    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • panixiaP
      panixia
      @jiminy-billy-bob said:
      @panixia said:
      @einstein said:
      Then we wouldn't probably need Transmutr, which is an expensive tool.
      I don't know how expensive this tool is, but as far as I saw, this doesn't supports quads from other modeling pakages.
      If it does, I would pay for it no problem at all. Now. The "shut up and take my moneys!" style.
      It is planned for a future Transmutr version ๐Ÿ˜‰
      It's a bit tricky to do, but I believe it's possible.
      I don't have an ETA, though. For now we are focused on Skatter v2.
      That would be really valuable for me, I'm more on the VR/game engine side of the fence right now, so no need for scatters/proxyes, but good topology is on top of the needs. ๐Ÿ˜„
        8 perf1
        This seems like a fantastic plugin!
        I too am having issues with 1.1.5 on Mac OS 10.12.6. with Sketchup 2017 Make.
        A poster back on page 6 had the same issue I am having. I dont know if I can post images here or not as I dont frequent the site enough. His earlier post had this...
        403 Forbidden
        (sketchucation.com)
        Im getting the same and was wondering if its an OS issue. I downloaded the most recent version of ASSIMP thinking I might need that. Do I? Couldn't figure out how to install it anyway. ๐Ÿ˜„
        Would love to get this sorted to be able to play around with this and put it through its paces. Thanks for any insight.
        • samuel_tS
          samuel_t
          Unfortunately, I think plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater.
            8 perf1
            Thanks samuel. Maybe after a long needed upgrade Ill try it again.
            • C
              colorfulman
              Hi sir:
              Thank you so much for you write this power plugin.
              When I use Universal Importer import any .stp file,Showned below erro,Can you help me?
              you can try import any .stp file to test this bug,This website is not allow me upload .stp file
              SketchUp 2019
              Universal Importer Error: Command failed: "C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Win/assimp.exe" info "C:\ProgramData/Universal Importer/tmp/import.stp" > "C:\ProgramData/Universal Importer/tmp/assimp.nfo"
              Launching asset import ... OK
              Validating postprocessing flags ... OK
              ERROR: Failed to load file: Validation failed: A node of the scenegraph is NULL
              assimp info: Unable to load input file C:\ProgramData/Universal Importer/tmp/import.stp
              C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
              Universal Importer Version: 1.1.5
              ็กฎๅฎš
              • T
                treddigaetano
                hi, can to import also mtl texture file of .obj ?
                • samuel_tS
                  samuel_t
                  @colorfulman said:
                  Hi sir:
                  SketchUp 2019
                  ็กฎๅฎš
                  Thank you for your report. Unfortunately I can't fix that issue. ๐Ÿ˜•
                  • samuel_tS
                    samuel_t
                    Hi, don't worry: MTL texture file of OBJ is automatically loaded. ๐Ÿ˜‰
                    • K
                      kd8qlo
                      Hello!
                      I keep getting this same error?
                      any ideas?
                      • samuel_tS
                        samuel_t
                        @kd8qlo said:
                        https://sketchucation.com/forums/download/file.php?id=158823
                        Hello!
                        any ideas?
                        Hello! Reinstall Microsoft Visual C++ runtime then try to import a model with Universal Importer...
                        • C
                          christopheforet
                          Hi all!
                          I get errors when importing different file types...
                          On Mac OS, Sketchup 2017, plugin v1.1.5.
                          Any ideas on how to fix this?
                            On Mac OS
                            What version of Mac OS? As Samuel indicated a few posts up, "...plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater."
                            • I
                              ibex
                              Thanks for providing this plugin.
                              I have installed it on Sketchup 2017 and also reinstalled the Windows C+ library. The plugin appears in my options and the toolbar is in place.
                              Each time I run it I get this error message trying to install an .stp file which I downloaded from here https://www.linak.com/products/linear-actuators/la22/#/2d3d
                              • samuel_tS
                                samuel_t
                                • L
                                  lema
                                  Textures are not imported correctly.
                                  The leaf is imported upside down.
                                  This can be understood if you open the model in other applications.
                                  https://drive.google.com/file/d/1-aTDHwlIvZhZY7RVeTcOy5WcILBdpfy1/view?usp=sharing
                                  • samuel_tS
                                    samuel_t
                                    @lema said:
                                    Hi, thank you for your report. Unfortunately I can't fix that issue. ๐Ÿ˜•
                                    • T
                                      turbodizayn
                                      Hi Sam!
                                      This is great plugin and for me it is better than transmuttr and skimp. Genius work.
                                      There is only problem-if model textured I have no polygon reduction =((( It works only with no texture material models for me. From time to time "redusePolygonCount" makes even more polygons then is in original model. May be it is 1.1.5 issue but there no source to download previous versions.
                                      I hope it will be fixed, please!
                                      PS You can see in second row no optimization of textured sphere
                                      • samuel_tS
                                        samuel_t
                                        @turbodizayn said:
                                        Hi Sam!
                                        Hi Turbo!
                                        Issues you describe seem to come from polygon reduction program (MeshLab) used in background by plugin. This mean, I can't fix them. ๐Ÿ˜•
                                          suestorm
                                          Hi Samuel,
                                          Thanks for the plug in, unfortunately I can not get it to work with Sketchup Pro 2019 or 2020. I downloaded universal importer v1.1.5.rbz from SketchUcation and installed it using the Extension Manager. I click on "Import with Universal Importer" in the File menu, select my .obj or .fbx model, and get the following error message. (please see attachment) and then the program crashes.
                                          I am using Mac OS 10.15.1 Catalina. I have Sketchup Pro 2019 and 2018 and I get the same result on both versions.
                                          Any suggestions?
                                          thanks,
                                          Dawn
                                          • E
                                            edwinfolk
                                            Hello Samuel,
                                            This looks like an awesome plugin and incredibly useful for rendering. Unfortunately, like Sue I cannot get it to work. I am using 2018 SKU and MacOS 10.15.2. Is there a work around? Or, is our OS not compatible at this time? Look forward to your answer and thanks.
                                            • 11
                                            • 12
                                            • 22
                                            • 23
                                            • 10 / 23
