    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 270.2k Views 43 Watching
    • yourpasswordisY
      yourpasswordis
      Thanks for what looks like a great plugin, I'm here to report it's not working for me (Sketchup pro 2017 Win, tried with sketchup 2016). After following your instructions closely the plugin hangs for close to five minutes, then removes the component's original cut opening. furthermore the plugin doesn't create the second cutting face, it only fills in the original hole. I was sure to drag a new components form the component library every time I was trying to cut, as you've pointed out to many others on this thread.
      I'd be happy to pay for support for this plugin but seeing as it's free I'll just have to hope TIG can help.
      The difference between good enough and awesome is huge
        Can you post a small SKP with a wall and cutting component window.
        Otherwise it's all guesswork.
        I suspect there's something wrong with your example window component.
        To test this please make two 3d [two faced] walls - ensuring that their front faces are looking 'outwards'.
        Now draw a smaller rectangle directly on a wall's face, give it a transparent material.
        Next select the transparent rectangle and its edges [double-click it] and make it into a component.
        In the dialog set it to glue and cut.
        Name it something like "A_Window".
        Now insert a second instance of it from the Component Browser [model tab] a,d glue it directly onto another wall.
        At this point you should have two 'windows' on the walls which let you see into the walls' insides
        Open the Ruby Console to see error-massages [if any].
        Now use the Hole Puncher on each window in turn and see what happens...
          I can replicate your issue.
          At the moment I can't see what's happening...
          I'm looking at it...
          • yourpasswordisY
            yourpasswordis
            TIG, thanks for the reply. I've tried your test (details below) and a couple different windows now; no luck. Sketchup file attached. I've seen the plugin used on tutorials/YouTube and could swear I'm doing it right.
            I made one wall by extruding a rectangle; ensuring the 'normals' faced outward. I grouped the wall then copied it in front of itself to create a common co-planar face. I tried using Hole Punch with a transparent rectangle cutting the co-planar face. The result was the removal of the cutting face (as before).
            @lbert
            Hole punch.skp
              Here's v3.0
              http://sketchucation.com/pluginstore?pln=HolePunchTool
              I have recoded it for v2017 compatibility***, and also signed it for all v2016/2017 loading-policies.
              ***The glitch was caused by a change in the way v2017 handles exploded entities - references are now lost as the edges/faces get a new ID - unlike all earlier versions !
              This has caused numerous issues across many plugins !
              [I'm still fixing EEby... tools !]
              Please test and feedback...
              • yourpasswordisY
                yourpasswordis
                Reporting back to say that 3.0 is not working, behaving same as before.
                Furthermore the extension manager lists 'hole punch' and the accompanying 'DeBazier' as unsigned.
                Ruby window shows no error, tried with a few different components.
                  The HolePunch should report as fully signed.***
                  Although deBabelizer was not re-signed for v2017 - just v2016.
                  But of course this doesn't matter anyway, if your loading-policy is unrestricted.
                  It worked just fine with your example SKP.
                  ***But now I see the glitch again - so I suspect I messed up some file swaps within the RBZ whilst re-signing it !
                  So I have made v4.0, which now includes a fully signed deBabelizer, and I have treble-checked the various files and re-signed the HolePunch too...
                  Please feed back...
                  Get v4.0 here...
                  • yourpasswordisY
                    yourpasswordis
                    Hole punch 4.0 works in SU17
                    TIG for prime minister
                    • pmolsonP
                      pmolson
                      This is my favorite time saving plug in ever!
                      Tig, I just wanted to make you aware of a behavior I have noticed in 2018 sketchup using latest holepunch download.
                      If I work on a model for a while, could be a half an hour or a half a day, placing objects that i will be punching after I get them all placed and then start punching them 1 by 1 there is a substantial delay from the time I hit "punch" to the time it actually punches. Upwards of 5 to seven seconds.
                      If I close the file and re-open it and start punching before i do anything else the punches then punch with virtually no delay.
                      If I was to to start working on the model after re-starting without punching first the delay will re-establish itself.
                      Not a big deal to me, because i normally place all my windows without punching and then punch them all when I have them in place so restarting once before I punch is not a big deal.
