    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 125.6k Views 39 Watching
    • CadFatherC Offline
      CadFather
      Yes, hope to work on an update sometime soon, time is a bit short but I will.
      also if problems, please try to be as specific as possible.
        CadFather
        ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
        later i'll have a proper look at the script and update it properly - thanks
        Powerbar Fix for 2019.rbz
        • atelierpaarA Offline
          atelierpaar
          Hello,
          I hope this chat also relates to jhs powerbar.
          After intalling SU 2019 I get the following errorcode :
          Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
          Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
          return nil
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in load' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in module:JHS_powerbar'
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>'
          C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
          C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
          unfortuantely I have no clou how to fix this.
          Any suggestions ?
          thanks
          Uli
          • jujuJ Offline
            juju
            @atelierpaar said:
            Hello,
            return nil
            Any suggestions ?
            thanks
            Uli
            Uli, is this with the file provided in the post directly above yours? (see below for quote).
            [attachment=0:26dzmfax]<!-- ia0 -->Powerbar Fix for 2019.rbz<!-- ia0 -->[/attachment:26dzmfax]
              CadFather
              yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
                stefanozilio
                Thanks, the bar is going to work in 2019
                • V Offline
                  valerostudio
                  Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
                    CadFather
                    that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
                      atelierpaar
                      thanks to you all
                      after a fresh download everything is nice an shiny again
                      Uli
                      • V Offline
                        valerostudio
                        I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
                        • F Offline
                          flyer_50
                          thanks
                          working also for me
                          regars
                            Hi Max,
                            Can you put the latest version in the PluginStore? The one linked to there is out of date.
                            Thanks.
                              CadFather
                              hi Dave, sure
                                Does the Power Tool bar has new plugins inside or it's grouping plugins yet existing ?
                                  CadFather
                                  it contains existing plugins. some near the original version - and many have been tweaked or even re-written (back in 2015).
                                    Thx for the explantions! โ˜€
                                      jamesfrees
                                      Mine says that jhs and the fix file are not models and can not be opened, I have updated everything
                                        Extensions are not models and are not installed by opening in SketchUp. What version of SketchUp are you actually using? Your profile says you are using SketchUp 2019 Free/Make but there is no such version.
                                          berylho
                                          I'm using 19.3 version, but even I have downloaded the newest version of the Powerbar, the tool bar still isn't showing...and there is no error message either.
                                          • jujuJ Offline
                                            juju
                                            Have you checked View > Toolbars to see if there is a checkmark next to its entry?
                                            • 3 / 4
