    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • Y
      yonofun
      Any advice concerning ffmpeg video download. I followed the link and the FFmpeg.org pdf directions but didn't find the exact steps available and got into a baited ads trap and downloaded similarly labeled ffmpeg files that were unrelated. I successfully created an edit in animator and would love to get it to mp4.
      • fredo6F
        For Mac, here is the download page.
        Then I suggest you pick the latest build of FFmpeg for Mac (dated 3 Jan 2020).
        https://ffmpeg.zeranoe.com/builds/macos64/static/ffmpeg-20200102-81172b5-macos64-static.zip
        Just extract the ffmpegexecutable in the ** bin**subfolder and put it in a known place where you will point to from Animator.
        • fredo6F
          New Release: Animator - v2.6a - 12 Jan 20
          Requirement: LibFredo6 v9.5
          Minor release
          • New instructions for FFmpeg installation
          • Extension of validity
          See plugin home page of Animator for Download of RBZ from the PluginStore.
          See Main Post of the Animator thread for more information.
            stopping
            Hi there,
            thank you for this incredible plugin! I've been using it for about half a year now creating animation films and it's truly one of the greatest SU plugins out there.
            However, since yesterday afternoon I'm experiencing a few bugs.
            1. Animations aren't previewed in the editor
            2. I can't select a specific time in my timeline any more. On mouseover it hovers in turquoise, however, nothing happens upon clicking. When I temporarily exit to SU and return to Animator it has then selected the moment I wasn't able to select previously. However, it doesn't show the animations that should have happened up to this point.
            3. When I proceed to "Generate a Video for the Film" it does not show a pop up window. It just hides all menus and displays a red frame around the editor.
            All these issues occured from one moment to the other. It was fine yesterday morning but started behaving like this in the afternoon. I tried to reinstall both the animator as well as the lib but it didn't help. I then proceeded to try the plugins in SU17 - same issues here.
            I'm using Win 10 Pro 64 Bit, SU19.2.222, Lib 9.5g, Animator 2.6a
            Here are the lines from the Ruby Console upon opening the animator:
            Error; #<ArgumentError; wrong number of arguments (given 2, expected 3)>
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6spline.rbe;46;in `evaluate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;291;in `bezier'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;260;in `call'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;260;in `double'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;246;in `block in standard_function_calculate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;254;in `standard_function_calculate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;214;in `standard_interpolate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;61;in `interpolate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;988;in `animal_apply_easing_oscillation'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;920;in `animal_calculate_ratio'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;852;in `block in animal_animate_contribution'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;845;in `each'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;845;in `animal_animate_contribution'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;638;in `animal_animate_processing'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;574;in `animal_animate_film'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1356;in `clip_animate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1534;in `notify_from_clip_animation'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;239;in `call'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;239;in `notify_event'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;447;in `perform'
            And this is what I get when I try to select a specific time from the timeline:
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6oscillation.rbe;58;in `interpolate'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatoranimal.rbe;927;in `animal_calculate_ratio'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;317;in `rewind'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6animationengine.rbe;466;in `goto_time'
            This is the result from selecting "Generate a Video for the Film":
            RENDERING INIT
            Status natural = {}
            Status thea = ;not_supported
            Status ambient_occlusion = ;not_supported
            Status sketchFX = ;not_supported
            Status twilight = ;not_supported
            VRAY Init
            Status vray = ;not_supported
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatorclipmanager.rbe;1340;in `clip_animate_rewind'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;582;in `assign_clip'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;559;in `build_list_clips'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;363;in `dialog_invoke'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe;2206;in `movie_dialog'
            c;/users/steff/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_animator/animatortool.rbe;2176;in `movie_clip_generation'
            • fredo6F
              Thanks for signaling.
              It should normally be fixed with LibFredo6 9.5h, just published.
                stopping
                Excellent, Thanks for the quick reply! That actually solved it!
                • E
                  Emersonvip
                  any chance to work with Enscape?
                  • fredo6F
                    No for the time being. I would need to liaise with the Enscape developers to see if something can be done.
                    • E
                      Emersonvip
                      That would be wonderful.
                      • MechaHercM
                        MechaHerc
                        Hi guys, i got problem with new version, am i missing something here?
                        the exploded filter not working in vray rendered..
                        Vray Rendered
                        Sketchup Animation
                        • C
                          Chelle
                          I love the animator and it works great for creating spinning camera angles of my building designs however I've found an issue when rendering animations involving movement and kinetics of doors.
                          The animation works fine within Sketchup and in Animator. It also shows on the interactive render within Vray.
                          However when it comes to creating the MP4, it is only rendering the first image of the closed doors on repeat and not creating an animation.
                          This is the video which I am trying to render using Vray Next (working when just using Sketchup):
                          This is an example of the videos I have been creating where it has worked fine and rendered in Vray:
                          Please help as I am loving the software so far and would like the animated door videos to match the showcasing of the model.
