    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 917.0k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v3.3b - 14 Mar 19
      Requirement: LibFredo6 v8.6i or above
      FredoTools 3.3b fixes bugs in FredoTools::ReportLabelArea for CSV export, as signaled by masloprojekt.
      See FredoTools plugin home page for Download.
      See also main post of this thread for User Discussion.
      • fredo6F
        NEW RELEASE: FredoTools v3.3c - 24 Mar 19
        FredoTools 3.3c fixes bugs in FredoTools::EdgeInspector preneting it to work in SU2019.
        • fredo6F
          NEW RELEASE: FredoTools v3.4a - 12 Apr 19
          FredoTools 3.4a improves performance when the Outliner is open. This may be important for ThruPaint, when you paint a complex model.
            miguelgba
            Hi Fredo, Your Plugin is simply one of the best and most usefull of Sketchup. But I have a request, the ReportLabelArea (report) is not exported in a CSV format that the Layout of Sketchup can read, every time I tried to copy and paste the .csv into layout it give me a blank table. I'm trying to use your plugin to make a quantity takeoff and insert the table on Layout, if this turns into possible and practical will be a wonder to my tries to use de Layout for construction drawings.
            Thanks in advance
              Open the CSV file in a spreadsheet program such as Excel and save it as XLSX or make it an RTF file. Both of these file types are supported by LayOut.
              Additionally, you shouldn't copy and paste files into LayOut. The reference that is created with copy and paste links to a temporary file location which will be removed when the operating system does its normal cleanup. You should use File>Insert and insert the file from its real location.
              • W
                Wise Vast
                I had installed libfredo v8.8a. And then, I install the fredotools v3.4a. I cannot find any tools, although extension manager shows that fredotools had been installed.
                  Have you restarted SketchUp following the installations ?
                  That will ensure everything gets properly synced...
                  Also, are you looking in the right places ?
                  Many of Fredo's tools have their own Toolbar.
                  And most of them also appear under SketchUp's "Tools" menu - in large submenus - "Fredo Tools" and "Fredo6 Collection"...
                    ardesigninterior
                    Thanks for the Plugin by Fredo6. it is awesome to help my works.
                    • designerbursaD
                      designerbursa
                      Can you add a command that shows the external dimensions of the solid part?
                      • designerbursaD
                        designerbursa
                        solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
                        • fredo6F
                          I think it should be a different plugin, because the request does apply to objects which are non-solid.
                          By the way, there may exist already some plugins giving the dimension of the bounding box, which I assume is what you want.
                          PS: indeed, there is no problem to adding this feature to Solid Volume, but that would be restrictive.
                          • designerbursaD
                            designerbursa
                            This is exactly what I'm looking for "element stat" 😄
                            Sorry, now I noticed.
                            Thanks FREDO! ..
                            • designerbursaD
                              designerbursa
                              This is exactly what I'm looking for "ElementStats" 😄
                              Thanks FREDO! ..
                              • L
                                Loiseau
                                Am intéres to have the extention "VisuHole" from Fredo6. You thing is possible ❓
                                  @loiseau said:
                                  You need to download the appropriate RBZ files for that extension by Fredo, and his support Lib, from the SketchUcation PluginStore.
                                  https://sketchucation.com/pluginstore?pln=VisuHole
                                  https://sketchucation.com/pluginstore?pln=LibFredo6
                                  Then install the two RBZ files - using the SketchUp Extension Manager > Install [red] button...
                                  Then restart SketchUp to sync everything.
                                  Then use the tool as explained in the usage notes...
                                  Vous devez télécharger les fichiers RBZ appropriés pour cette extension de Fredo, et son support Lib, à partir du SketchUcation PluginStore.
                                  Installez ensuite les deux fichiers RBZ - à l'aide du bouton SketchUp Extension Manager> Installer [rouge] ...
                                  Ensuite, redémarrez SketchUp pour tout synchroniser.
                                  Ensuite, utilisez l'outil comme expliqué dans les notes d'utilisation ...
                                  • fredo6F
                                    NEW RELEASE: FredoTools v3.5a - 12 Sep 19
                                    Requirement: LibFredo6 v9.1b or above
                                    FredoTools 3.5a introduces the ColorBySlope tool, which create a color mapping for a terrain mesh based on the slope of its faces.
                                    • OxerO
                                      Oxer
                                      New Spanish Language file (added Color by Slope).
                                      FredoTools_ES.zip
                                      • fredo6F
                                        Thank you. it will go into the next release soon (along with a new tool).
                                          dedmin
                                          Original post here - https://sketchucation.com/forums/viewtopic.php?f=80&t=71619
                                          • fredo6F
                                            NEW RELEASE: FredoTools v3.6a - 16 Oct 19
                                            Requirement: LibFredo6 v9.2a or above
                                            FredoTools 3.6a is a major release which introduces:
                                            • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
                                            • ColorPaint tool, which is a configurable Color Selector.
                                            • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 23
                                            • 24
                                            • 17 / 24
