    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 110.4k Views 14 Watching
    • samuel_tS
      samuel_t
      I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore. 😄
        https://o.aolcdn.com/images/dims3/GLOB/legacy_thumbnail/630x315/format/jpg/quality/85/http%3A%2F%2Fi.huffpost.com%2Fgen%2F3708096%2Fimages%2Fn-CHAMPAGNE-628x314.jpg
        https://s6.postimg.cc/c6p1c3ru9/mer_du_sud.jpg
        • samuel_tS
          samuel_t
          v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
          • samuel_tS
            samuel_t
            Material Library of PBR plugin includes 100 materials --> Direct link to download it.
              macchu
              I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
              • samuel_tS
                samuel_t
                PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
                  macchu
                  Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
                  • samuel_tS
                    samuel_t
                    Please open a Ruby Console* and paste this code:
                    PBR;;Viewport.reopen
                    Then send me resulting text or a screen capture.
                    (*) Window > Ruby Console
                      macchu
                      Here is a screenshot of the resulting text.
                      • samuel_tS
                        samuel_t
                        [attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
                        Looks good. I don't understand why Viewport doesn't open. 😕
                          macchu
                          It should open in a Chrome browser?
                          • samuel_tS
                            samuel_t
                            Yes. To be exact: It should open in a Chromium browser.
                            • duanekempD
                              duanekemp
                              I had "heard" of this, but this was the first time reading from beginning to end.
                              This is ambitious. Bravo.
                              Duane Kemp
                              Kemp Productions
                              Puidoux, Switzerland
                              Gallery:
                              https://duanekemp.artstation.com/
                              • Didier BurD
                                Didier Bur
                                @samuel_t:
                                Bonjour, merci pour ce plugin, par contre depuis que je l'ai installĂ©, la fenĂȘtre Chromium s'ouvre Ă  chaque dĂ©marrage de SketchUp, avec le dernier modĂšle chargĂ©, c'est un peu gĂȘnant. La camĂ©ra est assez limitĂ©e aussi, le zoom se bloque.
                                Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses.
                                DB
                                • samuel_tS
                                  samuel_t
                                  La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
                                    Bizarre aucun problùme de ce genre! 😄
                                    • C
                                      cadsifu
                                      Hi Samuel,
                                      It's great to know and get this PBR extension.
                                      I believe it is extremely useful for most modelers.
                                      I'm very new to PBR and would like to explore more on it.
                                      Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
                                      Any other plugin needed as supporting tools?
                                      Thank you.
                                      Nizam Mahmud
                                      Malaysia
                                      • samuel_tS
                                        samuel_t
                                        Yes. It is. 👍
                                        • samuel_tS
                                          samuel_t
                                          What's new in version 1.5.0 of PBR plugin?
                                          • You can apply a height map to a material:
                                            PBR Plugin Height Map Demo
                                          • You can change HDR background again.
                                          • Material transparency is auto-detected.
                                          Download latest PBR plugin from the SketchUcation PluginStore.
                                          • filibisF
                                            filibis
                                            Hi Samuel, are you using parallax mapping technique for this height displacement?
                                            • 5 / 6
