    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 134.3k Views 39 Watching
    • V
      valerostudio
      Will we get support for 2019? It doesnt seem to be installing correctly.
        stefanozilio
        Only for Info, I used your bar a lot
        Do you have the intension to update it for SU2019?
        SZ
        • CadFatherC
          CadFather
          Yes, hope to work on an update sometime soon, time is a bit short but I will.
          also if problems, please try to be as specific as possible.
          • CadFatherC
            CadFather
            ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
            later i'll have a proper look at the script and update it properly - thanks
            Powerbar Fix for 2019.rbz
            • atelierpaarA
              atelierpaar
              Hello,
              I hope this chat also relates to jhs powerbar.
              After intalling SU 2019 I get the following errorcode :
              Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
              Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
              return nil
              C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in load' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in module:JHS_powerbar'
              C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>'
              C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
              C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
              C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
              unfortuantely I have no clou how to fix this.
              Any suggestions ?
              thanks
              Uli
              • jujuJ
                juju
                @atelierpaar said:
                Hello,
                return nil
                Any suggestions ?
                thanks
                Uli
                Uli, is this with the file provided in the post directly above yours? (see below for quote).
                [attachment=0:26dzmfax]<!-- ia0 -->Powerbar Fix for 2019.rbz<!-- ia0 -->[/attachment:26dzmfax]
                • CadFatherC
                  CadFather
                  yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
                    stefanozilio
                    Thanks, the bar is going to work in 2019
                    • V
                      valerostudio
                      Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
                      • CadFatherC
                        CadFather
                        that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
                        • atelierpaarA
                          atelierpaar
                          thanks to you all
                          after a fresh download everything is nice an shiny again
                          Uli
                          • V
                            valerostudio
                            I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
                            • F
                              flyer_50
                              thanks
                              working also for me
                              regars
                                Hi Max,
                                Can you put the latest version in the PluginStore? The one linked to there is out of date.
                                Thanks.
                                • CadFatherC
                                  CadFather
                                  hi Dave, sure
                                    Does the Power Tool bar has new plugins inside or it's grouping plugins yet existing ?
                                    • CadFatherC
                                      CadFather
                                      it contains existing plugins. some near the original version - and many have been tweaked or even re-written (back in 2015).
                                        Thx for the explantions! โ˜€
                                          jamesfrees
                                          Mine says that jhs and the fix file are not models and can not be opened, I have updated everything
                                            Extensions are not models and are not installed by opening in SketchUp. What version of SketchUp are you actually using? Your profile says you are using SketchUp 2019 Free/Make but there is no such version.
                                            • 3 / 4
