    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.5k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      @oxer said:
      Fantastic plugin but I work on mac, is there plan for macos support?
      Good news: I'm working on a macOS version of plugin. 😛 Stay tuned!
        Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
        If this step fixes the issue then it's almost certain that SketchUp was not installed correctly !
        To fix it...
        Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed.
        Find the SketchUp installer's exe file - probably in your Downloads folder ?
        Select the exe file's icon and right-click > context-menu > "Run as administrator"
        When prompted choose "Repair".
        Restart SketchUp and retry...
        Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions...
        So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
        • Didier BurD Offline
          Didier Bur
          French translation file 😄
          fr.zip
          DB
          • samuel_tS Offline
            samuel_t
            @paladinjnr said:
            Hi Here is a link to the model as requested.
            Filehorst wurde abgeschaltet! Filehorst has been shut down!
            (filehorst.de)
            Your model had absolute paths to textures. That's not supported by plugin.
            I converted absolute paths to relative paths with a text editor. It's OK now:
            Fixed DirectX Model
            Fixed model is attached below:
            Fixed DirectX Model
            • samuel_tS Offline
              samuel_t
              Thank you! 😄
                Danish9762
                Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
                • jujuJ Offline
                  juju
                  @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
                  • samuel_tS Offline
                    samuel_t
                    @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
                    As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
                    • sketch3d.deS Offline
                      sketch3d.de
                      based on the MeshLab engine should maybe be mentioned.
                        paladinjnr
                        Will do
                        (filehorst.de)
                        Many Thanks Rae
                        Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again .
                        Once again many thanks for your help
                        Keep up the good work
                        Rae
                        • samuel_tS Offline
                          samuel_t
                          It was already mentioned on GitHub page. And now, it's also mentioned on SketchUcation page.
                            • OxerO Offline
                              Oxer
                              Thanks for the macos version!! 👍
                              SU2017 & macOS 10.13.6
                              I found some problems with the importing:
                              1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". I looked in the Console (I opened SketchUp via Terminal) and this is the error message:
                              assimp export; wrote output file; /Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae
                              Warning; uri contains white space, dom will convert them to %20 in output files!
                                uri=#Pinas Prueba.obj.obj
                              Error; daeStandardURIResolver;;resolveElement() - failed to resolve file;//localhost/Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae#Pinas Prueba.obj.obj
                              2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted'
                              I probed with different file format: obj, dae, fbx, blend and the same in all.
                              Perhaps it is a SketchUp error or perhaps is a problem with the scale, I don't know it, but I tried changing the 405 line in converter.rb:
                              dae_export.sub!('meter="1"', 'meter="0.01"')
                               to
                               dae_export.sub!('meter="1"', 'meter="1"')
                              And the Universal Importer inserted a flat component with two lines, see the image:
                              3. When you select a file (e.g. in the Finder) to import, the plugin copy all Finder files to the temp folder, why? and are this files delete automatically or is it necessary delete manually?
                              4. A minor detail, the texts 'Select a 3D Model' '3D Models |.3d;.3ds;.3mf;.ac;.ac3d;.acc;...' 'Select a Texture Atlas (Optional)' 'Images |.jpg;.png;*.bmp;||' do not appear in the importing windows.
                              Again, thanks for your efforts !!
                              • samuel_tS Offline
                                samuel_t
                                Thanks for detailed report! 😉
                                OK. I'm gonna fix that.
                                @oxer said:
                                2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted' [...]
                                Did you tried to import a completely different model? Could you please upload original "Pinas Prueba.obj + mtl + jpg" to a file hoster or here. This way I could debug it.
                                Model and associated files are copied to a temp folder to avoid invalid characters in path.
                                These temp files are automatically deleted at each import.
                                Strange. Maybe it's a SketchUp API bug on MacOS... 😕
                                • OxerO Offline
                                  Oxer
                                  Hi, I tried to import the same Pinas.obj file with QuadTools plugin and the importing works fine.
                                  Here the files:
                                  Pinas.obj, Pinas.mtl and texture
                                  • OxerO Offline
                                    Oxer
                                    It would be interest if other mac users test the file with other macos & SketchUp versions.
                                    • samuel_tS Offline
                                      samuel_t
                                      @oxer said:
                                      EDIT: I see that you have change the converter.rb to V2, I'll test this new version of the file.
                                      Super. Thanks for your help.
                                      • OxerO Offline
                                        Oxer
                                        I overwrited the converter.rb file and this is the result importing Pines.obj file:
                                        Two lines crossed in a vertical plane
                                        I made some testing with another models and formats, I used Blender to export the models to different formats.
                                        Original models created with Blender 2.82.
                                        THE RESULTS
                                        1. FBX format
                                        The importer works but there are some issues:
                                        A) The scale is multiplied by 100.
                                        B) It doesn't import the UVMap.
                                        C) With complex models the edges are displaced a little (see the image).
                                        2. OTHER FORMATS
                                        A) Cube 1 x 1 m, OBJ, PLY and DXF formats.
                                        B) Sphere 1 x 1 m, OBJ, PLY and DXF formats.
                                        EDIT: I see that you have changed the converter.rb to V2, I'll test this new version of the file.
                                        • OxerO Offline
                                          Oxer
                                          Thanks to you for your work!! 👍
                                          converter.rb V2 tested and it works fine now, fantastic!! 🎉
                                          Some issues only, the Z axis is flipped and the scale isn't correct, for the moment I probed with FBX format only.
                                          • OxerO Offline
                                            Oxer
                                            OBJ FORMAT
                                            The same issues as FBX format, scale (in this case is more small) an Z axis.
                                            PLY FORMAT
                                            The same issue with scale as OBJ format but the Z axis is correct. 👍
                                            DXF FORMAT
                                            The same issue with scale and axis as OBJ format , I think dxf doesn't support textures.
                                            • 22
                                            • 23
                                            • 2 / 23
