    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    595 Posts 119 Posters 1.9m Views 119 Watching
    • fredo6F Offline
      @aaronyee said:
      Hi, fredo. I want to realize how version of thea render can support v2.4b animator. Is the thea render v2.0 ok? Thank you for help me.
      I did not test with this version of Thea 2.0. I only have v1.5 on my laptop.
      So if you have it already, please make a test on a simple animation, opening the Ruby Console to check if there are error messages (normally you should only see traces of the execution).
      For Thea, make sure you use a Presto method, not interactive, with a reasonable sample/px, typically 10 to 20. This keeps the rendering under a reasonable amount of time.
      • fredo6F Offline
        New Release: Animator - v2.4c - 14 May 19
        Requirement: LibFredo6 v8.7f
        Minor release
        • Extension of validity
        See plugin home page of Animator for Download of RBZ from the PluginStore.
        See Main Post of the Animator thread for more information.
          meapiper
          Can I use this extension with Maxwell Render to create a rendered video? I believe I need to creates multiple scenes to bring into Maxwell.
          • fredo6F Offline
            I have no API to Maxwell, so it is not supported in Direct mode by Animator.
            And I doubt that Maxwell support the reverse mode (as Thea does), because they would have contacted me.
            So short answer is NO.
            • fredo6F Offline
              New Release: Animator - v2.4d - 14 Jun 19
              Minor release
              • Added a permanent FFMeg button to be able to change the location of the FFmpeg executable
              • fredo6F Offline
                New Release: Animator - v2.5a - 11 Sep 19
                Requirement: LibFredo6 v9.1b
                Minor release
                • fixed some bug around video generation
                • Y Offline
                  yonofun
                  Any advice concerning ffmpeg video download. I followed the link and the FFmpeg.org pdf directions but didn't find the exact steps available and got into a baited ads trap and downloaded similarly labeled ffmpeg files that were unrelated. I successfully created an edit in animator and would love to get it to mp4.
                  • fredo6F Offline
                    For Mac, here is the download page.
                    Then I suggest you pick the latest build of FFmpeg for Mac (dated 3 Jan 2020).
                    https://ffmpeg.zeranoe.com/builds/macos64/static/ffmpeg-20200102-81172b5-macos64-static.zip
                    Just extract the ffmpegexecutable in the ** bin**subfolder and put it in a known place where you will point to from Animator.
                    • fredo6F Offline
                      New Release: Animator - v2.6a - 12 Jan 20
                      Requirement: LibFredo6 v9.5
                      Minor release
                      • New instructions for FFmpeg installation
                        stopping
                        Hi there,
                        thank you for this incredible plugin! I've been using it for about half a year now creating animation films and it's truly one of the greatest SU plugins out there.
                        However, since yesterday afternoon I'm experiencing a few bugs.
                        1. Animations aren't previewed in the editor
                        2. I can't select a specific time in my timeline any more. On mouseover it hovers in turquoise, however, nothing happens upon clicking. When I temporarily exit to SU and return to Animator it has then selected the moment I wasn't able to select previously. However, it doesn't show the animations that should have happened up to this point.
                        3. When I proceed to "Generate a Video for the Film" it does not show a pop up window. It just hides all menus and displays a red frame around the editor.
                        All these issues occured from one moment to the other. It was fine yesterday morning but started behaving like this in the afternoon. I tried to reinstall both the animator as well as the lib but it didn't help. I then proceeded to try the plugins in SU17 - same issues here.
