    [Plugin][$] S4u_Transformer
    28 Posts 12 Posters 20.1k Views 12 Watching
    • hdpvH Offline
      hdpv
      Now,the update is free.
      Mail to me if you purchased it.
      Suforyou
      http://www.sketchupforyou.com
        rv1974
        Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take onlythose with scale -1 and flip it to 1?
        Thank you
        • hdpvH Offline
          hdpv
          Hi rv1974!
          s4u Transformer can't do it.
          You try this code:
          sel=Sketchup.active_model.selection
          axis=[0,5,10]
          s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
          sel.clear
          sel.add s
          Suforyou
            rv1974
            Hdpv thanks for reply!
            I tried the code- nothing happens. what am I doing wrong?
            Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
            <main>:4:in add' <main>:4:in <main>'
            SketchUp:1:in `eval'
            • hdpvH Offline
              hdpv
              First,You select all components.
              Suforyou
                rv1974
                IDK I select all and ... no magic happens
                Sometimes I have no reply in Ruby console, sometimes diffrent errors.
                In any case nothing flips to original
                axis=[0,5,10]
                sel.clear
                sel.add s
                or
                SketchUp:1:in eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in eval'
                axes.skp
                • hdpvH Offline
                  hdpv
                  You change axis.z to axis.x
                  axis=[0,5,10]
                  s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
                  sel.clear
                  sel.add s
                  After,you use s4uTransformer with center origin and ratio scale x_axis: -1
                  Suforyou
                    rv1974
                    ๐Ÿ˜ฎ Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
                    May I humbly ask you to shape it as .rb?
                    And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
                    Many thanks for assistance.
                    • 2 / 2
