    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • samuel_tS
      samuel_t
      @kd8qlo said:
      https://sketchucation.com/forums/download/file.php?id=158823
      Hello!
      I keep getting this same error?
      any ideas?
      Hello! Reinstall Microsoft Visual C++ runtime then try to import a model with Universal Importer...
      • C
        christopheforet
        Hi all!
        I get errors when importing different file types...
        On Mac OS, Sketchup 2017, plugin v1.1.5.
        Any ideas on how to fix this?
          On Mac OS
          What version of Mac OS? As Samuel indicated a few posts up, "...plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater."
          • I
            ibex
            Thanks for providing this plugin.
            I have installed it on Sketchup 2017 and also reinstalled the Windows C+ library. The plugin appears in my options and the toolbar is in place.
            Each time I run it I get this error message trying to install an .stp file which I downloaded from here https://www.linak.com/products/linear-actuators/la22/#/2d3d
            • samuel_tS
              samuel_t
              Thank you for your report. Unfortunately I can't fix that issue. πŸ˜•
              • L
                lema
                Textures are not imported correctly.
                The leaf is imported upside down.
                This can be understood if you open the model in other applications.
                https://drive.google.com/file/d/1-aTDHwlIvZhZY7RVeTcOy5WcILBdpfy1/view?usp=sharing
                • samuel_tS
                  samuel_t
                  @lema said:
                  Hi, thank you for your report. Unfortunately I can't fix that issue. πŸ˜•
                  • T
                    turbodizayn
                    Hi Sam!
                    This is great plugin and for me it is better than transmuttr and skimp. Genius work.
                    There is only problem-if model textured I have no polygon reduction =((( It works only with no texture material models for me. From time to time "redusePolygonCount" makes even more polygons then is in original model. May be it is 1.1.5 issue but there no source to download previous versions.
                    I hope it will be fixed, please!
                    PS You can see in second row no optimization of textured sphere
                    • samuel_tS
                      samuel_t
                      @turbodizayn said:
                      Hi Sam!
                      Hi Turbo!
                      Issues you describe seem to come from polygon reduction program (MeshLab) used in background by plugin. This mean, I can't fix them. πŸ˜•
                        suestorm
                        Hi Samuel,
                        Thanks for the plug in, unfortunately I can not get it to work with Sketchup Pro 2019 or 2020. I downloaded universal importer v1.1.5.rbz from SketchUcation and installed it using the Extension Manager. I click on "Import with Universal Importer" in the File menu, select my .obj or .fbx model, and get the following error message. (please see attachment) and then the program crashes.
                        I am using Mac OS 10.15.1 Catalina. I have Sketchup Pro 2019 and 2018 and I get the same result on both versions.
                        Any suggestions?
                        thanks,
                        Dawn
                        • E
                          edwinfolk
                          Hello Samuel,
                          This looks like an awesome plugin and incredibly useful for rendering. Unfortunately, like Sue I cannot get it to work. I am using 2018 SKU and MacOS 10.15.2. Is there a work around? Or, is our OS not compatible at this time? Look forward to your answer and thanks.
                          • samuel_tS
                            samuel_t
                            Hi suestorm, hello edwinfolk,
                            I don't have a real mac computer. πŸ˜•
                            When error occurs in SketchUp: Can you copy-paste command that fails ("/Users/.../assimp.nfo") to a terminal then show me back result?
                            This way I could maybe remotely debug...
                              suestorm
                              Hi Samuel,
                              Thanks for your reply. I don't understand what you mean about sending you a terminal, but I copy/pasted what comes up in the error box on my screen. Also attached a screen grab. I see several Mac users have posted the same error message, we are all having a consistent problem. I am on Mac OS 10.15.4 Sketchup Pro 2020. Thanks.
                              Universal Importer Error: Command failed: "/Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/dawn/.UniversalImporter/tmp/import.fbx" > "/Users/dawn/.UniversalImporter/tmp/assimp.nfo"
                              /Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
                              Universal Importer Version: 1.1.5
                              • samuel_tS
                                samuel_t
                                @suestorm said:
                                Hi Samuel,
                                Hi suestorm,
                                I mean:
                                1. Open SketchUp.
                                2. Import a .fbx model with Universal Importer plugin.
                                3. Wait error... then copy-paste following command to your terminal. (See this tuto here to know how.)
                                1. Send me back terminal result (text or screenshot).
                                Thanks.
                                  I think something might be getting lost in translation ?
                                  For 'Terminal' perhaps read 'SketchUp > Window > Ruby Console' [open it before doing anything]
                                  Although on a MAC there is a separate 'Terminal' app, surely you'd need it running before the error occurs ?
                                  • samuel_tS
                                    samuel_t
                                    I'm talking about that separate 'Terminal' app.
                                      So do you need to explain to MAC users to open the Terminal first, and then try your tool...
                                      And any error-messages might appear in that Terminal window ?
                                      • samuel_tS
                                        samuel_t
                                        No, command line needs to be pasted in Mac's Terminal after that Universal Importer plugin crashes.
                                        • E
                                          edwinfolk
                                          Hello Samuel,
                                          Thanks for doing this. This looks like a really great plugin that can help with rendering and setting up reference models for a lot of Maxwell users. Attached is a screen shot of the terminal window. Hope you can make sense of it.
                                            McGordon
                                            The permission denied means you don't have executable permissions on that assimp file. Can you paste this into Terminal and press return:
                                            ls -l ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/Assimp/Mac
                                            Then show us the results, which should look something like this:
                                            total 25448
                                            -rwxr-xr-x@ 1 gordon  staff      3791 24 Sep  2019 LICENSE.txt
                                            -rwxr-xr-x@ 1 gordon  staff    149772  6 Jan 16;05 assimp
                                            -rwxr-xr-x@ 1 gordon  staff  12810620  6 Jan 16;05 libassimp.dylib
                                            -rwxr-xr-x@ 1 gordon  staff     58316 24 Sep  2019 x.dyl
                                            I haven't installed this yet, I'm just trying to help as samuel_t doesn't have a Mac. The first 'x' in '-rwxr-xr-x@' for assimp means I could run that file as a program. That's the bit I'm looking for when you run that command which just lists what's in that directory.
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
