    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.0k Views 122 Watching
      Have you restarted SketchUp following the installations ?
      That will ensure everything gets properly synced...
      Also, are you looking in the right places ?
      Many of Fredo's tools have their own Toolbar.
      And most of them also appear under SketchUp's "Tools" menu - in large submenus - "Fredo Tools" and "Fredo6 Collection"...
        ardesigninterior
        Thanks for the Plugin by Fredo6. it is awesome to help my works.
        • designerbursaD
          designerbursa
          Can you add a command that shows the external dimensions of the solid part?
          • designerbursaD
            designerbursa
            solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
            • fredo6F
              I think it should be a different plugin, because the request does apply to objects which are non-solid.
              By the way, there may exist already some plugins giving the dimension of the bounding box, which I assume is what you want.
              PS: indeed, there is no problem to adding this feature to Solid Volume, but that would be restrictive.
              • designerbursaD
                designerbursa
                This is exactly what I'm looking for "element stat" 😄
                Sorry, now I noticed.
                Thanks FREDO! ..
                • designerbursaD
                  designerbursa
                  This is exactly what I'm looking for "ElementStats" 😄
                  Thanks FREDO! ..
                  • L
                    Loiseau
                    Am intéres to have the extention "VisuHole" from Fredo6. You thing is possible ❓
                      @loiseau said:
                      You need to download the appropriate RBZ files for that extension by Fredo, and his support Lib, from the SketchUcation PluginStore.
                      https://sketchucation.com/pluginstore?pln=VisuHole
                      https://sketchucation.com/pluginstore?pln=LibFredo6
                      Then install the two RBZ files - using the SketchUp Extension Manager > Install [red] button...
                      Then restart SketchUp to sync everything.
                      Then use the tool as explained in the usage notes...
                      Vous devez télécharger les fichiers RBZ appropriés pour cette extension de Fredo, et son support Lib, à partir du SketchUcation PluginStore.
                      Installez ensuite les deux fichiers RBZ - à l'aide du bouton SketchUp Extension Manager> Installer [rouge] ...
                      Ensuite, redémarrez SketchUp pour tout synchroniser.
                      Ensuite, utilisez l'outil comme expliqué dans les notes d'utilisation ...
                      • fredo6F
                        NEW RELEASE: FredoTools v3.5a - 12 Sep 19
                        Requirement: LibFredo6 v9.1b or above
                        FredoTools 3.5a introduces the ColorBySlope tool, which create a color mapping for a terrain mesh based on the slope of its faces.
                        See FredoTools plugin home page for Download.
                        See also main post of this thread for User Discussion.
                        • OxerO
                          Oxer
                          New Spanish Language file (added Color by Slope).
                          FredoTools_ES.zip
                          • fredo6F
                            Thank you. it will go into the next release soon (along with a new tool).
                              dedmin
                              Original post here - https://sketchucation.com/forums/viewtopic.php?f=80&t=71619
                              • fredo6F
                                NEW RELEASE: FredoTools v3.6a - 16 Oct 19
                                Requirement: LibFredo6 v9.2a or above
                                FredoTools 3.6a is a major release which introduces:
                                • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
                                • ColorPaint tool, which is a configurable Color Selector.
                                • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
                                • V
                                  volker72
                                  i have a question for you.
                                  I calculate thermal bridges (building physics). I place the edges on different layers (edges = thermal bridges).
                                  A report that outputs the length of the edges according to layers, like the ReportLabelArea does with areas, would be great.
                                  Is this easy to do?
                                  I could imagine that other users could also use this ReportLabelLenght.
                                  You are doing a great job, thank you very much and many greetings
                                  Volker
                                  • fredo6F
                                    NEW RELEASE: FredoTools v3.7a - 02 Nov 19
                                    Requirement: LibFredo6 v9.3a or above
                                    FredoTools 3.6a is a major release which introduces evolutions in:
                                    • ColorByAltitude, cosmetic adjustments and bug fixing.
                                    • ColorPaint, support of transparency and edition of colors.
                                    • ReportLabelArea, interactive flow and other cosmetic adjustments
                                    • fredo6F
                                      NEW RELEASE: FredoTools v3.8a - 18 Nov 19
                                      Requirement: LibFredo6 v9.4a or above
                                      FredoTools 3.8a is a major release which introduces:
                                      • ColorFlatMode
                                      • bug fixing and various cosmetic adjustments
                                      • P
                                        pbs1962
                                        Looking for help with curvishear..
                                        Just started working with this awesome plugin, but I must be doing something wrong.
                                        When I run this to build a ramp (two concentric semicircles) the model appears correct but it remains flat...I've tried various views, changing the height in case it was a scale problem...but no luck...I can post a video of my steps if that helps.
                                        Does anyone have a fix or suggestions for where to get more info?
                                          How about posting your SKP file with the ramp ready to run Curvishear?
                                          • P
                                            pbs1962
                                            Here's the skp file.
                                            ramp.skp
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 23
                                            • 24
                                            • 17 / 24
