    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 101.6k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      @macchu said:
      Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
      Please open a Ruby Console* and paste this code:
      PBR;;Viewport.reopen
      Then send me resulting text or a screen capture.
      (*) Window > Ruby Console
        macchu
        Here is a screenshot of the resulting text.
        • samuel_tS Offline
          samuel_t
          [attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
          Looks good. I don't understand why Viewport doesn't open. 😕
            macchu
            It should open in a Chrome browser?
            • samuel_tS Offline
              samuel_t
              Yes. To be exact: It should open in a Chromium browser.
              • duanekempD Offline
                duanekemp
                I had "heard" of this, but this was the first time reading from beginning to end.
                This is ambitious. Bravo.
                Duane Kemp
                Kemp Productions
                Puidoux, Switzerland
                Gallery:
                https://duanekemp.artstation.com/
                • Didier BurD Offline
                  Didier Bur
                  @samuel_t:
                  Bonjour, merci pour ce plugin, par contre depuis que je l'ai installĂ©, la fenĂȘtre Chromium s'ouvre Ă  chaque dĂ©marrage de SketchUp, avec le dernier modĂšle chargĂ©, c'est un peu gĂȘnant. La camĂ©ra est assez limitĂ©e aussi, le zoom se bloque.
                  Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses.
                  DB
                  • samuel_tS Offline
                    samuel_t
                    La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
                      Bizarre aucun problùme de ce genre! 😄
                        cadsifu
                        Hi Samuel,
                        It's great to know and get this PBR extension.
                        I believe it is extremely useful for most modelers.
                        I'm very new to PBR and would like to explore more on it.
                        Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
                        Any other plugin needed as supporting tools?
                        Thank you.
                        Nizam Mahmud
                        Malaysia
                        • samuel_tS Offline
                          samuel_t
                          Yes. It is. 👍
                          • samuel_tS Offline
                            samuel_t
                            What's new in version 1.5.0 of PBR plugin?
                            • You can apply a height map to a material:
                              PBR Plugin Height Map Demo
                            • You can change HDR background again.
                            • Material transparency is auto-detected.
                            Download latest PBR plugin from the SketchUcation PluginStore.
                            • filibisF Offline
                              filibis
                              Hi Samuel, are you using parallax mapping technique for this height displacement?
                              • samuel_tS Offline
                                samuel_t
                                Hi Filibis, yes.
                                • samuel_tS Offline
                                  samuel_t
                                  What's new in version 1.5.1 of the PBR plugin?
                                  • You can add artificial lights to model. Here how.
                                  PBR Plugin Lights Demo A
                                  PBR Plugin Lights Demo B
                                  • Camera points by default to the front of model.
                                  • samuel_tS Offline
                                    samuel_t
                                    What's new in the version 1.5.2 of the PBR plugin?
                                    • You can add artificial lights from Toolbar/Menu.
                                    • You can adjust sunlight intensity in Viewport.
                                    • Camera control in Viewport is similar to SU one.
                                    • samuel_tS Offline
                                      samuel_t
                                      What's new in the version 1.5.3 of the PBR plugin?
                                      • Camera position in Viewport is automatically saved/restored.
                                      • You can reset camera position in Viewport in one click on movie camera icon.
                                      • "Propagate materials to whole model." is automatically done.
                                        So we will win a click! 😉
                                        • samuel_tS Offline
                                          samuel_t
                                          What's new in the version 1.5.4 of the PBR plugin?
                                          • Textures not supported by glTF are supported by PBR plugin in SketchUp v2018 or greater.
                                          • Fix bug: SketchUp model can't be saved (CFileException 0...) whereas PBR Viewport is open.
                                          • PBR plugin checks automatically if a newer version is available @ http://www.sketchucation.com.
                                          • samuel_tS Offline
                                            samuel_t
                                            What's new in the version 1.5.5 of the PBR plugin?
                                            • Ambient occlusion maps are supported. For now, they are incompatible with height maps. 😕
                                            • When you erase a PBR light: PBR Viewport reopens automatically. Also, PBR lights are named.
                                            • Minor things were changed. E.g: SketchUp status bar changes when PBR Viewport (re)opens...
                                            • 5 / 6
