    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 338.0k Views 17 Watching
    • jujuJ Offline
      juju
      @halroach said:
      Hey Juju,
      Please see the attached FlexDoor. It has an extra option under the 'Arc:' attribute called "Always ON". When you want to turn it off, you may need to open and close the door once to see the changes. It's not perfect, but it's way better than exploding! 😄
      [attachment=0:12nekw82]<!-- ia0 -->flex_door_ft_1.6-arc always on option - Juju.skp<!-- ia0 -->[/attachment:12nekw82]
      Regarding layers: The arcs are on a separate layer called FlexDoor_Arc. You can always change it's name to what ever you want and then save the component to a folder in ComponentFinder (now officially released as part of FlexTools!).
      Hope this helps,
      Hi Yoni, thanks for this. Will you be making this part of the sets that comes with your extension by default?
      • halroachH Offline
        halroach
        Hey Juju,
        Sure, we'll do our best to add this feature in the next update, or the next after that...
        In the mean time you can add this component to any folder on your hard disk, and have quick access to it through ComponentFinder.
        If you want to change the default component that loads from the toolbar, you can replace the default door with this one. Make sure the new component has the same name => "flex_door_ft_1.skp". (Make a backup of the old one, just in case...)
        C:%ProgramData%\F3d_FlexTools\packages\components\flex_door_ft_1\component
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH Offline
          halroach
          Big news! The following new additions that we are working on will be part of the new package called FlexPack Pro!
          • WallCutter
          • Slider Window
          • Double-Hung Window
          • Awning and Hopper Windows
          • Casement Window
          • ComponentFinder improvements
          Read more on our blog: https://flextools.cc/blog/flexpack-pro/
          • halroachH Offline
            halroach
            The first update for FlexPack Pro:
            WallCutter is released, and it cuts through walls like never before! 😄 👍
            Check it out! >> https://flextools.cc/wallcutter
            • halroachH Offline
              halroach
              A quick update:
              We released a few enhancements and important bug fixes for WallCutter and the Place Upright tool.
              Read more about the changes in the Change log: https://flextools.cc/change-log
                dpaul
                Hello,
                Is it possible to use a window/door component with casings on BOTH sides and
                only the FRAME of the win/door cuts the wall (a group), leaving the trim on both sides intact?
                With my thanks.
                David
                • halroachH Offline
                  halroach
                  @dpaul said:
                  Hello,
                  With my thanks.
                  David
                  Hey David,
                  Yes it is possible... But we haven't released this feature yet. 😎.
                  It will be available in the next update of FlexTools. You will then be able to mark sub-components to be ignored by the cutting algorithm. We'll make an announcement when it's ready.
                  Yoni
                    dpaul
                    While waiting, I went ahead and purchased your plugin only to find out that you are right: it can't be done at the moment.
                    Disappointing......
                    However, what is encouraging is being able to punch in one of my windows into a wall I created with
                    Profile Builder 3 and when I shrink or expand the PB wall, I do temporarily lose my window, but once I press REFRESH it comes back. A relief.....!
                    In other words, this could be the combo I have been looking for that will fast track my building layouts: PB3 walls and Wall cutter for installing my own windows and doors.
                    Till then, though, perhaps we can clone you and your team in order to speed up what I need.......😄
                    Cheers.
                    David
                    • halroachH Offline
                      halroach
                      Disappointing......
                      Cheers.
                      David
                      If we were cloned... one of us clones would have definitely answered your question a lot faster! 😄
                      Great to hear it's working well with PB3 and with the Refresh button!
                      We have the feature you need already working in our 'development branch'. I believe you'll be able to use it pretty soon.
                        dpaul
                        Yes, Flex and PB3 should work very well for me---and I am particularly encouraged by the last comment in your thread.
                        I look forward to hearing about the update soon.....!
                        With my thanks.
                        David
                        • pbacotP Offline
                          All sounds great. Hope to try it soon!
                          • halroachH Offline
                            halroach
                            With my thanks.
                            David
                            Here it is! 😄
                            New update for WallCutter!
                            In this update we've introduced a much requested and significant enhancement for WallCutter - the ability to exclude sub-components from affecting the cutting algorithm. That means you'll now be able to have wall cutting windows (and doors) with Trim!
                            And yes, it will work with trim on both sides as asked by David here.
                            This update also includes a couple of bug fixes:
                            👊 One of the bugs found by Pixero (posted here) should now be fixed. Sketchup won't crash now when having 0 faces in a WallCutter component.
                            👊 The other bug fix addresses another similar crash that could happen if the faces in a cutting component had the thickness of 0. This could happen when a flat WallCutter component was created with the wrong axes orientation.
                            1. How to auto-update
                            2. Remember to restart Sketchup after the update!
                            Happy Flexing! 😄
                              dpaul
                              This is a crucial addition to a very powerful plugin.
                              Thanks.....!
                              • halroachH Offline
                                halroach
                                Thanks.....!
                                Great to hear! 😄
                                  somebodyelse
                                  This is great. I just have a quick question about pivot points. Say I want to create a pivot door, how does one go about creating the function of a pivot door?
                                  • halroachH Offline
                                    halroach
                                    Hi Ivan,
                                    If you mean to turn the FlexDoor into a pivot door, up till this very moment it was not possible...
                                    But it is now!!! 😄
                                    I made a few internal changes and added a setting called 'Axis - Move'.
                                    Consider this a hot-fix, not completely polished. You must turn the 'Arcs' off and set the 'Hinges' to 0 for things to look normal when changing the axis position.
                                    You'll find the updated FlexDoor in the zip attached below. Drag and drop the skp into a model for it to work.
                                    flex_door_ft_1_19-pivot_hotfix.zip
                                    • I Offline
                                      Ivan K
                                      OH MY GOODNESS!!!
                                      This is absolute perfection! screams in excitement
                                      THANK YOU!!!!
                                      • halroachH Offline
                                        halroach
                                        @ivan k said:
                                        OH MY GOODNESS!!!
                                        THANK YOU!!!!
                                        Very glad it's helpful Ivan 😄
                                        We released this new FlexDoor feature yesterday as an auto-update to the plugin. I think it will be useful for everyone.
                                        • halroachH Offline
                                          halroach
                                          Flex Slider Window/Door - Coming soon in the next update!
                                          • halroachH Offline
                                            halroach
                                            Meet the new FlexSlider window/door!
                                            Customize the sashes! Set the number of divisions, choose from 3 muntin distributions: 'equal divisions', 'prairie style', 'from side+equal spacing'.
                                            https://flextools.cc/wp-content/uploads/2018/09/flexslider-sash-settings-1024x671.png
                                            • 2 / 9