                          Versions I am using:
                          Sketchup - Sketchup Pro 2020
                          Vray - Vray Next 4.20.01 Feb 18 2020
                          Fredo6 Animator - 2.6c - 19 Mar 20
                          • fredo6F
                            Could you post or PM the model.
                            Difficult to find out without.
                            Also, when you run the video generation, could you leave the Ruby Console open. There are traces showing the processing of frames. And there may be errors as well.
                            • C
                              Chelle
                              Thanks for replying.
                              I've attached the model as well for you to look at.
                              Ruby Console was showing the following, however I was having the same issue where it was rendering the first frame on repeat/no movement :
                              RENDERING INIT
                              Status natural = {}
                              VRAY Init
                              Status vray = nil
                              ;beg_time => 0
                              ;end_time => 6.0
                              ;frame_rate => 15
                              ;speed_factor => 1.0
                              ;reversed_play => nil
                              ;transparent => false
                              ;dimX => 1440
                              ;dimY => 864
                              ;dim_mode => "r5_3"
                              ;filter => {
                              }  (;filter)
                              ;root_dir => (Don't want to post this bit publicly)
                              ;movie_dir => "Cedar Garden Room Doors - 12-Apr-2020 10-18-12"
                              ;movie_name => "Door Move"
                              ;date_modified => 1586615101.854707
                              ;movie_formats => {
                                 ;mp4 => true
                                 ;mov => false
                              }  (;movie_formats)
                              ;rendering_method => ;vray
                              MOVIE PX = 1440 PY = 864 transpa = false
                              VRAY Movie frame 1 animation time = 0.00s
                              AFTER launching Rendering and Timer; status = true
                              VRAY Status check - status = 6
                              VRay rendering not finished yet elapsed = 2.00s
                              VRay rendering not finished yet elapsed = 4.00s
                              VRay rendering not finished yet elapsed = 5.99s
                              VRay rendering not finished yet elapsed = 8.46s
                              VRAY Status check - status = 4
                              VRAY Finished after 10.47s
                              VRAY Movie frame 2 animation time = 0.07s
                              VRay rendering not finished yet elapsed = 1.99s
                              VRay rendering not finished yet elapsed = 3.99s
                              VRay rendering not finished yet elapsed = 7.99s
                              VRAY Finished after 9.99s
                              VRAY Movie frame 3 animation time = 0.13s
                              VRay rendering not finished yet elapsed = 2.01s
                              VRay rendering not finished yet elapsed = 4.01s
                              VRay rendering not finished yet elapsed = 6.01s
                              VRay rendering not finished yet elapsed = 8.02s
                              VRAY Finished after 10.01s
                              VRAY Movie frame 4 animation time = 0.20s
                              VRay rendering not finished yet elapsed = 4.02s
                              VRay rendering not finished yet elapsed = 6.02s
                              VRAY Finished after 10.02s
                              VRAY Movie frame 5 animation time = 0.27s
                              VRAY Movie frame 6 animation time = 0.33s
                              VRay rendering not finished yet elapsed = 8.01s
                              VRay rendering not finished yet elapsed = 10.02s
                              VRAY Finished after 12.03s
                              VRAY Movie frame 7 animation time = 0.40s
                              VRAY Status check - status = 1
                              VRAY Error or Time out
                              VRAY Movie frame 8 animation time = 0.47s
                              INTERRUPT true
                              VRAY STOP timer = 31539
                              VRAY STOP timer =
                              I stopped the render at this point as this is when there is a gap in the door which is easily visible to see if it is working.
                              Thanks.
                              Model I'm Using
                                Serge73
                                The problem appears on any primitive model. For example, rectilinear movement of a cube.
                                The problem with SketchUP 2020 and V-REY 4.20.01
                                Render only the first frame. The clip consists of the same frames, the duration is not important.
                                there is a problem on the forum
                                ;beg_time => 0
                                ;end_time => 2.0
                                ;frame_rate => 25
                                ;reversed_play => false
                                ;dimX => 740
                                ;dimY => 416
                                ;dim_mode => "r16_9"
                                ;filter => {
                                }  (;filter)
                                ;root_dir => "C;/TEMP/Animator Videos"
                                ;movie_dir => "test - 14-Apr-2020 23-57-29"
                                ;movie_name => "Film 1"
                                ;date_modified => 1586890168.103433
                                ;movie_formats => {
                                   ;mp4 => true
                                   ;mov => false
                                }  (;movie_formats)
                                MOVIE PX = 740 PY = 416 transpa = false
                                VRAY Finished after 1.99s
                                VRAY Movie frame 2 animation time = 0.04s
                                VRAY Movie frame 3 animation time = 0.08s
                                VRAY Finished after 2.00s
                                ......cut out........
