    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 709.9k Views 121 Watching
    • designerbursaD Offline
      designerbursa
      @fredo6 said:
      @designerbursa said:
      solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
      I think it should be a different plugin, because the request does apply to objects which are non-solid.
      By the way, there may exist already some plugins giving the dimension of the bounding box, which I assume is what you want.
      PS: indeed, there is no problem to adding this feature to Solid Volume, but that would be restrictive.
      This is exactly what I'm looking for "element stat" 😄
      Sorry, now I noticed.
      Thanks FREDO! ..
        designerbursa
        This is exactly what I'm looking for "ElementStats" 😄
        Thanks FREDO! ..
          Loiseau
          Am intéres to have the extention "VisuHole" from Fredo6. You thing is possible ❓
            @loiseau said:
            You need to download the appropriate RBZ files for that extension by Fredo, and his support Lib, from the SketchUcation PluginStore.
            https://sketchucation.com/pluginstore?pln=VisuHole
            https://sketchucation.com/pluginstore?pln=LibFredo6
            Then install the two RBZ files - using the SketchUp Extension Manager > Install [red] button...
            Then restart SketchUp to sync everything.
            Then use the tool as explained in the usage notes...
            Vous devez télécharger les fichiers RBZ appropriés pour cette extension de Fredo, et son support Lib, à partir du SketchUcation PluginStore.
            Installez ensuite les deux fichiers RBZ - à l'aide du bouton SketchUp Extension Manager> Installer [rouge] ...
            Ensuite, redémarrez SketchUp pour tout synchroniser.
            Ensuite, utilisez l'outil comme expliqué dans les notes d'utilisation ...
            • fredo6F Offline
              NEW RELEASE: FredoTools v3.5a - 12 Sep 19
              Requirement: LibFredo6 v9.1b or above
              FredoTools 3.5a introduces the ColorBySlope tool, which create a color mapping for a terrain mesh based on the slope of its faces.
              See FredoTools plugin home page for Download.
              See also main post of this thread for User Discussion.
              • OxerO Offline
                Oxer
                New Spanish Language file (added Color by Slope).
                FredoTools_ES.zip
                • fredo6F Offline
                  Thank you. it will go into the next release soon (along with a new tool).
                    dedmin
                    Original post here - https://sketchucation.com/forums/viewtopic.php?f=80&t=71619
                    • fredo6F Offline
                      NEW RELEASE: FredoTools v3.6a - 16 Oct 19
                      Requirement: LibFredo6 v9.2a or above
                      FredoTools 3.6a is a major release which introduces:
                      • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
                      • ColorPaint tool, which is a configurable Color Selector.
                      • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
                      • V Offline
                        volker72
                        i have a question for you.
                        I calculate thermal bridges (building physics). I place the edges on different layers (edges = thermal bridges).
                        A report that outputs the length of the edges according to layers, like the ReportLabelArea does with areas, would be great.
                        Is this easy to do?
                        I could imagine that other users could also use this ReportLabelLenght.
                        You are doing a great job, thank you very much and many greetings
                        Volker
                        • fredo6F Offline
                          NEW RELEASE: FredoTools v3.7a - 02 Nov 19
                          Requirement: LibFredo6 v9.3a or above
                          FredoTools 3.6a is a major release which introduces evolutions in:
                          • ColorByAltitude, cosmetic adjustments and bug fixing.
                          • ColorPaint, support of transparency and edition of colors.
                          • ReportLabelArea, interactive flow and other cosmetic adjustments
                          • fredo6F Offline
                            NEW RELEASE: FredoTools v3.8a - 18 Nov 19
                            Requirement: LibFredo6 v9.4a or above
                            FredoTools 3.8a is a major release which introduces:
                            • ColorFlatMode
                            • bug fixing and various cosmetic adjustments
                              pbs1962
                              Looking for help with curvishear..
                              Just started working with this awesome plugin, but I must be doing something wrong.
                              When I run this to build a ramp (two concentric semicircles) the model appears correct but it remains flat...I've tried various views, changing the height in case it was a scale problem...but no luck...I can post a video of my steps if that helps.
                              Does anyone have a fix or suggestions for where to get more info?
                                How about posting your SKP file with the ramp ready to run Curvishear?
                                  pbs1962
                                  Here's the skp file.
                                  ramp.skp
                                    This is what I see when I open your file. The geometry sort of looks like you're looking down on the ramp but its oriented in the vertical red/blue plane. The extension is extending up in the blue direction as it's supposed to do.
                                    If you want the ramp shape, lay the C-shape down on the ground plane as I've done on the right.
                                    FWIW, if you are having a difficult time keeping track of which way is up in SketchUp, you can either edit the style to include sky and horizon or choose a different style that already has it.
                                      dangeruss03
                                      I Just download it, i can't use Curvishear properly. i try to make ramp for my basement but it seems like something wrong. i don't know what happen and what to do. please help if anybody knew something
                                      https://drive.google.com/open?id=10pUU20bQVzGIdDTC4R4sciJ__mzsUNbB
                                        Your image doesn't show. Please attach the SKP file so we can see what you are trying to do and exactly how you have it set up.
                                          dangeruss03
                                          Ramp_Trial.skpthis is the file thanks
                                            I'm not sure what you are doing wrong. I do see that all of your curves are exploded to their individual segments. I welded the curves back together and ran Curvishear. It worked fine for me.
                                            Maybe you can review the usage instructions here and try again. It would also be helpful if you outline the exact steps you are using as you are setting up for and running Curvishear.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
