    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 107.3k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
      • samuel_tS Offline
        samuel_t
        Material Library of PBR plugin includes 100 materials --> Direct link to download it.
          macchu
          I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
          • samuel_tS Offline
            samuel_t
            PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
              macchu
              Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
              • samuel_tS Offline
                samuel_t
                Please open a Ruby Console* and paste this code:
                PBR;;Viewport.reopen
                Then send me resulting text or a screen capture.
                (*) Window > Ruby Console
                  macchu
                  Here is a screenshot of the resulting text.
                  • samuel_tS Offline
                    samuel_t
                    [attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
                    Looks good. I don't understand why Viewport doesn't open. 😕
                      macchu
                      It should open in a Chrome browser?
                      • samuel_tS Offline
                        samuel_t
                        Yes. To be exact: It should open in a Chromium browser.
                        • duanekempD Offline
                          duanekemp
                          I had "heard" of this, but this was the first time reading from beginning to end.
                          This is ambitious. Bravo.
                          Duane Kemp
                          Kemp Productions
                          Puidoux, Switzerland
                          Gallery:
                          https://duanekemp.artstation.com/
                          • Didier BurD Offline
                            Didier Bur
                            @samuel_t:
                            Bonjour, merci pour ce plugin, par contre depuis que je l'ai installĂ©, la fenĂȘtre Chromium s'ouvre Ă  chaque dĂ©marrage de SketchUp, avec le dernier modĂšle chargĂ©, c'est un peu gĂȘnant. La camĂ©ra est assez limitĂ©e aussi, le zoom se bloque.
                            Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses.
                            DB
                            • samuel_tS Offline
                              samuel_t
                              La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
                                Bizarre aucun problùme de ce genre! 😄
                                  cadsifu
                                  Hi Samuel,
                                  It's great to know and get this PBR extension.
                                  I believe it is extremely useful for most modelers.
                                  I'm very new to PBR and would like to explore more on it.
                                  Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
                                  Any other plugin needed as supporting tools?
                                  Thank you.
                                  Nizam Mahmud
                                  Malaysia
                                  • samuel_tS Offline
                                    samuel_t
                                    Yes. It is. 👍
                                    • samuel_tS Offline
                                      samuel_t
                                      What's new in version 1.5.0 of PBR plugin?
                                      • You can apply a height map to a material:
                                        PBR Plugin Height Map Demo
                                      • You can change HDR background again.
                                      • Material transparency is auto-detected.
                                      Download latest PBR plugin from the SketchUcation PluginStore.
                                      • filibisF Offline
                                        filibis
                                        Hi Samuel, are you using parallax mapping technique for this height displacement?
                                        • samuel_tS Offline
                                          samuel_t
                                          Hi Filibis, yes.
                                          • samuel_tS Offline
                                            samuel_t
                                            What's new in version 1.5.1 of the PBR plugin?
                                            • You can add artificial lights to model. Here how.
                                            PBR Plugin Lights Demo A
                                            PBR Plugin Lights Demo B
                                            • Camera points by default to the front of model.
                                            • 5 / 6
