    Anyone Upgrading to 2020?
    82 Posts 24 Posters 19.1k Views 24 Watching
    • kenK Offline
      ken
      I printed out the LayOut Quick Reference Card. I noticed a series of menu icons in the Arrange column and other selections that I like. However, they don't appear in Sketchup. I was just wondering why these are not native plugins for Sketchup. Yes, I know they are different programs, but most of the plugins to me would be a welcome addition to Sketchup.
      Dave as for the plugin that I un-installed was Fabber. A plugin to make flat layouts of parts for a CNC machine. The plugin manager could not uninstall the plugin, so I went to Revo Uninstall program. I guess I didn't look hard enough to see exactly what it was unstalling. I got back most of the plugins, but in Layout, but I lost all the Layout templates.
      Going to be more careful.
      Thanks in Advance
        kaas
        @HornOxx you're missing the 'tag' - I like the font though ๐Ÿ˜‰
        Sichtbarkeitseigenschaftenkenzeichnungskontrollemarkierung
          ๐Ÿ’š ๐Ÿ’š
            I wanted to rename 'Layer' to 'Tig' rather than to 'Tag'... but there were not many supporters !
            ๐Ÿ˜‰
            Although 'Label' came nearer !
              What is it in the Arrange menu that you want to see in SketchUp? Most of the entries in the Arrange menu are based on the fact that LO is a 2D thing and there's a defined paper space. They wouldn't make much sense in a 3D space.
              Thanks in Advance
              So you didn't just uninstall Fabber. Uninstalling SketchUp and LayOut should remove any OEM LO templates but should not touch your custom LO templates unless you put them in the same directory as the OEM templates. Proper re-installation of SketchUp and LayOut should restore the OEM templates. If your custom LO templates are stored somewhere other than the normal location, you might need to point LO to look at them. The normal location for user-created templates is in User/App Data as below.
              I always copy my templates to the Templates folder for the version. I do this for both SketchUp and LayOut.
              • HornOxxH Offline
                HornOxx
                @dave r said:
                ...and probably even longer in German. ๐Ÿ˜„
                which is true โ— โ— ๐Ÿ˜„ ๐Ÿ˜„ and since we love to assemble new (unpronounceable even to us!) words from existing ones, we often create word monsters like the fun proposal below ๐Ÿ˜„ and btw - one more reason to only allow English installations on my and our machines...
                never trust a skinny cook
                • HornOxxH Offline
                  HornOxx
                  so great and wow - yourยดs is much much better ๐Ÿ˜› ๐Ÿ˜„ and the font, hmm, I couldnยดt resist playing with the clichรฉ here ๐Ÿ˜† ๐Ÿ˜†
                  • HornOxxH Offline
                    HornOxx
                    @tig said:
                    I wanted to rename 'Layer' to 'Tig' rather than to 'Tag'... but there were not many supporters !...
                    Tig, you got my vote !!!
                    • andybotA Offline
                      andybot
                      Exciting ๐Ÿ˜ Seems like SU is almost caught up to FormZ circa 2000 with the ability to hide objects. So glad I didn't renew my maintenance after 2017. Layers = Tags... I can't even.
                      Anyone want to guess which version of ACAD LT I'm still using? ๐Ÿ’š
                      • F Offline
                        faust07
                        Oder wie der Sachse sagt: "Dig, Dag und Digedag"... ๐Ÿ˜Ž
                        (Cover of the first issue of a comic magazine from the 1950s of the former GDR)
                        • david_hD Offline
                          david_h
                          IT seems that from the release email I just got that visibilty and nomenclature are about the only major changes. correct? One thing that I have asked for since v.3 (!) yes i have been around that long! is when working in a group or component with nested groups, etc is the abilty to hide or reveal only the next object up in the nested tree. Maybe the new outliner will allow for this. I dunno. I have never really gotten in to OL because of that so maybe this will help.
                          Gotta check it out.
                          D
                            DentalEZ
                            This is a plug that Iโ€™ve used for a while now that uses the word โ€œLayersโ€ called โ€œMake Name Groupโ€. Itโ€™s a great little plug in that does what it says, I can name it and place the items on any layer I have in my drawing. Not sure whoโ€™s the author but I hope they updated it.
                            My other question is with the outliner. I use this all the time to name all my object from the default name so I can find things easier. But as I found out the hard way V-Ray does not like (Nor Recommend) you have the outliner panels open when using their plug-ins. Saving a drawings can take a very long time when I forget to close it.
                            Same with Scatter it does not like the outliner or the components panel open. Has or will these issues be resolved with these vendors do we know?
                              The purely visual renaming of 'Layers' into 'Tags' should work seamlessly in most cases...
                              Obviously the specific plugin you referred to should consider replace 'Layer' with 'Tag' in its dialog - if the SketchUp version is >= 20 ...
                              But it should still work - 'below the hood' some checks might fail - like 'layer-name' if the default 'Layer0' has been renamed and accessed directly through the API...
                              We need feedback...
                                DentalEZ
                                Like most people I am to busy right now to do the upgrade for our company and i want to play with it before i do it there. I'll have to play with it over the weekend at home on my own version of SKU, but i'll let you know what happens.
                                I should be able to work with both 2019 and 2020, Right?
                                  I don't see a first question. If it's about the dialog box from the extension displaying the word "Layer", you might be able to edit the extension to say "Tag" but the author should do that. It really makes no difference, though, as long as you know.
                                  You don't put objects on layers. Layers, not Tags, get assigned to components and groups.
                                  I expect the vendors will need to deal with it.
                                    Glenn at home
                                    My 19 and 20 are working side by side.
                                      DentalEZ
                                      Guess I need to reword it, but yes the 1st question is about this plugin i am hoping that the author sees this responds about upgrading it. ๐Ÿ˜„
                                      Yes, I am hoping for a response from the community on these issues also. maybe someone has heard something or will.
                                      • kenK Offline
                                        ken
                                        I have the program Toolbars from Jim Foltz. The last two Sketchup updates, somehow I got it to work, however, with this version of Sketchup I haven't been able to get it to work.
                                        Below is an image of the four toolbars I created. I really would like someone to show or tell me how to get these options again.
                                        I think but not sure that Jim hasn't done any coding for some time. Making my own set of commands was very helpful.
                                          I don't have that extension from Jim and I don't believe it's available anymore so I can't help you. It's entirely possible it won't work in SU2020 but I can't test it to tell you.
                                          • jujuJ Offline
                                            juju
                                            Toolbar Editor will be able to do that, it's also listed as SU2020 compatible.
                                            • 2 / 5
