movie_formats)
                    VRAY Finished after 6.00s
                    VRAY Finished after 5.99s
                    ... cut...
                    VRAY Movie frame 26 animation time = 1.00s
                    VRay rendering not finished yet elapsed = 6.00s
                    VRAY Finished after 8.00s
                    VRAY STOP timer =
                    Command FFmpeg for mp4 = "D;/FFMPEG/bin/ffmpeg.exe" -framerate 25 -i "U1588154971_Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                    Thanks for your job
                    Sin título.skp
                    Animator.mov
                      Atilla_Ahmediye
                      Hello Thank your for this amazing plug-in...it is really cool 👍
                      I guess it is needs to be patch to work with Vray Next (4.20.02).
                      • T
                        TDahl
                        Is there a way to control the thickness or weight of edges (lines) as they appear in the exported movie frames (MP4, etc.)? I am using SketchUp Pro 2018 with Animator v2.6c. I noticed that edges are rendered with thicker lines in Animator's frames than they are when I use SketchUp Pro 2018's native Export > Animation function.
                        In a video editor, I would like to seamlessly transition from a native animation exported clip to an Animator-exported clip, but there is a clear visual discontinuity between the line thicknesses of the two clips at the transition point. Attached is a still picture with a native animation-export on the left and an Animator-export on the right. The boundary is a bit subtle side-by-side, but it is a quite evident "pop" when viewing a video that abruptly jumps from the thinner to the thicker line weight.
                        Comparison of edge line thickness between native SketchUp and Animator exported frames
                        • fredo6F
                          Yes. I need to update Animator for that, because there is now an option about the line thickness.
                          That would be an extra parameter in the generation dialog.
                            Mill29
                            Thanks a lot Fredo for this wonderfull tool!
                            Just for information, it works well with Thea render V2
                            • L
                              lazara
                              Fredo my sincere congratulations on your wonderful animation tool for Sketchup. It is very useful to me in the reconstruction of 3D traffic accidents. Thank you very much for your development and constant updating. 👍
                              • T
                                TDahl
                                Animator v2.6c is telling me that it has expired, but there does not seem to be a newer version available yet. Any estimate on when a new version (or a re-release of v2.6c with an extended expiration date) might be available?
                                • T
                                  TimHforProMinent
                                  I am having trouble with Animator V2.6c. I get the below message,
                                  I run 2020 on a Windows Machine.
                                  This version of Animator has expired
                                  Please upgrade to the latest version
                                  and I have the latest version.
                                  Thanks, Tim
                                  • fredo6F
                                    New Release: Animator - v2.7a - 15 Jun 20
                                    Requirement: LibFredo6 v9.5k
                                    Minor release
                                    • Extension of validity
                                    See plugin home page of Animator for Download of RBZ from the PluginStore.
                                    See Main Post of the Animator thread for more information.
                                    • fredo6F
                                      @timhforprominent said:
                                      Ooops! My fault. Forgot to update it in due time. Thanks for signaling.
                                      • T
                                        TDahl
                                        Animator v2.7a downloaded, installed, and started up fine - thank you for the quick turn-around!
                                        • T
                                          TimHforProMinent
                                          Fredo,
                                          Thank you very much, downloaded and installed without problems.
                                          Thanks for such a great Plugin.
                                          I am still learning all the functions.
                                          Tim
                                            rong1937
                                            Hope to create scenes in sketchup
                                            thank you
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 29
                                            • 30
                                            • 17 / 30