                        I'm using Win 10 Pro 64 Bit, SU19.2.222, Lib 9.5g, Animator 2.6a
                        Here are the lines from the Ruby Console upon opening the animator:
                        Error; #<ArgumentError; wrong number of arguments (given 2, expected 3)>
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6spline.rbe;46;in `evaluate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;291;in `bezier'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;260;in `call'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;260;in `double'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;246;in `block in standard_function_calculate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;254;in `standard_function_calculate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;214;in `standard_interpolate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;61;in `interpolate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;988;in `animal_apply_easing_oscillation'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;920;in `animal_calculate_ratio'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;852;in `block in animal_animate_contribution'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;845;in `each'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;845;in `animal_animate_contribution'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;638;in `animal_animate_processing'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;574;in `animal_animate_film'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1356;in `clip_animate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1534;in `notify_from_clip_animation'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;239;in `call'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;239;in `notify_event'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;447;in `perform'
                        And this is what I get when I try to select a specific time from the timeline:
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;58;in `interpolate'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;927;in `animal_calculate_ratio'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;317;in `rewind'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;466;in `goto_time'
                        This is the result from selecting "Generate a Video for the Film":
                        RENDERING INIT
                        Status natural = {}
                        Status thea = ;not_supported
                        Status ambient_occlusion = ;not_supported
                        Status sketchFX = ;not_supported
                        Status twilight = ;not_supported
                        VRAY Init
                        Status vray = ;not_supported
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1340;in `clip_animate_rewind'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;582;in `assign_clip'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;559;in `build_list_clips'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;363;in `dialog_invoke'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe;2206;in `movie_dialog'
                        c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe;2176;in `movie_clip_generation'
                        • fredo6F Offline
                          Thanks for signaling.
                          It should normally be fixed with LibFredo6 9.5h, just published.
                            stopping
                            Excellent, Thanks for the quick reply! That actually solved it!
                            • E Offline
                              Emersonvip
                              any chance to work with Enscape?
                              • fredo6F Offline
                                No for the time being. I would need to liaise with the Enscape developers to see if something can be done.
                                • E Offline
                                  Emersonvip
                                  That would be wonderful.
                                  • MechaHercM Offline
                                    MechaHerc
                                    Hi guys, i got problem with new version, am i missing something here?
                                    the exploded filter not working in vray rendered..
                                    Vray Rendered
                                    Sketchup Animation
                                      Chelle
                                      I love the animator and it works great for creating spinning camera angles of my building designs however I've found an issue when rendering animations involving movement and kinetics of doors.
                                      The animation works fine within Sketchup and in Animator. It also shows on the interactive render within Vray.
                                      However when it comes to creating the MP4, it is only rendering the first image of the closed doors on repeat and not creating an animation.
                                      This is the video which I am trying to render using Vray Next (working when just using Sketchup):
                                      This is an example of the videos I have been creating where it has worked fine and rendered in Vray:
                                      Please help as I am loving the software so far and would like the animated door videos to match the showcasing of the model.
                                      Versions I am using:
                                      Sketchup - Sketchup Pro 2020
                                      Vray - Vray Next 4.20.01 Feb 18 2020
                                      Fredo6 Animator - 2.6c - 19 Mar 20
                                      • fredo6F Offline
                                        Could you post or PM the model.
                                        Difficult to find out without.
                                        Also, when you run the video generation, could you leave the Ruby Console open. There are traces showing the processing of frames. And there may be errors as well.
                                          Chelle
                                          Thanks for replying.
                                          I've attached the model as well for you to look at.
