    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 342.9k Views 17 Watching
      somebodyelse
      This is great. I just have a quick question about pivot points. Say I want to create a pivot door, how does one go about creating the function of a pivot door?
      • halroachH
        halroach
        Hi Ivan,
        If you mean to turn the FlexDoor into a pivot door, up till this very moment it was not possible...
        But it is now!!! 😄
        I made a few internal changes and added a setting called 'Axis - Move'.
        Consider this a hot-fix, not completely polished. You must turn the 'Arcs' off and set the 'Hinges' to 0 for things to look normal when changing the axis position.
        You'll find the updated FlexDoor in the zip attached below. Drag and drop the skp into a model for it to work.
        flex_door_ft_1_19-pivot_hotfix.zip
        FlexTools - Super Quick Windows, Doors, Slats...
        • I
          Ivan K
          OH MY GOODNESS!!!
          This is absolute perfection! screams in excitement
          THANK YOU!!!!
          • halroachH
            halroach
            @ivan k said:
            OH MY GOODNESS!!!
            THANK YOU!!!!
            Very glad it's helpful Ivan 😄
            We released this new FlexDoor feature yesterday as an auto-update to the plugin. I think it will be useful for everyone.
            • halroachH
              halroach
              Flex Slider Window/Door - Coming soon in the next update!
              • halroachH
                halroach
                Meet the new FlexSlider window/door!
                Customize the sashes! Set the number of divisions, choose from 3 muntin distributions: 'equal divisions', 'prairie style', 'from side+equal spacing'.
                https://flextools.cc/wp-content/uploads/2018/09/flexslider-sash-settings-1024x671.png
                • halroachH
                  halroach
                  One of the features in the new FlexSlider Window/Door is that you can hide parts of the frame in order to make various configurations.
                  In the following example is a 4-panel door made by combining two FlexSliders.
                  This can serve as a temporary solution for those who need a 4-panel door component Right Now!
                  We plan to make a dedicated 4-panel door component at a later time.
                  https://flextools.cc/wp-content/uploads/2018/10/flexslider_double_01_01.gif
                  • halroachH
                    halroach
                    Glad to announce ComponentFinder was updated to version 0.8.0 😄
                    The highlights:
                    • Folder scanning depth is now increased from 5 levels deep to infinity! (and beyond...)
                    • The maximum number of components in an open folder tab is now up to 6000!
                    • When opening a new folder tab, the scanning will be going on in the background so you can continue working while it's scanning. Components will be added as they are discovered.
                    • You can now cancel the scan anytime.
                    • Faster loading of open folder tabs during CF startup.
                    • An additional larger zoom level was added.
                    • You can click on the folder name and it then shows the full path instead.
                    • When hovering over components, a tooltip appears with the full path.
                    • The annoying bug where components' thumbnails would suddenly break? Squashed! 👊
                    To see the full list of release notes => https://flextools.cc/release-notes/
                    How to update => https://flextools.cc/learn/updates/
                    • halroachH
                      halroach
                      You can now use FlexTools in Japanese 日本語 !
                      Translations usually come in with a bit of a delay after each release. In this update we've added some translations for the FlexSlider component. Japanese is available for FlexPack Pro and FlexPack 2017 too.
                      https://discourse-cdn-sjc1.com/sketchup/uploads/default/original/3X/8/8/88d87639cfd535635c811e2c12ced2c7822abfb5.png
                      Many thanks go to our devoted translators who keep contributing their precious time and expertise:
                      Takahiro Terasawa for the new Japanese translation
                      Pilou - French translation
                      Rafael Teresa - Spanish translation
                      Rebeca Rabia - Portuguese translation
                      Charles Tom from Geographic Information LTD 幾何資訊 - Traditional Chinese translation
                      Shaun 肖万涛 - Simplified Chinese translation
                      If you can help to translate FlexTools into your language - Please let us know!
                      • halroachH
                        halroach
                        The new Flex Double-Hung Window is released!
                        Check out the video to see how it works:
                        • halroachH
                          halroach
                          It’s Black Friday time!
                          We’re glad to offer you €25 Off FlexPack Pro! - Speed up your modeling workflow with dynamic windows, doors, WallCutter, the most powerful wall cutting tool in the Sketchup world, and more.
                          This offer is good starting now, from Black Friday to Cyber Monday - Nov 23-26.
                          Spend less time modeling and have more time for actual designing with FlexTools!
                          • Epix3DE
                            Epix3D
                            How can I make a swing glassdoor with glass sidepanels?
                            • halroachH
                              halroach
                              Hi Epix,
                              Take a look at the video in the link - It's currently the closest to a glass door that you can get with FlexDoor:
                              https://youtu.be/LvJJq04AWV0
                              The settings that were changed in the video:
                              Doorstop - Height => 0
                              Sill - Height => 0
                              Clearance Bottom => 0
                              Hinges => 0
                              Door Panel - Thickness => 1cm
                              Axis - Move => 10cm
                              The door handle was also changed (with some parts deleted).
                              You can make your own custom door handles following the tutorials here:
                              http://frandzel3d.com/flexdoor/flexdoor-hardware/
                              Hope that helps.
                              • Epix3DE
                                Epix3D
                                Looks good halroach but I will need frames around glass like a panel door. Do I have to make it manually? I hope this will come in an upcoming version.
                                Like this, -only glass on both sides
                                • halroachH
                                  halroach
                                  I think I have what you need - Please take a look at the (Experimental 🤓 ) FlexLabs section:
                                  https://flextools.cc/flexlabs/
                                  I just added now a 'FlexDoor with glass divisions + Side panels'.
                                  ***** Make sure to install and activate the FlexBetaPack.
                                  ***** Since it is rather experimental, turning off any of the side panels might screw things up.
                                  If you want to remove a side panel (by clicking on the sides of the frame) without sub-components flying around, double click into it until you reach a component called 'Panel Right' or 'Panel Left'. Delete the component that is within either of those. After that click (With the interact tool) on the frame sides to turn off or on the panels.
                                  ***** To edit each of the panels and the mullions you have to double click into the components a few times till you reach the right settings.
                                  Let me know how it works out.
                                  • halroachH
                                    halroach
                                    A new update is out!
                                    You can now browse and search through your In-Model Components and Groups with ComponentFinder!
                                    Read more details on the FlexBlog.
                                    https://flextools.cc/wp-content/uploads/2019/01/CF_In-model_01_05-800.gif
                                    • Epix3DE
                                      Epix3D
                                      When I mirror Flex doors and windows with copy the cutholes on original disappears..?
                                      Same happens if I modify a wall with flexcomponents.
                                      Is there a way of updating so the cutholes comes back?
                                      • halroachH
                                        halroach
                                        Can you upload a jpg or an skp example or send either to yoni@flextools.cc so I can better understand where the issue is.
                                        • Epix3DE
                                          Epix3D
                                          Flexwindows are mirrored from one side to the other cutting new holes but removing the original holes from the side copied from..
                                          [img]FlexToolsMissingHoles.jpg[/img]
                                          • Epix3DE
                                            Epix3D
                                            ..Strange thing happened, -when I closed and reopened the file the holes were back..?
                                            • 3 / 9
