    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.9k Views 12 Watching
    • hdpvH Offline
      hdpv
      Sorry HornOxx, This trial is expired.
      Suforyou
      http://www.sketchupforyou.com
        Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
        • HornOxxH Offline
          HornOxx
          Sorry - how embarrassing to me!! 😉 I didn´t even notice that this is a purchase-plugin.
          Regards to All
          never trust a skinny cook
          • hdpvH Offline
            hdpv
            Thanks Dave!
            Suforyou
            • BerserkB Offline
              Berserk
              This is incredible
                pipinek
                To the Author (S4U).
                Should it be any discount, upgrade price for the v1 users?
                If yes how can one apply it?
                • hdpvH Offline
                  hdpv
                  Now,the update is free.
                  Mail to me if you purchased it.
                  Suforyou
                    rv1974
                    Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
                    Thank you
                    • hdpvH Offline
                      hdpv
                      Hi rv1974!
                      s4u Transformer can't do it.
                      You try this code:
                      sel=Sketchup.active_model.selection
                      axis=[0,5,10]
                      s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
                      sel.clear
                      sel.add s
                      Suforyou
                        rv1974
                        Hdpv thanks for reply!
                        I tried the code- nothing happens. what am I doing wrong?
                        Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                        <main>:4:in add' <main>:4:in <main>'
                        SketchUp:1:in `eval'
                        • hdpvH Offline
                          hdpv
                          First,You select all components.
                          Suforyou
                            rv1974
                            IDK I select all and ... no magic happens
                            Sometimes I have no reply in Ruby console, sometimes diffrent errors.
                            In any case nothing flips to original
                            axis=[0,5,10]
                            sel.clear
                            sel.add s
                            or
                            SketchUp:1:in eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in eval'
                            axes.skp
                            • hdpvH Offline
                              hdpv
                              You change axis.z to axis.x
                              axis=[0,5,10]
                              s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
                              sel.clear
                              sel.add s
                              After,you use s4uTransformer with center origin and ratio scale x_axis: -1
                              Suforyou
                                rv1974
                                😮 Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
                                May I humbly ask you to shape it as .rb?
                                And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
                                Many thanks for assistance.
                                • 2 / 2
