    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 125.1k Views 39 Watching
    • CadFatherC Offline
      CadFather
      that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
      • atelierpaarA Offline
        atelierpaar
        thanks to you all
        after a fresh download everything is nice an shiny again
        Uli
        • V Offline
          valerostudio
          I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
          • F Offline
            flyer_50
            thanks
            working also for me
            regars
              Hi Max,
              Can you put the latest version in the PluginStore? The one linked to there is out of date.
              Thanks.
                CadFather
                hi Dave, sure
                  Does the Power Tool bar has new plugins inside or it's grouping plugins yet existing ?
                    CadFather
                    it contains existing plugins. some near the original version - and many have been tweaked or even re-written (back in 2015).
                      Thx for the explantions! ☀
                        jamesfrees
                        Mine says that jhs and the fix file are not models and can not be opened, I have updated everything
                          Extensions are not models and are not installed by opening in SketchUp. What version of SketchUp are you actually using? Your profile says you are using SketchUp 2019 Free/Make but there is no such version.
                            berylho
                            I'm using 19.3 version, but even I have downloaded the newest version of the Powerbar, the tool bar still isn't showing...and there is no error message either.
                            • jujuJ Offline
                              juju
                              Have you checked View > Toolbars to see if there is a checkmark next to its entry?
                                I don't have any use for it but I just installed it in SU2019.3 to see what would happen. I clicked the Install button and nearly instantly, the toolbar appeared at the top of the model window.
                                  arielkarmi
                                  Im using sketchup 2020 on a Mac. Installed the extension but cant find the tools. Its also showing as an unsigned extension. I tried to install 2019. Same issue.
                                  Any advice?
                                    Apocan
                                    indiremiyorum yardımcı olurmusunuz ?
                                    • jujuJ Offline
                                      juju
                                      bless your soul
                                      • Y Offline
                                        yjanssen
                                        Does not work on sketchup 2020 pro...
                                        does not come up
                                          Actually it does work just fine in SketchUp 2020.
                                          Make sure you've installed the correct version.
                                            darkhelmet
                                            Thx to @cadfather for this awesome plugin. I kinda figured out most of the functionality however I don't understand how Rotix works - it shows the 3 planes in the upper left, but how do I then rotate an object?
                                            • 4 / 4
