    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 457.2k Views 109 Watching
      glro
      dxf fileHi, i tried your plugin
      It worked for a OBJ file
      but not for this DXF file (joined)
      do you know why?
      • OxerO Offline
        Oxer
        Fantastic plugin but I work on mac, is there plan for macos support?
        Spanish Language File
        es.zip
          Khai
          ok. Cob (caligari trueSpace) is a little shakey, but don't worry, I'm likely to be the only person to be using that....
          OBJ so far is nice and solid, other than some scaling issues.. everythings coming in tiny 😉 but thats not a real issue...
          thanks again!
          • samuel_tS Offline
            samuel_t
            do you know why?
            Import fails because filename contains a '#' character.
            Substitute '#' with '_' and import will be succesful. 😉
            plateforme_202001051957_ca.dxf
            • samuel_tS Offline
              samuel_t
              @khai said:
              thanks again!
              You're welcome! 👍
                paladinjnr
                I have installed the plugin in my SketchUp 2018 , absolutely brilliant
                how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
                • kenK Offline
                  ken
                  I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
                  I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
                  Thanks for your help.
                  Ken
                  • samuel_tS Offline
                    samuel_t
                    @paladinjnr said:
                    Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
                    • samuel_tS Offline
                      samuel_t
                      Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
                        Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
                        If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
                        To fix it...
                        Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
                        Find the SketchUp installer's exe file - probably in your Downloads folder ?
                        Select the exe file's icon and right-click > context-menu > "Run as administrator"
                        When prompted choose "Repair".
                        Restart SketchUp and retry...
                        Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
                        So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
                        • Didier BurD Offline
                          Didier Bur
                          French translation file 😄
                          fr.zip
                          DB
                          • samuel_tS Offline
                            samuel_t
                            @paladinjnr said:
                            Hi Here is a link to the model as requested.
                            Filehorst wurde abgeschaltet! Filehorst has been shut down!
                            (filehorst.de)
                            Your model had absolute paths to textures. That's not supported by plugin.
                            I converted absolute paths to relative paths with a text editor. It's OK now:
                            Fixed DirectX Model
                            Fixed model is attached below:
                            Fixed DirectX Model
                            • samuel_tS Offline
                              samuel_t
                              Thank you! 😄
                                Danish9762
                                Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                                • jujuJ Offline
                                  juju
                                  @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                                  • samuel_tS Offline
                                    samuel_t
                                    @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                                    As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                                    • sketch3d.deS Offline
                                      sketch3d.de
                                      based on the MeshLab engine should maybe be mentioned.
                                        paladinjnr
                                        Will do
                                        (filehorst.de)
                                        Many Thanks Rae
                                        Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again .
                                        Once again many thanks for your help
                                        Keep up the good work
                                        Rae
                                        • samuel_tS Offline
                                          samuel_t
                                          It was already mentioned on GitHub page. And now, it's also mentioned on SketchUcation page.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 22
                                            • 23
                                            • 14 / 23
