    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.9k Views 12 Watching
      @hdpv said:
      Sorry HornOxx, This trial is expired.
      Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
      • HornOxxH Offline
        HornOxx
        Sorry - how embarrassing to me!! 😉 I didn´t even notice that this is a purchase-plugin.
        Regards to All
        never trust a skinny cook
        • hdpvH Offline
          hdpv
          Thanks Dave!
          Suforyou
          http://www.sketchupforyou.com
          • BerserkB Offline
            Berserk
            This is incredible
              pipinek
              To the Author (S4U).
              Should it be any discount, upgrade price for the v1 users?
              If yes how can one apply it?
              • hdpvH Offline
                hdpv
                Now,the update is free.
                Mail to me if you purchased it.
                Suforyou
                  rv1974
                  Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
                  Thank you
                  • hdpvH Offline
                    hdpv
                    Hi rv1974!
                    s4u Transformer can't do it.
                    You try this code:
                    sel=Sketchup.active_model.selection
                    axis=[0,5,10]
                    s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
                    sel.clear
                    sel.add s
                    Suforyou
                      rv1974
                      Hdpv thanks for reply!
                      I tried the code- nothing happens. what am I doing wrong?
                      Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                      <main>:4:in add' <main>:4:in <main>'
                      SketchUp:1:in `eval'
                      • hdpvH Offline
                        hdpv
                        First,You select all components.
                        Suforyou
                          rv1974
                          IDK I select all and ... no magic happens
                          Sometimes I have no reply in Ruby console, sometimes diffrent errors.
                          In any case nothing flips to original
                          axis=[0,5,10]
                          sel.clear
                          sel.add s
                          or
                          SketchUp:1:in eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in eval'
                          axes.skp
                          • hdpvH Offline
                            hdpv
                            You change axis.z to axis.x
                            axis=[0,5,10]
                            s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
                            sel.clear
                            sel.add s
                            After,you use s4uTransformer with center origin and ratio scale x_axis: -1
                            Suforyou
                              rv1974
                              😮 Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
                              May I humbly ask you to shape it as .rb?
                              And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
                              Many thanks for assistance.
                              • 2 / 2
