    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
    • fredo6F Offline
      That's relatively difficult to make a Draw Bezier on Surface.
      I think in the case of your model, the best would be to proceed with shaped cylinder and then intersect the torus.
        reza1813
        Dear Fredo,
        Thank you for your prompt reply to my question. Wow, I thought that adding curve line(Bezier) on Tool on surface plugin will be possible in SketchUp as MESH interface because this is just an example in order to show you what I mean and you obviously know that we usually need to add curve line on the curved surface(Like other Software: Rhino and...). Indeed, I ever use Drap(Feature in the SketchUp) or Flowify plugin(Anders L.) in order to put a pattern on my curved surface but most of the time it doesn't work properly or It does not look like what I am looking for.
        All in all, I hope so in the near future, we have this feature on SketchUp. Thanks in advance.
        Tools On Surface
        Tools On Surface 02
        Yours sincerely,
        Hamidreza
        • ChumleyC Offline
          Chumley
          Hi there.
          Do you have a link to download the Tools on Surface plugin? I tried on the main page but link doesn't work.
          Thanks.
            You should always look in the Plugin Store for the latest versions of almost all toolsets...
            See here...
            https://sketchucation.com/pluginstore?pln=ToolsOnSurface
            Also remember to download and install the latest LibFredo...
            https://sketchucation.com/pluginstore?pln=LibFredo6
            After the installations, restart SketchUp to ensure everything gets synced...
              Caleb_Stanley
              I am having issues upon the startup of SketchUp with ToolsOnSurface, I believe it may have something to do with the latest update but I am not sure. Below is the text of the error code upon starting.
              ToolsOn Surface 2.4a: Error starting up plugin (creating menus and icons) invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]
              c:/...'sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in'rescue in block in effective_load_part2'
              Please Help. Thank you.
                I'm sure that Fredo will respond with more details...
                However, the error message you posted is incomplete - in fact it omits the vital parts.
                Can you re-post the FULL message [including your ../users/user_name/ etc]...
                Also please confirm that you have the latest LibFredo RBZ installed...
                • fredo6F Offline
                  Thanks, TIG, for your invaluable help.
                  I already answer in the other thread where the problem was also posted.
                    rv1974
                    Fredo could erroneous Arc behavior be fixed please?
                    • jgbJ Offline
                      jgb
                      I get that a lot too. Mentioned it numerous times in the past 8+ years and no improvement. Sometimes it works correctly, but I cannot define what works and what doesn't.
                      jgb
                        rv1974
                        Yep it's present from day 1. The 'workaround' is not to start/end from the outer edges. Just a microscopic offset, then manually extend the arc Kinda helps in many (but not 100%) cases
                        • fredo6F Offline
                          This is a fundamental flaw in the algorithm when you start from sharp borders.
                          So, not something simple to correct, versus revisiting seriously the algorithm itself.
                          • jgbJ Offline
                            jgb
                            What do you mean "sharp borders"?
                            jgb
                            • fredo6F Offline
                              Usual cases where you TOS algorithm has problem are those where the surface is a close shape and when you start from an edge which has a sharp angle.
                                mrswissmaster
                                Is it possible to place image on curved surface?
                                  Native tools can do that or you could look at Fredo's Thru Paint.
                                    keitheseymour
                                    I'm running Sketchup 2015, and have installed Fredo6: Tools On Surface v2.4a. I can see it installed in my extensions list, but it doesn't show up in the menus to use. Any ideas? Thanks in advance.
                                    • BoxB Offline
                                      Did you install the Fredo Library that is required.
                                        Fredo's tools appear under the Tools menu, did you look there ?
                                          stebbins
                                          Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
                                          Thanks in advance,
                                          showing diagonal lines.
                                          • fredo6F Offline
                                            I would need to have the model, and also to understand how you used the OffsetOnSurface tool.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
