    Clipping Plane Plugin
    21 Posts 9 Posters 5.3k Views 9 Watching
    • sfto1S Offline
      sfto1
      Has anyone tested and/purchased Daniel Tal's Clipping Plane Plugin?
      Wondering how well it works when clipping happens very close up. His video looks intriguing, but his examples still seemed far from the object being clipped.
      • sfto1S Offline
        sfto1
        I discovered a workaround, which is not as simple as a one button solution as Daniel Tal's, but its free and trying it, it seems to work fine. Not sure if it has unnoticed consequences, but it seems simple enough to reverse.
        Any of you plugin masters here on sketchucation up to making one?
        • jujuJ Offline
          juju
          Interesting how this is somehow "discovered" and only makes it "out there" AFTER clipping plane was released...
          • sfto1S Offline
            sfto1
            Just for clarification sake, I didn't "discover" the workaround. I stumbled on/discovered the video by SUforyou (referenced above) when trying to find out more about Daniel's plugin.
            Perplexed why, what seems to be somewhat simple, has not been made into a native tool after all these years of users struggling with clipping.
            • jujuJ Offline
              juju
              I probably expressed myself inadequately. I wasn't saying that you "discovered" it, but was referring to the person (-s) in the clip you linked to. Although I know them to be long time SU users and rather proficient at it as well.
                A short question if I may, why the video to make such a small point? Why not just give a simple instruction?
                • jujuJ Offline
                  juju
                  Because we are creative people, and creative people are visual people?
                    I am a creative person and like to think visually, that's why I like text, so much simpler and less room for waffling. Nice.
                      samnorth
                      ThomThom's Camera tools has a shortcut to the camera parameters panel [SU menu->Camera->Advanced]
                      SketchUp Plugins | PluginStore | SketchUcation
                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                      (sketchucation.com)
                      • jiminy-billy-bobJ Offline
                        jiminy-billy-bob
                        The "Force" checkbox was added in SketchUp 2017. We've known since then.
                        The issue is that it is not exposed in the Ruby API, so no extension could leverage it.
                        I guess Daniel Tal's extension simply found a hacky way to check this box automatically, but simulating clicks or something like that. This is probably the reason it is only available on Windows.
                        • GD3DesignG Offline
                          GD3Design
                          $50! 😮
                          Greedy much..?
                          • jujuJ Offline
                            juju
                            @gd3design said:
                            $50! 😮
                            Greedy much..?
                            Not cheap/inexpensive no.
                            It works (Windows only), it saves time, it saves aggrevation, it is a perpetual licence. From what I understand it makes use of 3rd party software/code which is licenced, nobody else has been able to bring a solution to market since ever.
                            Rather say you can't afford it, no shame in that.
                            • PixeroP Offline
                              Pixero
                              I've made a plugin that opens the advanced camera settings window on rightclick if you want to adjust clipping plane manually.
                              (sketchucation.com)
                                slbaumgartner
                                Not meaning to whine, but this all raises the question of why no such camera parameters dialog has ever been available on Mac - meaning it isn't even possible to create the equivalent of Daniel's plugin!
                                  Be aware that if you set the Near value too low you can create other problems. You might end up with something like this:
                                  Instead of this:
                                  • PixeroP Offline
                                    Pixero
                                    Doesn't this work on Mac?
                                    Sketchup.send_action 10624
                                      No. It's a PC thing only.
                                      • sfto1S Offline
                                        sfto1
                                        (sketchucation.com)
                                        Thanks Pixero!
                                        • sfto1S Offline
                                          sfto1
                                          [attachment=1:2ofksyrr]<!-- ia1 -->Screenshot - 2_24_2020 , 8_17_37 AM.png<!-- ia1 -->[/attachment:2ofksyrr]
                                          Instead of this:
                                          [attachment=0:2ofksyrr]<!-- ia0 -->Screenshot - 2_24_2020 , 8_17_54 AM.png<!-- ia0 -->[/attachment:2ofksyrr]
                                          Using Pixero's solution, if the z fighting effect happens, uncheck the "force" box and zoom out. The camera near distance resets and the z fighting effect should disappear.
                                            Yes. I found that works. I was just advising that one shouldn't just set a very small Near value and expect it to work for all camera positions.
