    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      Cenosha
      Guys,
      With the LibFredo6 installed the problem is gone!
      • N Offline
        nocoloDean
        1st and only post.
        What an absolute ABORTION trying to get Bezierspline loaded into Sketchup 2014.
        Still haven't managed. It says it's loaded in Sketchucation's plugin manager, but it's not showing up in Prefs/Extensions, nor is it showing up in the program.
        What a mess. How hard can it be? Install > use.
          SketchUp version 2014 is old.
          Support from SketchUp only extends back to v2017.
          Some Extensions' authors allow backward compatible to v8, and reading this tool's guide it should be OK...
          An oddity in your error message suggests that it's been NOT installed properly.
          Usually the installation path is...
          C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
          So how did you install this toolset exactly ?
          How is it that SketchUp is trying to load it from here ?
          C:\Documents and Settings\user\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
          What is your current Windows OS ?
          Please fill in your Profile properly...
          It might well be incompatible ?
          Many users have this tool installed successfully in many SketchUp versions.
          Starting off "on an aggressive preemptive attack" might work in wing chung, but when your are asking for advice or help, then a more conciliatory tone often attracts a more sympathetic and helpful response... 😲
          • fredo6F Offline
            This is related with the non-ascii deficiencies of old Sketchup versions in some Windows configurations, and there is nothing that can be done (except to migrate to newer versions).
              LisaG
              Just downloaded LibFredo6 plugin for SketchUp Make V2017. The installation is not yet complete as under Preferences there is no "Extensions" listed. Not sure where else to find it!
              Thanks.
                Thanks.
                LibFredo6 appears in the Window menu and Bezier Spline Curves appears in the Draw menu. Did you look there?
                  Ahmed0007
                  Polyline segmentor is not working in sketchup 2020?
                    It worked for me just now in 2020.
                      Ahmed0007
                      [attachment=1:37qeug7g]<!-- ia1 -->Screenshot - 2_2_2020 , 3_59_21 PM.png<!-- ia1 -->[/attachment:37qeug7g]
                      Thanks for quick response.
                      but not working for me 😞
                      .Gif
                      • BoxB Offline
                        Do you have the most up to date Libfredo?
                        • fredo6F Offline
                          @Ahmed0007
                          Normally, when you convert to Segmentor, you should have a dialog box popping up (asking for number of segments).
                          Could you open the Ruby console while you invoke the convert.
                            Ahmed0007
                            yes.
                              Ahmed0007
                              @fredo6 said:
                              @Ahmed0007
                              Error: #<NameError: uninitialized constant BZ__Segmentor::Traductor>
                              C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/BZ__Segmentor.rb:72:in bz_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
                              C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
                              C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
                              Thanks for Respond
                              • fredo6F Offline
                                Can you check if in your plugin directory, subfolder bezierspline, you have a file called LibTraductor.rb.
                                If not, can you download beizerspline v2.1a.
                                Also, you should delete any file LibTraductor.rb which would be in the main Plugin directory.
                                  Ahmed0007
                                  Thanks Now it's working.
                                  • fredo6F Offline
                                    What was the problem?
                                      rv1974
                                      Fredo, two observations:
                                      'Close nicely' in Cubic Bezier is broken (the curve disappears, rarely the curve is kept but it exits without closing)
                                      Would it be possible to add some F(?) shortcut to 'Done end exit' across all sub-tools?
                                      Thank you
                                      P.S. BTW there's something in your closed curves that doesn't allow them to be used as paths for Profile Builder's assemblies. I'd have to explode or 'turn to arch' (another plugin) to overcome it. Is there possibility to do something on your end?
                                      • fredo6F Offline
                                        I am not able to reproduce the issues you mentioned.
                                        Could you open the Ruby console when you play with BezierSpline.
                                          rv1974
                                          Error: #<ArgumentError: wrong number of arguments (given 2, expected 1)>
                                          C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
                                          C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2049:in call_compute_curve' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:984:in draw'
                                            rv1974
                                            rror: #<ArgumentError: At least 2 points required to initialize curve>
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/curve.rbe:8:in initialize' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in new'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2097:in block in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in each_index'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:2037:in rebuild_entity_array_from_points_array' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/chain.rbe:1995:in offset!'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:2191:in offset_chain' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:219:in block in build_rails'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in each' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:215:in build_rails'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/pbapi/assembly.rbe:184:in draw' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1221:in build_fence'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1209:in block in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in each'
                                            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:1208:in build_along_path' c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/dm_profilebuilder3/assembly_dialog.rbe:126:in block in initialize'
                                            I could send a file if needed
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
