    • Log Masuk
    SubD examples and models
    Scheduled Pinned Kunci Moved SUbD
    renderpluginsextensions
    1.7k Kiriman 81 Posters 1.0m Lihat 79 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • BoxB Luar talian
      A little early morning SUbD insanity, took quite a while to subdivide. I wouldn't have done the whole thing if I had thought about it properly, just one segment and array. But this is all one piece with thickness and is a solid. Added the cutaway to see the inner structure.
      1 Reply Last reply Balas Petikan 0
      • pilouP Luar talian
        • BoxB Luar talian
          Just a bit of fun. For the absolute simplicity of it.
          • HornOxxH Luar talian
            HornOxx
            ... wunderbar - how does this inner glass shape look like (raw)? Somewhere I read of "extra thumbs up" - you know where it right now comes from...
            never trust a skinny cook
            • BoxB Luar talian
              Is this what you mean?
              I didn't save the model so I reproduced it.
              Note the outer layer I have thickened with JPP, not shown in the original image.
              • BoxB Luar talian
                This one shows how if you SUbD before JPP you get the sharp edges in the original render rather than the soft ones in the second model.
                  HornOxx
                  Thanks, now I got it 😄 - I first assumed to see 2 shapes above. To see your competent handling with geometry is impressive allways 👍 - for exampe that you started with a section plane to generate this first shape ...
                  • BoxB Luar talian
                    No, you are right, there are two shapes, the red and the blue. The blue one fits around the red one.
                    Here's the rest of it, hope that makes sense.
                      HornOxx
                      Yes 😄 - and I really enjoy this kind of geometry exercises ...
                      • V Luar talian
                        Vizan
                        @cotty said:
                        Hopefully the beginning of a looong and helpful topic...
                        How did you render with a square grid without triangles? It doesn’t work out for me((
                        • C Luar talian
                          Callegari_hr
                          In QuadFaceTools plugin there is Convert Triangulated Mesh to Quads, select two triangles of one quad and run that tool.
                          • cottyC Luar talian
                            cotty
                            You can use this tool with no visible hidden geometry for it.
                            my SketchUp gallery
                            • V Luar talian
                              Vizan
                              [attachment=4:3726vs77]<!-- ia4 -->quads.jpg<!-- ia4 -->[/attachment:3726vs77]
                              After the Subd plugin, my model looks like on a screenshot. But when rendering a polygon mesh in Vray, I see triangles. I noticed that if the dividing line of the square is hidden, then it is not visible on the visualization.
                              It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
                              • BoxB Luar talian
                                This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
                                Render the shape then export the edges as a transparent background .png and combine the two.
                                Hera's a very simple example.
                                • V Luar talian
                                  Vizan
                                  Thanks! This is a good idea)))
                                  • thomthomT Luar talian
                                    I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
                                      • B Luar talian
                                        bahri06
                                        My first post here... still WIP Honda CB 175
                                        Thanks to Pilou for all your tutorial on you tube channel
                                          cotty
                                          great model and impressive first post...
                                          my SketchUp gallery
                                            Cool motor bike! 😎
                                            (Ps these above videos are not my own videos, alas! 😉
                                            • 82
                                            • 83
                                            • 4 / 83
