    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.9k Views 12 Watching
    • BerserkB Offline
      Berserk
      This is incredible
        pipinek
        To the Author (S4U).
        Should it be any discount, upgrade price for the v1 users?
        If yes how can one apply it?
        • hdpvH Offline
          hdpv
          Now,the update is free.
          Mail to me if you purchased it.
          Suforyou
          http://www.sketchupforyou.com
            rv1974
            Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
            Thank you
            • hdpvH Offline
              hdpv
              Hi rv1974!
              s4u Transformer can't do it.
              You try this code:
              sel=Sketchup.active_model.selection
              axis=[0,5,10]
              s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
              sel.clear
              sel.add s
              Suforyou
                rv1974
                Hdpv thanks for reply!
                I tried the code- nothing happens. what am I doing wrong?
                Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                <main>:4:in add' <main>:4:in <main>'
                SketchUp:1:in `eval'
                • hdpvH Offline
                  hdpv
                  First,You select all components.
                  Suforyou
                    rv1974
                    IDK I select all and ... no magic happens
                    Sometimes I have no reply in Ruby console, sometimes diffrent errors.
                    In any case nothing flips to original
                    axis=[0,5,10]
                    sel.clear
                    sel.add s
                    or
                    SketchUp:1:in eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in eval'
                    axes.skp
                    • hdpvH Offline
                      hdpv
                      You change axis.z to axis.x
                      axis=[0,5,10]
                      s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
                      sel.clear
                      sel.add s
                      After,you use s4uTransformer with center origin and ratio scale x_axis: -1
                      Suforyou
                        rv1974
                        ๐Ÿ˜ฎ Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
                        May I humbly ask you to shape it as .rb?
                        And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
                        Many thanks for assistance.
                        • 2 / 2
