    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 107.3k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      The latest PBR plugin version (downloadable here) includes a toolbar
      and one more material.
        https://2img.net/h/s6.postimg.cc/9zsltvmlt/GIF_samu93.gif
        • samuel_tS Offline
          samuel_t
          PBR plugin v1.4.3 :
          • Checks required plugin.
          • Externalizes material lib.
          • samuel_tS Offline
            samuel_t
            I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore. 😄
              https://o.aolcdn.com/images/dims3/GLOB/legacy_thumbnail/630x315/format/jpg/quality/85/http%3A%2F%2Fi.huffpost.com%2Fgen%2F3708096%2Fimages%2Fn-CHAMPAGNE-628x314.jpg
              https://s6.postimg.cc/c6p1c3ru9/mer_du_sud.jpg
              • samuel_tS Offline
                samuel_t
                v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
                • samuel_tS Offline
                  samuel_t
                  Material Library of PBR plugin includes 100 materials --> Direct link to download it.
                    macchu
                    I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
                    • samuel_tS Offline
                      samuel_t
                      PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
                        macchu
                        Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
                        • samuel_tS Offline
                          samuel_t
                          Please open a Ruby Console* and paste this code:
                          PBR;;Viewport.reopen
                          Then send me resulting text or a screen capture.
                          (*) Window > Ruby Console
                            macchu
                            Here is a screenshot of the resulting text.
                            • samuel_tS Offline
                              samuel_t
                              [attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
                              Looks good. I don't understand why Viewport doesn't open. 😕
                                macchu
                                It should open in a Chrome browser?
                                • samuel_tS Offline
                                  samuel_t
                                  Yes. To be exact: It should open in a Chromium browser.
                                  • duanekempD Offline
                                    duanekemp
                                    I had "heard" of this, but this was the first time reading from beginning to end.
                                    This is ambitious. Bravo.
                                    Duane Kemp
                                    Kemp Productions
                                    Puidoux, Switzerland
                                    Gallery:
                                    https://duanekemp.artstation.com/
                                    • Didier BurD Offline
                                      Didier Bur
                                      @samuel_t:
                                      Bonjour, merci pour ce plugin, par contre depuis que je l'ai installĂ©, la fenĂȘtre Chromium s'ouvre Ă  chaque dĂ©marrage de SketchUp, avec le dernier modĂšle chargĂ©, c'est un peu gĂȘnant. La camĂ©ra est assez limitĂ©e aussi, le zoom se bloque.
                                      Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses.
                                      DB
                                      • samuel_tS Offline
                                        samuel_t
                                        La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
                                          Bizarre aucun problùme de ce genre! 😄
                                            cadsifu
                                            Hi Samuel,
                                            It's great to know and get this PBR extension.
                                            I believe it is extremely useful for most modelers.
                                            I'm very new to PBR and would like to explore more on it.
                                            Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
                                            Any other plugin needed as supporting tools?
                                            Thank you.
                                            Nizam Mahmud
                                            Malaysia
                                            • 4 / 6
