    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
    • alsomarA
      alsomar Extension Creator
      A really nice improvement! Thank you so much for this new extension!
      Alejandro Soriano Visuals ยท All my links
        Mill29
        Unbelivable tool!
        thanks a lot!
        • StinkieS
          Stinkie
          Consider me baffled. ๐Ÿ˜ฎ
          Thanks alot for the videos. ๐Ÿ‘
          Edit: the preview mode is great!
            damj
            This is awesome! Thank you!!
            Rounding complex geometry will be so much easier!
            About the Undo/Repair option, what happens to a geometry that has been modified after the rounding?
            Will the "undone geometry" be discarded or will it restore to the original geometry, discarding the modifications in the meantime?
            I +1 the wish from chippwalters to have a component "remember" its rounding parameters (one can never get enough ๐Ÿ˜› )
            Thank you again!
            • fredo6F
              Thank you again!
              It's not like if Sketchup had a full parametric framework! Actualy, there is absolutely nothing.
              Once a shape is rounded, that would be fine to move it, scale it, etc... as long as this is based on regular transformation. Repair will work and keep the transformation.
              However, if modify the shape, Repair will re-establish the original shape at it was when you did the Rounding. So your changes will be lost, including material painting and edge properties.
              I take the idea of the Modifier, which was my initial goal, but is more complex to do.
              So consider Repair as a safety net at the moment.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                That's stunning work! Congrats
                Did you consider having a simpler toggle button like SubD's, instead of the undo/repair?
                  samnorth
                  Wow, thank you Fredo!
                  ๐Ÿ‘ ๐Ÿ˜„
                  • G
                    Glenn at home
                    Oh BOY!!!!!! Thank you for this!
                    • K
                      kaas
                      impressive!
                      • cottyC
                        cotty
                        Can't wait to try it!
                        my SketchUp gallery
                          Fredo does it again !
                          • fredo6F
                            Thanks to all for your encouragements.
                            One thing I forgot to mention (it's now done in the main post) is that FredoCorner will become a paid plugin after a 2-3 months beta period. It will also only support SU2016 and above. RoundCorner will continue to exist and be supported as a free plugin.
                            • BoxB
                              And so it should, you need to be paid for your excellent work.
                              • T
                                Tyson
                                This is phenomenal! Thank you, thank you, thank you Fredo!
                                • OxerO
                                  Oxer
                                  Congratulations Fredo!! ๐Ÿ‘
                                  This is a incredible tool and it's very useful to make the complex shapes more realistic, thanks for your efforts.
                                  • N
                                    numerobis
                                    AWESOME!!! ๐Ÿ˜
                                    This really looks fantastic. Great work. Thank you very much! ๐Ÿ˜„ ๐Ÿ˜Ž
                                    • PixeroP
                                      Pixero
                                      That would be useful.
                                      • alvisA
                                        alvis
                                        Impressive. ๐Ÿ˜ฎ
                                        • cengiziletenC
                                          cengizileten
                                          The great return of Fredo
                                          • N
                                            numerobis
                                            A real modifier system in SU would be great. Maybe if some of you plugin geniuses could join together to get Trimble to at least support this effort, if it would be possible with some modifications in the SU code.
                                            Based on the experience of the last years i think we won't see any real improvements of SU in the near future, but maybe there would be a way to extend the capability in form of payed extentions that go deeper than the current plugins.
                                            btw. If you can store this rounding information with the object, would it be possible to implement material IDs on this level?
                                            • 22
                                            • 23
                                            • 1 / 23
