    Power Toolbar (2.5) - fix for 2019
    78 Posts 39 Posters 134.3k Views 39 Watching
    • P
      Pherim
      Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
      Then I get this error in the Ruby Console:
      Error; #<ArgumentError; Not enough points - at least 2 required>
      C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `add_curve'
      C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb;3841;in `main'
      C;/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb;578;in `block in <module;Max_Coppoletta>'
      SketchUp;1;in `call'
      • V
        vzynsky
        JHS powerbar 2.4 + su17! What was the problem? 😕
        https://scontent.fdad1-1.fna.fbcdn.net/v/t1.0-9/21728301_1450124848414787_6713604283302657052_n.jpg?oh=39fd716e7f701ed415829835d3fb3cf2&oe=5A49F8D4
        • G
          GoodWin_2203
          thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
          • majidM
            majid
            Silly question: Does it work with the latest SU?
            • Y
              young77
              Hi…
              I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.
              please refers to my link : https://ufile.io/fk7et
              • V
                valerostudio
                Will we get support for 2019? It doesnt seem to be installing correctly.
                  stefanozilio
                  Only for Info, I used your bar a lot
                  Do you have the intension to update it for SU2019?
                  SZ
                  • CadFatherC
                    CadFather
                    Yes, hope to work on an update sometime soon, time is a bit short but I will.
                    also if problems, please try to be as specific as possible.
                    • CadFatherC
                      CadFather
                      ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
                      later i'll have a proper look at the script and update it properly - thanks
                      Powerbar Fix for 2019.rbz
                      • atelierpaarA
                        atelierpaar
                        Hello,
                        I hope this chat also relates to jhs powerbar.
                        After intalling SU 2019 I get the following errorcode :
                        Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                        Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
                        return nil
                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in load' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in module:JHS_powerbar'
                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in <top (required)>'
                        C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
                        C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
                        unfortuantely I have no clou how to fix this.
                        Any suggestions ?
                        thanks
                        Uli
                        • jujuJ
                          juju
                          @atelierpaar said:
                          Hello,
                          return nil
                          Any suggestions ?
                          thanks
                          Uli
                          Uli, is this with the file provided in the post directly above yours? (see below for quote).
                          [attachment=0:26dzmfax]<!-- ia0 -->Powerbar Fix for 2019.rbz<!-- ia0 -->[/attachment:26dzmfax]
                          • CadFatherC
                            CadFather
                            yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
                              stefanozilio
                              Thanks, the bar is going to work in 2019
                              • V
                                valerostudio
                                Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
                                • CadFatherC
                                  CadFather
                                  that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
                                  • atelierpaarA
                                    atelierpaar
                                    thanks to you all
                                    after a fresh download everything is nice an shiny again
                                    Uli
                                    • V
                                      valerostudio
                                      I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
                                      • F
                                        flyer_50
                                        thanks
                                        working also for me
                                        regars
                                          Hi Max,
                                          Can you put the latest version in the PluginStore? The one linked to there is out of date.
                                          Thanks.
                                          • CadFatherC
                                            CadFather
                                            hi Dave, sure
                                            • 3 / 4
