    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.9k Views 12 Watching
    • BoxB Offline
      I know nothing about coding so I gave you a quote from Tig when the issue came up before.
      I just wanted to point out that your Plugin's toolbar was always popping up whether open or closed previously. I've just installed and tested your Slice plugin and it doesn't do it, so that suggest there is a difference in the code.
      I don't mean this as a criticism, simply a bug fix.
      • hdpvH Offline
        hdpv
        no difference in the code.I use Sketchup 2014,win64
        this bug fix is no expect. 😄
        Suforyou
        http://www.sketchupforyou.com
        • HornOxxH Offline
          HornOxx
          hi HDPV,
          first thank you for this great tool!
          I have used it for some time and it worked great so far, but since a few days I get the message
          that I should do an update as soon as I use the plugin (please see screenshot). This is the only plugin that causes this error by now.
          I run SketchUp 2013 Pro and SketchUp 8 Free on Win7 64bit. I get this message on both versions.
          any help is appreciated - thank you
          never trust a skinny cook
          • hdpvH Offline
            hdpv
            Sorry HornOxx, This trial is expired.
            Suforyou
              Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
              • HornOxxH Offline
                HornOxx
                Sorry - how embarrassing to me!! 😉 I didn´t even notice that this is a purchase-plugin.
                Regards to All
                • hdpvH Offline
                  hdpv
                  Thanks Dave!
                  Suforyou
                  • BerserkB Offline
                    Berserk
                    This is incredible
                      pipinek
                      To the Author (S4U).
                      Should it be any discount, upgrade price for the v1 users?
                      If yes how can one apply it?
                      • hdpvH Offline
                        hdpv
                        Now,the update is free.
                        Mail to me if you purchased it.
                        Suforyou
                          rv1974
                          Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
                          Thank you
                          • hdpvH Offline
                            hdpv
                            Hi rv1974!
                            s4u Transformer can't do it.
                            You try this code:
                            sel=Sketchup.active_model.selection
                            axis=[0,5,10]
                            s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
                            sel.clear
                            sel.add s
                            Suforyou
                              rv1974
                              Hdpv thanks for reply!
                              I tried the code- nothing happens. what am I doing wrong?
                              Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                              <main>:4:in add' <main>:4:in <main>'
                              SketchUp:1:in `eval'
                              • hdpvH Offline
                                hdpv
                                First,You select all components.
                                Suforyou
                                  rv1974
                                  IDK I select all and ... no magic happens
                                  Sometimes I have no reply in Ruby console, sometimes diffrent errors.
                                  In any case nothing flips to original
                                  axis=[0,5,10]
                                  sel.clear
                                  sel.add s
                                  or
                                  SketchUp:1:in eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in eval'
                                  axes.skp
                                  • hdpvH Offline
                                    hdpv
                                    You change axis.z to axis.x
                                    axis=[0,5,10]
                                    s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
                                    sel.clear
                                    sel.add s
                                    After,you use s4uTransformer with center origin and ratio scale x_axis: -1
                                    Suforyou
                                      rv1974
                                      😮 Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
                                      May I humbly ask you to shape it as .rb?
                                      And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
                                      Many thanks for assistance.
                                      • 2 / 2
