    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 117.6k Views 39 Watching
    • CadFatherC Offline
      CadFather
      Hi Pherim, i'll have a look at it, though that might be a while as i'm away
        Pherim
        Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
        Then I get this error in the Ruby Console:
        Error; #<ArgumentError; Not enough points - at least 2 required>
        C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `add_curve'
        C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `main'
        C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb;578;in `block in <module;Max_Coppoletta>'
        SketchUp;1;in `call'
        • V Offline
          vzynsky
          JHS powerbar 2.4 + su17! What was the problem? 😕
          https://scontent.fdad1-1.fna.fbcdn.net/v/t1.0-9/21728301_1450124848414787_6713604283302657052_n.jpg?oh=39fd716e7f701ed415829835d3fb3cf2&oe=5A49F8D4
            GoodWin_2203
            thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
            • majidM Online
              majid
              Silly question: Does it work with the latest SU?
              • Y Offline
                young77
                Hi…
                I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.
                please refers to my link : https://ufile.io/fk7et
                • V Offline
                  valerostudio
                  Will we get support for 2019? It doesnt seem to be installing correctly.
                    stefanozilio
                    Only for Info, I used your bar a lot
                    Do you have the intension to update it for SU2019?
                    SZ
                      CadFather
                      Yes, hope to work on an update sometime soon, time is a bit short but I will.
                      also if problems, please try to be as specific as possible.
                        CadFather
                        ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
                        later i'll have a proper look at the script and update it properly - thanks
                        Powerbar Fix for 2019.rbz
                        • atelierpaarA Offline
                          atelierpaar
                          Hello,
                          I hope this chat also relates to jhs powerbar.
                          After intalling SU 2019 I get the following errorcode :
                          Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                          Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
                          return nil
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in load' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in module:JHS_powerbar'
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>'
                          C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
                          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
                          unfortuantely I have no clou how to fix this.
                          Any suggestions ?
                          thanks
                          Uli
                          • jujuJ Offline
                            juju
                            @atelierpaar said:
                            Hello,
                            return nil
                            Any suggestions ?
                            thanks
                            Uli
                            Uli, is this with the file provided in the post directly above yours? (see below for quote).
                            [attachment=0:26dzmfax]<!-- ia0 -->Powerbar Fix for 2019.rbz<!-- ia0 -->[/attachment:26dzmfax]
                              CadFather
                              yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
                                stefanozilio
                                Thanks, the bar is going to work in 2019
                                • V Offline
                                  valerostudio
                                  Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
                                    CadFather
                                    that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
                                      atelierpaar
                                      thanks to you all
                                      after a fresh download everything is nice an shiny again
                                      Uli
                                      • V Offline
                                        valerostudio
                                        I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
                                        • F Offline
                                          flyer_50
                                          thanks
                                          working also for me
                                          regars
                                            Hi Max,
                                            Can you put the latest version in the PluginStore? The one linked to there is out of date.
                                            Thanks.
                                            • 3 / 4
