    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
    • K
      kd8qlo
      Hello!
      I keep getting this same error?
      any ideas?
      • samuel_tS
        samuel_t
        @kd8qlo said:
        https://sketchucation.com/forums/download/file.php?id=158823
        Hello!
        any ideas?
        Hello! Reinstall Microsoft Visual C++ runtime then try to import a model with Universal Importer...
        • C
          christopheforet
          Hi all!
          I get errors when importing different file types...
          On Mac OS, Sketchup 2017, plugin v1.1.5.
          Any ideas on how to fix this?
            On Mac OS
            What version of Mac OS? As Samuel indicated a few posts up, "...plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater."
            • I
              ibex
              Thanks for providing this plugin.
              I have installed it on Sketchup 2017 and also reinstalled the Windows C+ library. The plugin appears in my options and the toolbar is in place.
              Each time I run it I get this error message trying to install an .stp file which I downloaded from here https://www.linak.com/products/linear-actuators/la22/#/2d3d
              • samuel_tS
                samuel_t
                Thank you for your report. Unfortunately I can't fix that issue. πŸ˜•
                • L
                  lema
                  Textures are not imported correctly.
                  The leaf is imported upside down.
                  This can be understood if you open the model in other applications.
                  https://drive.google.com/file/d/1-aTDHwlIvZhZY7RVeTcOy5WcILBdpfy1/view?usp=sharing
                  • samuel_tS
                    samuel_t
                    @lema said:
                    Hi, thank you for your report. Unfortunately I can't fix that issue. πŸ˜•
                    • T
                      turbodizayn
                      Hi Sam!
                      This is great plugin and for me it is better than transmuttr and skimp. Genius work.
                      There is only problem-if model textured I have no polygon reduction =((( It works only with no texture material models for me. From time to time "redusePolygonCount" makes even more polygons then is in original model. May be it is 1.1.5 issue but there no source to download previous versions.
                      I hope it will be fixed, please!
                      PS You can see in second row no optimization of textured sphere
                      • samuel_tS
                        samuel_t
                        @turbodizayn said:
                        Hi Sam!
                        Hi Turbo!
                        Issues you describe seem to come from polygon reduction program (MeshLab) used in background by plugin. This mean, I can't fix them. πŸ˜•
                          suestorm
                          Hi Samuel,
                          Thanks for the plug in, unfortunately I can not get it to work with Sketchup Pro 2019 or 2020. I downloaded universal importer v1.1.5.rbz from SketchUcation and installed it using the Extension Manager. I click on "Import with Universal Importer" in the File menu, select my .obj or .fbx model, and get the following error message. (please see attachment) and then the program crashes.
                          I am using Mac OS 10.15.1 Catalina. I have Sketchup Pro 2019 and 2018 and I get the same result on both versions.
                          Any suggestions?
                          thanks,
                          Dawn
                          • E
                            edwinfolk
                            Hello Samuel,
                            This looks like an awesome plugin and incredibly useful for rendering. Unfortunately, like Sue I cannot get it to work. I am using 2018 SKU and MacOS 10.15.2. Is there a work around? Or, is our OS not compatible at this time? Look forward to your answer and thanks.
                            • samuel_tS
                              samuel_t
                              Hi suestorm, hello edwinfolk,
                              I don't have a real mac computer. πŸ˜•
                              When error occurs in SketchUp: Can you copy-paste command that fails ("/Users/.../assimp.nfo") to a terminal then show me back result?
                              This way I could maybe remotely debug...
                                suestorm
                                Hi Samuel,
                                Thanks for your reply. I don't understand what you mean about sending you a terminal, but I copy/pasted what comes up in the error box on my screen. Also attached a screen grab. I see several Mac users have posted the same error message, we are all having a consistent problem. I am on Mac OS 10.15.4 Sketchup Pro 2020. Thanks.
                                Universal Importer Error: Command failed: "/Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/dawn/.UniversalImporter/tmp/import.fbx" > "/Users/dawn/.UniversalImporter/tmp/assimp.nfo"
                                /Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
                                Universal Importer Version: 1.1.5
                                • samuel_tS
                                  samuel_t
                                  @suestorm said:
                                  Hi Samuel,
                                  Hi suestorm,
                                  I mean:
                                  1. Open SketchUp.
                                  2. Import a .fbx model with Universal Importer plugin.
                                  3. Wait error... then copy-paste following command to your terminal. (See this tuto here to know how.)
                                  1. Send me back terminal result (text or screenshot).
                                  Thanks.
                                    I think something might be getting lost in translation ?
                                    For 'Terminal' perhaps read 'SketchUp > Window > Ruby Console' [open it before doing anything]
                                    Although on a MAC there is a separate 'Terminal' app, surely you'd need it running before the error occurs ?
                                    • samuel_tS
                                      samuel_t
                                      I'm talking about that separate 'Terminal' app.
                                        So do you need to explain to MAC users to open the Terminal first, and then try your tool...
                                        And any error-messages might appear in that Terminal window ?
                                        • samuel_tS
                                          samuel_t
                                          No, command line needs to be pasted in Mac's Terminal after that Universal Importer plugin crashes.
                                          • E
                                            edwinfolk
                                            Hello Samuel,
                                            Thanks for doing this. This looks like a really great plugin that can help with rendering and setting up reference models for a lot of Maxwell users. Attached is a screen shot of the terminal window. Hope you can make sense of it.
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
