    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.0k Views 122 Watching
    • designerbursaD
      designerbursa
      Can you add a command that shows the external dimensions of the solid part?
      • designerbursaD
        designerbursa
        solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
        • fredo6F
          I think it should be a different plugin, because the request does apply to objects which are non-solid.
          By the way, there may exist already some plugins giving the dimension of the bounding box, which I assume is what you want.
          PS: indeed, there is no problem to adding this feature to Solid Volume, but that would be restrictive.
          • designerbursaD
            designerbursa
            This is exactly what I'm looking for "element stat" 😄
            Sorry, now I noticed.
            Thanks FREDO! ..
            • designerbursaD
              designerbursa
              This is exactly what I'm looking for "ElementStats" 😄
              Thanks FREDO! ..
              • L
                Loiseau
                Am intéres to have the extention "VisuHole" from Fredo6. You thing is possible ❓
                  @loiseau said:
                  You need to download the appropriate RBZ files for that extension by Fredo, and his support Lib, from the SketchUcation PluginStore.
                  https://sketchucation.com/pluginstore?pln=VisuHole
                  https://sketchucation.com/pluginstore?pln=LibFredo6
                  Then install the two RBZ files - using the SketchUp Extension Manager > Install [red] button...
                  Then restart SketchUp to sync everything.
                  Then use the tool as explained in the usage notes...
                  Vous devez télécharger les fichiers RBZ appropriés pour cette extension de Fredo, et son support Lib, à partir du SketchUcation PluginStore.
                  Installez ensuite les deux fichiers RBZ - à l'aide du bouton SketchUp Extension Manager> Installer [rouge] ...
                  Ensuite, redémarrez SketchUp pour tout synchroniser.
                  Ensuite, utilisez l'outil comme expliqué dans les notes d'utilisation ...
                  • fredo6F
                    NEW RELEASE: FredoTools v3.5a - 12 Sep 19
                    Requirement: LibFredo6 v9.1b or above
                    FredoTools 3.5a introduces the ColorBySlope tool, which create a color mapping for a terrain mesh based on the slope of its faces.
                    See FredoTools plugin home page for Download.
                    See also main post of this thread for User Discussion.
                    • OxerO
                      Oxer
                      New Spanish Language file (added Color by Slope).
                      FredoTools_ES.zip
                      • fredo6F
                        Thank you. it will go into the next release soon (along with a new tool).
                          dedmin
                          Original post here - https://sketchucation.com/forums/viewtopic.php?f=80&t=71619
                          • fredo6F
                            NEW RELEASE: FredoTools v3.6a - 16 Oct 19
                            Requirement: LibFredo6 v9.2a or above
                            FredoTools 3.6a is a major release which introduces:
                            • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
                            • ColorPaint tool, which is a configurable Color Selector.
                            • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
                            • V
                              volker72
                              i have a question for you.
                              I calculate thermal bridges (building physics). I place the edges on different layers (edges = thermal bridges).
                              A report that outputs the length of the edges according to layers, like the ReportLabelArea does with areas, would be great.
                              Is this easy to do?
                              I could imagine that other users could also use this ReportLabelLenght.
                              You are doing a great job, thank you very much and many greetings
                              Volker
                              • fredo6F
                                NEW RELEASE: FredoTools v3.7a - 02 Nov 19
                                Requirement: LibFredo6 v9.3a or above
                                FredoTools 3.6a is a major release which introduces evolutions in:
                                • ColorByAltitude, cosmetic adjustments and bug fixing.
                                • ColorPaint, support of transparency and edition of colors.
                                • ReportLabelArea, interactive flow and other cosmetic adjustments
                                • fredo6F
                                  NEW RELEASE: FredoTools v3.8a - 18 Nov 19
                                  Requirement: LibFredo6 v9.4a or above
                                  FredoTools 3.8a is a major release which introduces:
                                  • ColorFlatMode
                                  • bug fixing and various cosmetic adjustments
                                  • P
                                    pbs1962
                                    Looking for help with curvishear..
                                    Just started working with this awesome plugin, but I must be doing something wrong.
                                    When I run this to build a ramp (two concentric semicircles) the model appears correct but it remains flat...I've tried various views, changing the height in case it was a scale problem...but no luck...I can post a video of my steps if that helps.
                                    Does anyone have a fix or suggestions for where to get more info?
                                      How about posting your SKP file with the ramp ready to run Curvishear?
                                      • P
                                        pbs1962
                                        Here's the skp file.
                                        ramp.skp
                                          This is what I see when I open your file. The geometry sort of looks like you're looking down on the ramp but its oriented in the vertical red/blue plane. The extension is extending up in the blue direction as it's supposed to do.
                                          If you want the ramp shape, lay the C-shape down on the ground plane as I've done on the right.
                                          FWIW, if you are having a difficult time keeping track of which way is up in SketchUp, you can either edit the style to include sky and horizon or choose a different style that already has it.
                                            dangeruss03
                                            I Just download it, i can't use Curvishear properly. i try to make ramp for my basement but it seems like something wrong. i don't know what happen and what to do. please help if anybody knew something
                                            https://drive.google.com/open?id=10pUU20bQVzGIdDTC4R4sciJ__mzsUNbB
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 23
                                            • 24
                                            • 17 / 24
