    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      SketchUp version 2014 is old.
      Support from SketchUp only extends back to v2017.
      Some Extensions' authors allow backward compatible to v8, and reading this tool's guide it should be OK...
      An oddity in your error message suggests that it's been NOT installed properly.
      Usually the installation path is...
      C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
      So how did you install this toolset exactly ?
      How is it that SketchUp is trying to load it from here ?
      C:\Documents and Settings\user\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
      What is your current Windows OS ?
      Please fill in your Profile properly...
      It might well be incompatible ?
      Many users have this tool installed successfully in many SketchUp versions.
      Starting off "on an aggressive preemptive attack" might work in wing chung, but when your are asking for advice or help, then a more conciliatory tone often attracts a more sympathetic and helpful response... 😲
      • fredo6F Offline
        This is related with the non-ascii deficiencies of old Sketchup versions in some Windows configurations, and there is nothing that can be done (except to migrate to newer versions).
          LisaG
          Just downloaded LibFredo6 plugin for SketchUp Make V2017. The installation is not yet complete as under Preferences there is no "Extensions" listed. Not sure where else to find it!
          Thanks.
            Thanks.
            LibFredo6 appears in the Window menu and Bezier Spline Curves appears in the Draw menu. Did you look there?
              Ahmed0007
              Polyline segmentor is not working in sketchup 2020?
                It worked for me just now in 2020.
                  Ahmed0007
                  [attachment=1:37qeug7g]<!-- ia1 -->Screenshot - 2_2_2020 , 3_59_21 PM.png<!-- ia1 -->[/attachment:37qeug7g]
                  Thanks for quick response.
                  but not working for me 😞
                  .Gif
                  • BoxB Offline
                    Do you have the most up to date Libfredo?
                    • fredo6F Offline
                      @Ahmed0007
                      Normally, when you convert to Segmentor, you should have a dialog box popping up (asking for number of segments).
                      Could you open the Ruby console while you invoke the convert.
                        Ahmed0007
                        yes.
                          Ahmed0007
                          @fredo6 said:
                          @Ahmed0007
                          Error: #<NameError: uninitialized constant BZ__Segmentor::Traductor>
                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/BZ__Segmentor.rb:72:in bz_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
                          Thanks for Respond
                          • fredo6F Offline
                            Can you check if in your plugin directory, subfolder bezierspline, you have a file called LibTraductor.rb.
                            If not, can you download beizerspline v2.1a.
                            Also, you should delete any file LibTraductor.rb which would be in the main Plugin directory.
                              Ahmed0007
                              Thanks Now it's working.
                              • fredo6F Offline
                                What was the problem?
                                  rv1974
                                  Fredo, two observations:
                                  'Close nicely' in Cubic Bezier is broken (the curve disappears, rarely the curve is kept but it exits without closing)
                                  Would it be possible to add some F(?) shortcut to 'Done end exit' across all sub-tools?
                                  Thank you
                                  P.S. BTW there's something in your closed curves that doesn't allow them to be used as paths for Profile Builder's assemblies. I'd have to explode or 'turn to arch' (another plugin) to overcome it. Is there possibility to do something on your end?
                                  • fredo6F Offline
                                    I am not able to reproduce the issues you mentioned.
                                    Could you open the Ruby console when you play with BezierSpline.
                                      rv1974
                                      Error: #<ArgumentError: wrong number of arguments (given 2, expected 1)>
                                      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
                                      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2049:in call_compute_curve' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:984:in draw'
                                        rv1974
                                        rror: #<ArgumentError: At least 2 points required to initialize curve>
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/curve.rbe:8:in initialize' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in new'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in block in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in each_index'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:1995:in offset!'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:2191:in offset_chain' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:219:in block in build_rails'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in each' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in build_rails'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:184:in draw' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1221:in build_fence'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1209:in block in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in each'
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:126:in block in initialize'
                                        I could send a file if needed
                                        • fredo6F Offline
                                          Could you send me the offset.rb file that is mentioned
                                          C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in `offset'
                                          I don't know what it is but it may cause a conflict.
                                            rv1974
                                            some info:
                                            http://www.smustard.com/script/Offset
                                            Please download the updated offset.rb from there.
                                            After I updated the offset.rb from the link above the error message slightly changed:
                                            C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:149:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