                                VRAY Movie frame 49 animation time = 1.92s
                                VRAY Movie frame 50 animation time = 1.96s
                                VRAY Movie frame 51 animation time = 2.00s
                                VRAY STOP timer =
                                Command FFmpeg for mp4 = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -framerate 25 -i "U1586890672_Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                                ===> Status FFmpeg for mp4 = true
                                Command FFmpeg for mov = "C;/Program Files/ffmpeg/bin/ffmpeg.exe" -i "Film 1.mp4" -acodec copy -vcodec copy -f mov "Film 1.mov" 2> FFmpeg_log_mov.txt
                                ===> Status FFmpeg for mov = true
                                • T
                                  TonyAU
                                  Before I get into my issue I would like to thank Fredo for the hard work in creating this plug-in, it's awesome!!
                                  Now I just need to check if anyone else is having issues with animating camera views, For some reason in this release the camera's seem to be glitching.. If I save a camera view in the animator, they start in the correct position then jump out to an unexpected view then finish on the correct location.. There's no fluidity to the movement, not sure if it's something I'm doing wrong though.. It definitely could be.. 😄
                                  Let me know your thoughts
                                  Cheers..
                                  • fredo6F
                                    @tonyAU
                                    It would help to have the model.
                                    Do you use only ONE camera or several?
                                    • T
                                      TonyAU
                                      Hi Fredo,
                                      File attached, I think it happens on all my files so don't know if it's my end or yours.. I can live without it, I just thought I would put it out there and give you the heads up.
                                      cheers for all your hard work..
                                      Animator Cam test.skp
                                      • fredo6F
                                        @TonyAU,
                                        Thanks for the model.
                                        It helped me to realize that there was a bug in the interpolation of cameras when they are in Parallel projection.
                                        I fixed it and it will go in LibFredo6 v10.1.
                                        • T
                                          TonyAU
                                          Your a legend..
                                          Thank you Fredo
                                            serland
                                            Hi all,
                                            Sorry but the problem persits, with LibFredo 10.1 and lastest Animator ver. when the VRay mode is selected it only renders the first frame in the final video.
                                            I attach the skp file and the video.
                                            Natural Animation
                                            ;beg_time => 0
                                            ;end_time => 1.0
                                            ;frame_rate => 25
                                            ;dimX => 1498
                                            ;dimY => 856
                                            ;dim_mode => "viewport"
                                            ;filter => {
                                            }  (;filter)
                                            ;root_dir => "C;/Users/serland/Desktop/Animator Videos"
                                            ;movie_dir => "Sin título - 29-Apr-2020 12-08-02"
                                            ;date_modified => 1588154844.373782
                                            ;movie_formats => {
                                               ;mp4 => true
                                               ;mov => false
                                            }  (;movie_formats)
                                            ;rendering_method => ;natural
                                            MOVIE PX = 1498 PY = 856 transpa = false
                                            NATURAL image 1 time = 0s Image01.png frame = 1 res = 1498x856
                                            NATURAL image 2 time = 0.04s Image02.png frame = 2 res = 1498x856
                                            NATURAL image 3 time = 0.08s Image03.png frame = 3 res = 1498x856
                                            NATURAL image 4 time = 0.12s Image04.png frame = 4 res = 1498x856
                                            ... cut ...
                                            NATURAL image 24 time = 0.9200000000000003s Image24.png frame = 24 res = 1498x856
                                            NATURAL image 25 time = 0.9600000000000003s Image25.png frame = 25 res = 1498x856
                                            NATURAL image 26 time = 1.0s Image26.png frame = 26 res = 1498x856
                                            Command FFmpeg for mp4 = "D;/FFMPEG/bin/ffmpeg.exe" -framerate 25 -i "Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                                            Command FFmpeg for mov = "D;/FFMPEG/bin/ffmpeg.exe" -i "Film 1.mp4" -acodec copy -vcodec copy -f mov "Film 1.mov" 2> FFmpeg_log_mov.txt
                                            VRay Animation
                                            ;beg_time => 0
                                            ;end_time => 1.0
                                            ;frame_rate => 25
                                            ;dimX => 1498
                                            ;dimY => 856
                                            ;filter => {
                                            }  (;filter)
                                            ;movie_dir => "Sin título - 29-Apr-2020 12-09-18"
                                            ;movie_formats => {
                                               ;mp4 => true
                                               ;mov => false
                                            }  (;movie_formats)
                                            VRAY Finished after 6.00s
                                            VRAY Finished after 5.99s
                                            ... cut...
                                            VRAY Movie frame 26 animation time = 1.00s
                                            VRay rendering not finished yet elapsed = 6.00s
                                            VRAY Finished after 8.00s
                                            VRAY STOP timer =
                                            Command FFmpeg for mp4 = "D;/FFMPEG/bin/ffmpeg.exe" -framerate 25 -i "U1588154971_Image%02d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1  "Film 1.mp4" 2> FFmpeg_log_mp4.txt
                                            Thanks for your job
                                            Sin título.skp
                                            Animator.mov
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 29
                                            • 30
                                            • 17 / 30