                                          Ruby Console was showing the following, however I was having the same issue where it was rendering the first frame on repeat/no movement :
                                          RENDERING INIT
                                          Status natural = {}
                                          VRAY Init
                                          Status vray = nil
                                          ;beg_time => 0
                                          ;end_time => 6.0
                                          ;frame_rate => 15
                                          ;speed_factor => 1.0
                                          ;reversed_play => nil
                                          ;transparent => false
                                          ;dimX => 1440
                                          ;dimY => 864
                                          ;dim_mode => "r5_3"
                                          ;filter => {
                                          }  (;filter)
                                          ;root_dir => (Don't want to post this bit publicly)
                                          ;movie_dir => "Cedar Garden Room Doors - 12-Apr-2020 10-18-12"
                                          ;movie_name => "Door Move"
                                          ;date_modified => 1586615101.854707
                                          ;movie_formats => {
                                             ;mp4 => true
                                             ;mov => false
                                          }  (;movie_formats)
                                          ;rendering_method => ;vray
                                          MOVIE PX = 1440 PY = 864 transpa = false
                                          VRAY Movie frame 1 animation time = 0.00s
                                          AFTER launching Rendering and Timer; status = true
                                          VRAY Status check - status = 6
                                          VRay rendering not finished yet elapsed = 2.00s
                                          VRay rendering not finished yet elapsed = 4.00s
                                          VRay rendering not finished yet elapsed = 5.99s
                                          VRay rendering not finished yet elapsed = 8.46s
                                          VRAY Status check - status = 4
                                          VRAY Finished after 10.47s
                                          VRAY Movie frame 2 animation time = 0.07s
                                          VRay rendering not finished yet elapsed = 1.99s
                                          VRay rendering not finished yet elapsed = 3.99s
                                          VRay rendering not finished yet elapsed = 7.99s
                                          VRAY Finished after 9.99s
                                          VRAY Movie frame 3 animation time = 0.13s
                                          VRay rendering not finished yet elapsed = 2.01s
                                          VRay rendering not finished yet elapsed = 4.01s
                                          VRay rendering not finished yet elapsed = 6.01s
                                          VRay rendering not finished yet elapsed = 8.02s
                                          VRAY Finished after 10.01s
                                          VRAY Movie frame 4 animation time = 0.20s
                                          VRay rendering not finished yet elapsed = 4.02s
                                          VRay rendering not finished yet elapsed = 6.02s
                                          VRAY Finished after 10.02s
                                          VRAY Movie frame 5 animation time = 0.27s
                                          VRAY Movie frame 6 animation time = 0.33s
                                          VRay rendering not finished yet elapsed = 8.01s
                                          VRay rendering not finished yet elapsed = 10.02s
                                          VRAY Finished after 12.03s
                                          VRAY Movie frame 7 animation time = 0.40s
                                          VRAY Status check - status = 1
                                          VRAY Error or Time out
                                          VRAY Movie frame 8 animation time = 0.47s
                                          INTERRUPT true
                                          VRAY STOP timer = 31539
                                          VRAY STOP timer =
                                          I stopped the render at this point as this is when there is a gap in the door which is easily visible to see if it is working.
                                          Thanks.
                                          Model I'm Using
                                            Serge73
                                            The problem appears on any primitive model. For example, rectilinear movement of a cube.
                                            The problem with SketchUP 2020 and V-REY 4.20.01
                                            Render only the first frame. The clip consists of the same frames, the duration is not important.
                                            there is a problem on the forum
                                            ;beg_time => 0
                                            ;end_time => 2.0
                                            ;frame_rate => 25
                                            ;reversed_play => false
                                            ;dimX => 740
                                            ;dimY => 416
                                            ;dim_mode => "r16_9"
                                            ;filter => {
                                            }  (;filter)
                                            ;root_dir => "C;/TEMP/Animator Videos"
                                            ;movie_dir => "test - 14-Apr-2020 23-57-29"
                                            ;movie_name => "Film 1"
                                            ;date_modified => 1586890168.103433
                                            ;movie_formats => {
                                               ;mp4 => true
                                               ;mov => false
                                            }  (;movie_formats)
                                            MOVIE PX = 740 PY = 416 transpa = false
                                            VRAY Finished after 1.99s
                                            VRAY Movie frame 2 animation time = 0.04s
                                            VRAY Movie frame 3 animation time = 0.08s
                                            VRAY Finished after 2.00s
                                            ......cut out........
                                            VRAY Movie frame 49 animation time = 1.92s
                                            VRAY Movie frame 50 animation time = 1.96s
                                            VRAY Movie frame 51 animation time = 2.00s
                                            VRAY STOP timer =
                                            Command FFmpeg for mp4 = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -framerate 25 -i "U1586890672_Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                                            ===> Status FFmpeg for mp4 = true
                                            Command FFmpeg for mov = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -i "Film 1.mp4" -acodec copy -vcodec copy -f mov "Film 1.mov" 2> FFmpeg_log_mov.txt
                                            ===> Status FFmpeg for mov = true
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 29
                                            • 30
                                            • 17 / 30
