    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.7k Views 12 Watching
    • hdpvH Offline
      hdpv
      Thank all!
      it's the same a game πŸ˜„
      Suforyou
      http://www.sketchupforyou.com
      • BoxB Offline
        It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update.
        @tig said:
        If an author has made his tool's loading code 'unfriendly' it will always open its toolbar, even if you last exited with that toolbar closed...
        For example if a plugin has the overly simple code:
        tb.show
        Which always opens the toolbar, irrespective of your wishes !
        To open a toolbar only if the user previously exited with it open [OR it's the first time it's used, e.g. a new installation] the loader code needs adjusting to read something like:
        tb.show **if tb.get_last_state.abs == 1** # TB_VISIBLE/NEVER
        Which is the code used by the SketchUcation toolbar...
        • StinkieS Offline
          Stinkie
          Wow. πŸ‘
          • hdpvH Offline
            hdpv
            tb.show
            maybe on Mac,on Win is no problem
            I fix for next update,
            Suforyou
            • BoxB Offline
              I don't have a mac.
              • hdpvH Offline
                hdpv
                i don't know this error,but this code is OK
                "tb.show if tb.get_last_state.abs == 1"
                Suforyou
                • BoxB Offline
                  I know nothing about coding so I gave you a quote from Tig when the issue came up before.
                  I just wanted to point out that your Plugin's toolbar was always popping up whether open or closed previously. I've just installed and tested your Slice plugin and it doesn't do it, so that suggest there is a difference in the code.
                  I don't mean this as a criticism, simply a bug fix.
                  • hdpvH Offline
                    hdpv
                    no difference in the code.I use Sketchup 2014,win64
                    this bug fix is no expect. πŸ˜„
                    Suforyou
                    • HornOxxH Offline
                      HornOxx
                      hi HDPV,
                      first thank you for this great tool!
                      I have used it for some time and it worked great so far, but since a few days I get the message
                      that I should do an update as soon as I use the plugin (please see screenshot). This is the only plugin that causes this error by now.
                      I run SketchUp 2013 Pro and SketchUp 8 Free on Win7 64bit. I get this message on both versions.
                      any help is appreciated - thank you
                      never trust a skinny cook
                      • hdpvH Offline
                        hdpv
                        Sorry HornOxx, This trial is expired.
                        Suforyou
                          Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
                          • HornOxxH Offline
                            HornOxx
                            Sorry - how embarrassing to me!! πŸ˜‰ I didnΒ΄t even notice that this is a purchase-plugin.
                            Regards to All
                            • hdpvH Offline
                              hdpv
                              Thanks Dave!
                              Suforyou
                              • BerserkB Offline
                                Berserk
                                This is incredible
                                  pipinek
                                  To the Author (S4U).
                                  Should it be any discount, upgrade price for the v1 users?
                                  If yes how can one apply it?
                                  • hdpvH Offline
                                    hdpv
                                    Now,the update is free.
                                    Mail to me if you purchased it.
                                    Suforyou
                                      rv1974
                                      Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
                                      Thank you
                                      • hdpvH Offline
                                        hdpv
                                        Hi rv1974!
                                        s4u Transformer can't do it.
                                        You try this code:
                                        sel=Sketchup.active_model.selection
                                        axis=[0,5,10]
                                        s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
                                        sel.clear
                                        sel.add s
                                        Suforyou
                                          rv1974
                                          Hdpv thanks for reply!
                                          I tried the code- nothing happens. what am I doing wrong?
                                          Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                                          <main>:4:in add' <main>:4:in <main>'
                                          SketchUp:1:in `eval'
                                          • hdpvH Offline
                                            hdpv
                                            First,You select all components.
                                            Suforyou