                      Just thought you might like to know.
                      p
                      • T
                        trombe
                        I wanted to try this script out, however checking the compatibility it only runs up to SU2017, however, pmolson, is saying he has it running on 2018, which is wonderful.
                        After downloading and copy/pasting the script into the SU 2018 plug-ins folder, then opening SU 2018 Pro and testing, I cannot see any available evidence of the plug-in on the context menu after selecting the component - yes, the window component I made is set to "cut opening".
                        Are you able to advise pmolson ?
                        thanks in advance
                        p
                          Copying and pasting the downloaded file into the Plugins folder is not the correct way to install it. In fact, it doesn't install it at all. After downloading the RBZ file, go to Window>Extension Manager and click on Install Extension. Navigate to the downloaded file and click Open, then Yes.
                            ARQUISAURIO
                            FUNCIONANDO EN SU 2017!
                              Almost certainly - with your 'Extension Loading Policy' set to be 'Unrestricted'.
                              Casi con toda seguridad - la carga de su 'política de extensión' establecida para estar 'sin restricciones'
                                DSnodgrass
                                I know that the last post to this thread was 3 years ago, but I'm wondering if this plugin still works for SU 2022?
                                I've tried it but when I punch, the component glues to the inside of the BACK face rather than the outer of the front. Initially the component does glue to the front/bottom face but after the punch it inserts back the equivalent of the thickness of the ceiling.
                                  It is somewhat old... but it should still work in newer SketchUp versions, but you do need to ensure that the cutting-component instance is glued onto the correct face and that it has its axes properly oriented.
                                  Also this tool works with cutting-components glued onto faces - not onto faces within groups or other components...
                                    It works fine on 2022.
                                    • pmolsonP
                                      pmolson
                                      I use this plug-in every day all day. Works great in the current version. I've had the issue your experiencing in the past and it's always been either my faces are reversed and I'm applying it to a backface or the components axes doesn't match the axes of the opened groupe/component that I'm inserting it into. So check those things it should work.
                                        DSnodgrass
                                        Thanks for the responses guys.
                                        So I read through all of the posts in this thread and found someone who said that they exploded out all the nested components.
                                        In my example, the recessed light (which I grabbed from 3Dwarehouse) had dozens of nested components. So I exploded all those out to groups, made the entire thing a single component, and viola, the punch works!
                                        Nearly all the tutorials on how to use this plugin assume the user is building a cutting component from scratch, as opposed to using a pre-built component that has sub-components. To use a complex component with lots of nested components I had to do this:
                                        1. explode all nested components back to just groups
                                        2. Select the parent object and make it a component
                                        3. Choose an existing surface in the newly created component that will act as the cutting plane and set the axes such that the blue is perpendicular to the component.
                                        This process worked for the recessed light but...
                                        I have doors I'd like to be able to punch walls with. These have handles, pneumatic closers, windows of various sizes, etc., all of which must remain as nested components. So I'm not sure how to convert those doors into something that will cut. Adding to the complexity, because the doors have windows cut into them, I would end up with components that have two cutting surfaces (one to punch a window into the door slab and one for the door frame to punch through the wall. Maybe not possible.
                                          3DWH is the wild west of 3D content so some level of caution should be exercised when importing models.
                                          For punching you can make a simple profile to act as the 'puncher'...
                                          ...then insert your object post-punch.
                                            DSnodgrass
                                            In my case, I was able to make the 3DW recessed light punch a hole (by fully exploding it) but I couldn't make my complex doors that I assembled (and which have a few 3DW components like the closers and the handles), punch.
                                            I think, in the door's case, the issue is not just that there are lots of nested components (primarily the handles and the closers) but also, that a door frame is not a continuous loop so you have to add an additional cutter to the component. I just haven't been able to make that work so precutting a hole is probably my only solution that I've been able to discern.
                                            I'd love to be pointed to a video where I could learn how to mod an existing complex component (that has nested sub-components) to allow it to use the HPT.
                                            Note that the image below is a door shown without the additional cutting loop. I have a few I've added a loop to and they still don't cut for some reason.
                                            • 10 / 10
