    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
    • halroachH
      halroach
      A quick update:
      We released a few enhancements and important bug fixes for WallCutter and the Place Upright tool.
      Read more about the changes in the Change log: https://flextools.cc/change-log
      FlexTools - Super Quick Windows, Doors, Slats...
        dpaul
        Hello,
        Is it possible to use a window/door component with casings on BOTH sides and
        only the FRAME of the win/door cuts the wall (a group), leaving the trim on both sides intact?
        With my thanks.
        David
        • halroachH
          halroach
          @dpaul said:
          Hello,
          With my thanks.
          David
          Hey David,
          Yes it is possible... But we haven't released this feature yet. 😎.
          It will be available in the next update of FlexTools. You will then be able to mark sub-components to be ignored by the cutting algorithm. We'll make an announcement when it's ready.
          Yoni
            dpaul
            While waiting, I went ahead and purchased your plugin only to find out that you are right: it can't be done at the moment.
            Disappointing......
            However, what is encouraging is being able to punch in one of my windows into a wall I created with
            Profile Builder 3 and when I shrink or expand the PB wall, I do temporarily lose my window, but once I press REFRESH it comes back. A relief.....!
            In other words, this could be the combo I have been looking for that will fast track my building layouts: PB3 walls and Wall cutter for installing my own windows and doors.
            Till then, though, perhaps we can clone you and your team in order to speed up what I need.......😄
            Cheers.
            David
            • halroachH
              halroach
              Disappointing......
              Cheers.
              David
              If we were cloned... one of us clones would have definitely answered your question a lot faster! 😄
              Great to hear it's working well with PB3 and with the Refresh button!
              We have the feature you need already working in our 'development branch'. I believe you'll be able to use it pretty soon.
                dpaul
                Yes, Flex and PB3 should work very well for me---and I am particularly encouraged by the last comment in your thread.
                I look forward to hearing about the update soon.....!
                With my thanks.
                David
                • pbacotP
                  All sounds great. Hope to try it soon!
                  • halroachH
                    halroach
                    With my thanks.
                    David
                    Here it is! 😄
                    New update for WallCutter!
                    In this update we've introduced a much requested and significant enhancement for WallCutter - the ability to exclude sub-components from affecting the cutting algorithm. That means you'll now be able to have wall cutting windows (and doors) with Trim!
                    And yes, it will work with trim on both sides as asked by David here.
                    This update also includes a couple of bug fixes:
                    👊 One of the bugs found by Pixero (posted here) should now be fixed. Sketchup won't crash now when having 0 faces in a WallCutter component.
                    👊 The other bug fix addresses another similar crash that could happen if the faces in a cutting component had the thickness of 0. This could happen when a flat WallCutter component was created with the wrong axes orientation.
                    1. How to auto-update
                    2. Remember to restart Sketchup after the update!
                    Happy Flexing! 😄
                      dpaul
                      This is a crucial addition to a very powerful plugin.
                      Thanks.....!
                      • halroachH
                        halroach
                        Thanks.....!
                        Great to hear! 😄
                          somebodyelse
                          This is great. I just have a quick question about pivot points. Say I want to create a pivot door, how does one go about creating the function of a pivot door?
                          • halroachH
                            halroach
                            Hi Ivan,
                            If you mean to turn the FlexDoor into a pivot door, up till this very moment it was not possible...
                            But it is now!!! 😄
                            I made a few internal changes and added a setting called 'Axis - Move'.
                            Consider this a hot-fix, not completely polished. You must turn the 'Arcs' off and set the 'Hinges' to 0 for things to look normal when changing the axis position.
                            You'll find the updated FlexDoor in the zip attached below. Drag and drop the skp into a model for it to work.
                            flex_door_ft_1_19-pivot_hotfix.zip
                            • I
                              Ivan K
                              OH MY GOODNESS!!!
                              This is absolute perfection! screams in excitement
                              THANK YOU!!!!
                              • halroachH
                                halroach
                                @ivan k said:
                                OH MY GOODNESS!!!
                                THANK YOU!!!!
                                Very glad it's helpful Ivan 😄
                                We released this new FlexDoor feature yesterday as an auto-update to the plugin. I think it will be useful for everyone.
                                • halroachH
                                  halroach
                                  Flex Slider Window/Door - Coming soon in the next update!
                                  • halroachH
                                    halroach
                                    Meet the new FlexSlider window/door!
                                    Customize the sashes! Set the number of divisions, choose from 3 muntin distributions: 'equal divisions', 'prairie style', 'from side+equal spacing'.
                                    https://flextools.cc/wp-content/uploads/2018/09/flexslider-sash-settings-1024x671.png
                                    • halroachH
                                      halroach
                                      One of the features in the new FlexSlider Window/Door is that you can hide parts of the frame in order to make various configurations.
                                      In the following example is a 4-panel door made by combining two FlexSliders.
                                      This can serve as a temporary solution for those who need a 4-panel door component Right Now!
                                      We plan to make a dedicated 4-panel door component at a later time.
                                      https://flextools.cc/wp-content/uploads/2018/10/flexslider_double_01_01.gif
                                      • halroachH
                                        halroach
                                        Glad to announce ComponentFinder was updated to version 0.8.0 😄
                                        The highlights:
                                        • Folder scanning depth is now increased from 5 levels deep to infinity! (and beyond...)
                                        • The maximum number of components in an open folder tab is now up to 6000!
                                        • When opening a new folder tab, the scanning will be going on in the background so you can continue working while it's scanning. Components will be added as they are discovered.
                                        • You can now cancel the scan anytime.
                                        • Faster loading of open folder tabs during CF startup.
                                        • An additional larger zoom level was added.
                                        • You can click on the folder name and it then shows the full path instead.
                                        • When hovering over components, a tooltip appears with the full path.
                                        • The annoying bug where components' thumbnails would suddenly break? Squashed! 👊
                                        To see the full list of release notes => https://flextools.cc/release-notes/
                                        How to update => https://flextools.cc/learn/updates/
                                        • halroachH
                                          halroach
                                          You can now use FlexTools in Japanese 日本語 !
                                          Translations usually come in with a bit of a delay after each release. In this update we've added some translations for the FlexSlider component. Japanese is available for FlexPack Pro and FlexPack 2017 too.
                                          https://discourse-cdn-sjc1.com/sketchup/uploads/default/original/3X/8/8/88d87639cfd535635c811e2c12ced2c7822abfb5.png
                                          Many thanks go to our devoted translators who keep contributing their precious time and expertise:
                                          Takahiro Terasawa for the new Japanese translation
                                          Pilou - French translation
                                          Rafael Teresa - Spanish translation
                                          Rebeca Rabia - Portuguese translation
                                          Charles Tom from Geographic Information LTD 幾何資訊 - Traditional Chinese translation
                                          Shaun 肖万涛 - Simplified Chinese translation
                                          If you can help to translate FlexTools into your language - Please let us know!
                                          • halroachH
                                            halroach
                                            The new Flex Double-Hung Window is released!
                                            Check out the video to see how it works:
                                            • 2 / 9
