    Clipping Plane Plugin
    21 Posts 9 Posters 6.7k Views 9 Watching
      samnorth
      ThomThom's Camera tools has a shortcut to the camera parameters panel [SU menu->Camera->Advanced]
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      • jiminy-billy-bobJ
        jiminy-billy-bob
        @juju said:
        Interesting how this is somehow "discovered" and only makes it "out there" AFTER clipping plane was released...
        The "Force" checkbox was added in SketchUp 2017. We've known since then.
        The issue is that it is not exposed in the Ruby API, so no extension could leverage it.
        I guess Daniel Tal's extension simply found a hacky way to check this box automatically, but simulating clicks or something like that. This is probably the reason it is only available on Windows.
        • GD3DesignG
          GD3Design
          $50! ๐Ÿ˜ฎ
          Greedy much..?
          • jujuJ
            juju
            @gd3design said:
            $50! ๐Ÿ˜ฎ
            Greedy much..?
            Not cheap/inexpensive no.
            It works (Windows only), it saves time, it saves aggrevation, it is a perpetual licence. From what I understand it makes use of 3rd party software/code which is licenced, nobody else has been able to bring a solution to market since ever.
            Rather say you can't afford it, no shame in that.
            • PixeroP
              Pixero
              I've made a plugin that opens the advanced camera settings window on rightclick if you want to adjust clipping plane manually.
              (sketchucation.com)
                slbaumgartner
                Not meaning to whine, but this all raises the question of why no such camera parameters dialog has ever been available on Mac - meaning it isn't even possible to create the equivalent of Daniel's plugin!
                  Be aware that if you set the Near value too low you can create other problems. You might end up with something like this:
                  Instead of this:
                  • PixeroP
                    Pixero
                    Doesn't this work on Mac?
                    Sketchup.send_action 10624
                      No. It's a PC thing only.
                      • sfto1S
                        sfto1
                        (sketchucation.com)
                        Thanks Pixero!
                        • sfto1S
                          sfto1
                          [attachment=1:2ofksyrr]<!-- ia1 -->Screenshot - 2_24_2020 , 8_17_37 AM.png<!-- ia1 -->[/attachment:2ofksyrr]
                          Instead of this:
                          [attachment=0:2ofksyrr]<!-- ia0 -->Screenshot - 2_24_2020 , 8_17_54 AM.png<!-- ia0 -->[/attachment:2ofksyrr]
                          Using Pixero's solution, if the z fighting effect happens, uncheck the "force" box and zoom out. The camera near distance resets and the z fighting effect should disappear.
                            Yes. I found that works. I was just advising that one shouldn't just set a very small Near value and expect it to work for all camera positions.
                            • sfto1S
                              sfto1
                              ๐Ÿ‘
