    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      You should always look in the Plugin Store for the latest versions of almost all toolsets...
      See here...
      https://sketchucation.com/pluginstore?pln=ToolsOnSurface
      Also remember to download and install the latest LibFredo...
      https://sketchucation.com/pluginstore?pln=LibFredo6
      After the installations, restart SketchUp to ensure everything gets synced...
        Caleb_Stanley
        I am having issues upon the startup of SketchUp with ToolsOnSurface, I believe it may have something to do with the latest update but I am not sure. Below is the text of the error code upon starting.
        ToolsOn Surface 2.4a: Error starting up plugin (creating menus and icons) invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]
        c:/...'sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in'rescue in block in effective_load_part2'
        Please Help. Thank you.
          I'm sure that Fredo will respond with more details...
          However, the error message you posted is incomplete - in fact it omits the vital parts.
          Can you re-post the FULL message [including your ../users/user_name/ etc]...
          Also please confirm that you have the latest LibFredo RBZ installed...
          • fredo6F Offline
            Thanks, TIG, for your invaluable help.
            I already answer in the other thread where the problem was also posted.
              rv1974
              Fredo could erroneous Arc behavior be fixed please?
              • jgbJ Offline
                jgb
                I get that a lot too. Mentioned it numerous times in the past 8+ years and no improvement. Sometimes it works correctly, but I cannot define what works and what doesn't.
                jgb
                  rv1974
                  Yep it's present from day 1. The 'workaround' is not to start/end from the outer edges. Just a microscopic offset, then manually extend the arc Kinda helps in many (but not 100%) cases
                  • fredo6F Offline
                    This is a fundamental flaw in the algorithm when you start from sharp borders.
                    So, not something simple to correct, versus revisiting seriously the algorithm itself.
                    • jgbJ Offline
                      jgb
                      What do you mean "sharp borders"?
                      jgb
                      • fredo6F Offline
                        Usual cases where you TOS algorithm has problem are those where the surface is a close shape and when you start from an edge which has a sharp angle.
                          mrswissmaster
                          Is it possible to place image on curved surface?
                            Native tools can do that or you could look at Fredo's Thru Paint.
                              keitheseymour
                              I'm running Sketchup 2015, and have installed Fredo6: Tools On Surface v2.4a. I can see it installed in my extensions list, but it doesn't show up in the menus to use. Any ideas? Thanks in advance.
                              • BoxB Offline
                                Did you install the Fredo Library that is required.
                                  Fredo's tools appear under the Tools menu, did you look there ?
                                    stebbins
                                    Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
                                    Thanks in advance,
                                    showing diagonal lines.
                                    • fredo6F Offline
                                      I would need to have the model, and also to understand how you used the OffsetOnSurface tool.
                                      • jgbJ Offline
                                        jgb
                                        I take it that those roofs have the center raised a bit. The diagonal lines are the "hip" bends. Quite normal. You need to make then "soft" or hidden.
                                        Three ways, either select the line and change its attribute in Entity Attributes; or
                                        with the erase tool, press and hold "CTRL" and sweep over the line.
                                        The third way is to create a layer and move those lines into it. Make that layer visible or invisible as needed.
                                        jgb
                                          j40
                                          Hi, great plugin! πŸ‘ I have an issue on SketchUp 2020 version (Mac), it's not appearing in none of menus.
                                          on SU 2018 it's working perfectly though.
                                          Any idea why it happens?
                                          best regards
                                          Top3D Studio
                                            It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
