    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 836.5k Views 121 Watching
    • OxerO
      Oxer
      New Spanish Language file (added Color by Slope).
      FredoTools_ES.zip
      • fredo6F
        Thank you. it will go into the next release soon (along with a new tool).
          dedmin
          Original post here - https://sketchucation.com/forums/viewtopic.php?f=80&t=71619
          • fredo6F
            NEW RELEASE: FredoTools v3.6a - 16 Oct 19
            Requirement: LibFredo6 v9.2a or above
            FredoTools 3.6a is a major release which introduces:
            • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
            • ColorPaint tool, which is a configurable Color Selector.
            • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
            See FredoTools plugin home page for Download.
            See also main post of this thread for User Discussion.
            • V
              volker72
              i have a question for you.
              I calculate thermal bridges (building physics). I place the edges on different layers (edges = thermal bridges).
              A report that outputs the length of the edges according to layers, like the ReportLabelArea does with areas, would be great.
              Is this easy to do?
              I could imagine that other users could also use this ReportLabelLenght.
              You are doing a great job, thank you very much and many greetings
              Volker
              • fredo6F
                NEW RELEASE: FredoTools v3.7a - 02 Nov 19
                Requirement: LibFredo6 v9.3a or above
                FredoTools 3.6a is a major release which introduces evolutions in:
                • ColorByAltitude, cosmetic adjustments and bug fixing.
                • ColorPaint, support of transparency and edition of colors.
                • ReportLabelArea, interactive flow and other cosmetic adjustments
                • fredo6F
                  NEW RELEASE: FredoTools v3.8a - 18 Nov 19
                  Requirement: LibFredo6 v9.4a or above
                  FredoTools 3.8a is a major release which introduces:
                  • ColorFlatMode
                  • bug fixing and various cosmetic adjustments
                  • P
                    pbs1962
                    Looking for help with curvishear..
                    Just started working with this awesome plugin, but I must be doing something wrong.
                    When I run this to build a ramp (two concentric semicircles) the model appears correct but it remains flat...I've tried various views, changing the height in case it was a scale problem...but no luck...I can post a video of my steps if that helps.
                    Does anyone have a fix or suggestions for where to get more info?
                      How about posting your SKP file with the ramp ready to run Curvishear?
                      • P
                        pbs1962
                        Here's the skp file.
                        ramp.skp
                          This is what I see when I open your file. The geometry sort of looks like you're looking down on the ramp but its oriented in the vertical red/blue plane. The extension is extending up in the blue direction as it's supposed to do.
                          If you want the ramp shape, lay the C-shape down on the ground plane as I've done on the right.
                          FWIW, if you are having a difficult time keeping track of which way is up in SketchUp, you can either edit the style to include sky and horizon or choose a different style that already has it.
                            dangeruss03
                            I Just download it, i can't use Curvishear properly. i try to make ramp for my basement but it seems like something wrong. i don't know what happen and what to do. please help if anybody knew something
                            https://drive.google.com/open?id=10pUU20bQVzGIdDTC4R4sciJ__mzsUNbB
                              Your image doesn't show. Please attach the SKP file so we can see what you are trying to do and exactly how you have it set up.
                                dangeruss03
                                Ramp_Trial.skpthis is the file thanks
                                  I'm not sure what you are doing wrong. I do see that all of your curves are exploded to their individual segments. I welded the curves back together and ran Curvishear. It worked fine for me.
                                  Maybe you can review the usage instructions here and try again. It would also be helpful if you outline the exact steps you are using as you are setting up for and running Curvishear.
                                    dangeruss03
                                    [attachment=0:2rb4kko1]<!-- ia0 -->Screenshot - 12_1_2019 , 8_07_53 AM.png<!-- ia0 -->[/attachment:2rb4kko1]
                                    But how to weld all the lines, i tried to use super weld plugin and it work just like that
                                      I used TIG-Weld to do it but I only welded the curves. I did not weld the entire perimeter. Why are the curves exploded in the first place? Maybe you should redraw them so they aren't exploded.
                                      • O
                                        oo7wazzy
                                        HI Fredo
                                        I downloaded the LibFredo6 package for Sketchup 19 on MAC. It is loaded and installed, but I can't see any of the tools. It is showing in the Window drop down menu but nowhere else that I can see. Have I done something wrong in the installation ? In the extension manager it is Enabled. Any help would be appreciated.
                                          Have you quit and restarted SketchUp after installing?
                                          Fredo Tools shows in the Tools menu. Do you see that?
                                            rv1974
                                            Many years I dream of ability to explicitly move the end vertex, run CurviShear and get desired slope (it means curve as required condition has to be ditched).
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 23
                                            • 24
                                            • 18 / 24
