    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • fredo6F Offline
      @Ahmed0007
      Normally, when you convert to Segmentor, you should have a dialog box popping up (asking for number of segments).
      Could you open the Ruby console while you invoke the convert.
        Ahmed0007
        @box said:
        Do you have the most up to date Libfredo?
        yes.
          Ahmed0007
          @fredo6 said:
          @Ahmed0007
          Error: #<NameError: uninitialized constant BZ__Segmentor::Traductor>
          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/BZ__Segmentor.rb:72:in bz_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
          Thanks for Respond
          • fredo6F Offline
            Can you check if in your plugin directory, subfolder bezierspline, you have a file called LibTraductor.rb.
            If not, can you download beizerspline v2.1a.
            Also, you should delete any file LibTraductor.rb which would be in the main Plugin directory.
              Ahmed0007
              Thanks Now it's working.
              • fredo6F Offline
                What was the problem?
                  rv1974
                  Fredo, two observations:
                  'Close nicely' in Cubic Bezier is broken (the curve disappears, rarely the curve is kept but it exits without closing)
                  Would it be possible to add some F(?) shortcut to 'Done end exit' across all sub-tools?
                  Thank you
                  P.S. BTW there's something in your closed curves that doesn't allow them to be used as paths for Profile Builder's assemblies. I'd have to explode or 'turn to arch' (another plugin) to overcome it. Is there possibility to do something on your end?
                  • fredo6F Offline
                    I am not able to reproduce the issues you mentioned.
                    Could you open the Ruby console when you play with BezierSpline.
                      rv1974
                      Error: #<ArgumentError: wrong number of arguments (given 2, expected 1)>
                      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
                      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2049:in call_compute_curve' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:984:in draw'
                        rv1974
                        rror: #<ArgumentError: At least 2 points required to initialize curve>
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/curve.rbe:8:in initialize' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in new'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in block in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in each_index'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:1995:in offset!'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:2191:in offset_chain' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:219:in block in build_rails'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in each' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in build_rails'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:184:in draw' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1221:in build_fence'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1209:in block in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in each'
                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:126:in block in initialize'
                        I could send a file if needed
                        • fredo6F Offline
                          Could you send me the offset.rb file that is mentioned
                          C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in `offset'
                          I don't know what it is but it may cause a conflict.
                            rv1974
                            some info:
                            http://www.smustard.com/script/Offset
                            Please download the updated offset.rb from there.
                            After I updated the offset.rb from the link above the error message slightly changed:
                            C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:149:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
                            • fredo6F Offline
                              You should definitely disregard this plugin.
                              It redefines base methods for native Sketchup objects (Face, Array, ...). So it causes conflicts with other plugins, among which mine. There is nothing I can do about it.
                              By the way, this offset.rb is a library to be used by other plugins or extensions. Which one requires offset.rb?
                                rv1974
                                at least this one:
                                https://sketchucation.com/forums/viewtopic.php?f=180&t=14095
                                damn.. from 2008 (sketchup 6) .. I have to put it down with heavy nostalgia.
                                • fredo6F Offline
                                  @rv1974 said:
                                  at least this one:
                                  I publish a fix with version BezierSpline v2.1b.
                                  But, frankly, offset.rb should be avoided, because it redefines methods in base classes of Sketchup Ruby.
                                  • fredo6F Offline
                                    NEW RELEASE 2.1b - 14 Apr 21
                                    This release prevents a conflict with offset.rb (RickW).
                                    More info at main post
                                    Download BezierSpline at Sketchucation Plugin Store
                                      rv1974
                                      Huge thank you Fredo!
                                      I assume PB assembly problem is not at your end, is it?
                                      PS I said good-buy to windowizer 4+offset, thank you for pointer.
                                      PPS Some F3 for 'done and exit'- not this time?
                                        DarthKeidran
                                        I don't know if you're updating this to work with Sketchup 2021 (Running macOS Big Sur), but the only functions of this plugin I can use are "Classic Bezier Curve", "Polyline", "Catmull Spline", "F Spline", and "Courbette". From tutorials I can find, the other tools are supposed to bring up a Parameters dialogue box (or contextual menu based on what the Rubi Console says), which I can't get to appear no matter what I try.
                                        A good example of this is the action in this sketchup discussion: https://forums.sketchup.com/t/divide-existing-arc-into-equal-segments/74870/2
                                        I, more specifically, am trying to get an ellipse with equally sized segments as is demonstrated with your tool in this sketchup discussion: https://forums.sketchup.com/t/elliptical-array/17102/13
                                        If you have any suggestions to fix this, let me know please.
                                        DarthKeidran.
                                        • fredo6F Offline
                                          NEW RELEASE 2.2a - 22 Apr 21
                                          This release improves performance for selection contextual menu.
                                            R0bBot
                                            Is there any way to turn off the "double shift" feature? Im not sure the technical term but how the curve's controls changes when pressing shift twice. Im not sure how to remove that feature since its more of a nuisance than an addon
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 23 / 23
