    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 107.3k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      @chippwalters said:
      Great stuff! Just found out about this plugin. Look forward to trying it 😄
      Thank you! 😉
      • samuel_tS Offline
        samuel_t
        The latest PBR plugin version (downloadable here) includes a toolbar
        and one more material.
          https://2img.net/h/s6.postimg.cc/9zsltvmlt/GIF_samu93.gif
          • samuel_tS Offline
            samuel_t
            PBR plugin v1.4.3 :
            • Checks required plugin.
            • Externalizes material lib.
            • samuel_tS Offline
              samuel_t
              I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore. 😄
                https://o.aolcdn.com/images/dims3/GLOB/legacy_thumbnail/630x315/format/jpg/quality/85/http%3A%2F%2Fi.huffpost.com%2Fgen%2F3708096%2Fimages%2Fn-CHAMPAGNE-628x314.jpg
                https://s6.postimg.cc/c6p1c3ru9/mer_du_sud.jpg
                • samuel_tS Offline
                  samuel_t
                  v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
                  • samuel_tS Offline
                    samuel_t
                    Material Library of PBR plugin includes 100 materials --> Direct link to download it.
                      macchu
                      I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
                      • samuel_tS Offline
                        samuel_t
                        PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
                          macchu
                          Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
                          • samuel_tS Offline
                            samuel_t
                            Please open a Ruby Console* and paste this code:
                            PBR;;Viewport.reopen
                            Then send me resulting text or a screen capture.
                            (*) Window > Ruby Console
                              macchu
                              Here is a screenshot of the resulting text.
                              • samuel_tS Offline
                                samuel_t
                                [attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
                                Looks good. I don't understand why Viewport doesn't open. 😕
                                  macchu
                                  It should open in a Chrome browser?
                                  • samuel_tS Offline
                                    samuel_t
                                    Yes. To be exact: It should open in a Chromium browser.
                                    • duanekempD Offline
                                      duanekemp
                                      I had "heard" of this, but this was the first time reading from beginning to end.
                                      This is ambitious. Bravo.
                                      Duane Kemp
                                      Kemp Productions
                                      Puidoux, Switzerland
                                      Gallery:
                                      https://duanekemp.artstation.com/
                                      • Didier BurD Offline
                                        Didier Bur
                                        @samuel_t:
                                        Bonjour, merci pour ce plugin, par contre depuis que je l'ai installé, la fenêtre Chromium s'ouvre à chaque démarrage de SketchUp, avec le dernier modèle chargé, c'est un peu gênant. La caméra est assez limitée aussi, le zoom se bloque.
                                        Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses.
                                        DB
                                        • samuel_tS Offline
                                          samuel_t
                                          La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
                                            Bizarre aucun problème de ce genre! 😄
                                            • 4 / 6
