    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 261.4k Views 43 Watching
    • mariochaM
      mariocha
      After inserting doors and windows, which do cut openings, in some particular cases I would like the cut face to be copied and visible on the parent face, i.e outside the compo. Do you think part of your plugin could be used to get that ?
      %(#008000)[Mario C.
        I don't fully understand the question...
        If you UNlink the cutting instance - context-menu - then it is no longer connected to the instance anyway ?
        Please explain what you mean/want = somewhat better...
        Or perhaps ex-the-tool - how about using "intersect" between the instance and face, then "unglue" the instance ??
        • mariochaM
          mariocha
          Finally, I think your suggestion to intersect the compo with the face will be just fine. Thousand thanks ! πŸ˜„
          %(#008000)[Mario C.
            Maybe can help for some cases ?
            • mariochaM
              mariocha
              Dynamic components tend to get pretty complicated. They are mainly made of sub-components and groups.
              In order to have them cut opening, I add loose edges framing the opening I want.
              Some geometry, trimmings, extend outside the perimeter of those edges.
              And also, some geometry are hidden, depending on the user choice of options.
              So HolePunch is having a lot of problems with my complicated DCs.
              Looking at the code, I think I understand that it is adding all the faces of sub components and groups as punching elements. Too many overlapping geometry in my DCs, I think.
              Btw, your code is a huge lesson in high level SU Ruby API coding.
              So my question; Is a HolePunch variant taking only the cut-opening edges as punching elements a good idea ? If so, feasible ?
              PunchCutOpening.rb ? πŸ˜‰
              %(#008000)[Mario C.
              • mariochaM
                mariocha
                Ok, so as not to have anybody waste time over this, let it be known that I have done it. Well only proof of concept. Still a lot to do.
                It took a lot of reading of numerous post and I must thank TIG, TT, Dan, Driven, Jim, and others for their several replies to newbies questions and for their unscripted plugins from which one can learn a lot.
                Cookies to you all SU-Ruby masters. πŸ˜„
                %(#008000)[Mario C.
                  Please note that this extension has some issues with v2017 entities' IDs etc - stopping it working properly.
                  An update is in progress - please be patient...
                  • H
                    hank
                    Sounds like just what I need mariocha. Any updates? Could you post your rb?
                    • yourpasswordisY
                      yourpasswordis
                      Thanks for what looks like a great plugin, I'm here to report it's not working for me (Sketchup pro 2017 Win, tried with sketchup 2016). After following your instructions closely the plugin hangs for close to five minutes, then removes the component's original cut opening. furthermore the plugin doesn't create the second cutting face, it only fills in the original hole. I was sure to drag a new components form the component library every time I was trying to cut, as you've pointed out to many others on this thread.
                      I'd be happy to pay for support for this plugin but seeing as it's free I'll just have to hope TIG can help.
                      The difference between good enough and awesome is huge
                        Can you post a small SKP with a wall and cutting component window.
                        Otherwise it's all guesswork.
                        I suspect there's something wrong with your example window component.
                        To test this please make two 3d [two faced] walls - ensuring that their front faces are looking 'outwards'.
                        Now draw a smaller rectangle directly on a wall's face, give it a transparent material.
                        Next select the transparent rectangle and its edges [double-click it] and make it into a component.
                        In the dialog set it to glue and cut.
                        Name it something like "A_Window".
                        Now insert a second instance of it from the Component Browser [model tab] a,d glue it directly onto another wall.
                        At this point you should have two 'windows' on the walls which let you see into the walls' insides
                        Open the Ruby Console to see error-massages [if any].
                        Now use the Hole Puncher on each window in turn and see what happens...
                          I can replicate your issue.
                          At the moment I can't see what's happening...
                          I'm looking at it...
                          • yourpasswordisY
                            yourpasswordis
                            TIG, thanks for the reply. I've tried your test (details below) and a couple different windows now; no luck. Sketchup file attached. I've seen the plugin used on tutorials/YouTube and could swear I'm doing it right.
                            I made one wall by extruding a rectangle; ensuring the 'normals' faced outward. I grouped the wall then copied it in front of itself to create a common co-planar face. I tried using Hole Punch with a transparent rectangle cutting the co-planar face. The result was the removal of the cutting face (as before).
                            @lbert
                            Hole punch.skp
                              Here's v3.0
                              http://sketchucation.com/pluginstore?pln=HolePunchTool
                              I have recoded it for v2017 compatibility***, and also signed it for all v2016/2017 loading-policies.
                              ***The glitch was caused by a change in the way v2017 handles exploded entities - references are now lost as the edges/faces get a new ID - unlike all earlier versions !
                              This has caused numerous issues across many plugins !
                              [I'm still fixing EEby... tools !]
                              Please test and feedback...
                              • yourpasswordisY
                                yourpasswordis
                                Reporting back to say that 3.0 is not working, behaving same as before.
                                Furthermore the extension manager lists 'hole punch' and the accompanying 'DeBazier' as unsigned.
                                Ruby window shows no error, tried with a few different components.
                                  The HolePunch should report as fully signed.***
                                  Although deBabelizer was not re-signed for v2017 - just v2016.
                                  But of course this doesn't matter anyway, if your loading-policy is unrestricted.
                                  It worked just fine with your example SKP.
                                  ***But now I see the glitch again - so I suspect I messed up some file swaps within the RBZ whilst re-signing it !
                                  So I have made v4.0, which now includes a fully signed deBabelizer, and I have treble-checked the various files and re-signed the HolePunch too...
                                  Please feed back...
                                  Get v4.0 here...
                                  • yourpasswordisY
                                    yourpasswordis
                                    Hole punch 4.0 works in SU17
                                    TIG for prime minister
                                    • pmolsonP
                                      pmolson
                                      This is my favorite time saving plug in ever!
                                      Tig, I just wanted to make you aware of a behavior I have noticed in 2018 sketchup using latest holepunch download.
                                      If I work on a model for a while, could be a half an hour or a half a day, placing objects that i will be punching after I get them all placed and then start punching them 1 by 1 there is a substantial delay from the time I hit "punch" to the time it actually punches. Upwards of 5 to seven seconds.
                                      If I close the file and re-open it and start punching before i do anything else the punches then punch with virtually no delay.
                                      If I was to to start working on the model after re-starting without punching first the delay will re-establish itself.
                                      Not a big deal to me, because i normally place all my windows without punching and then punch them all when I have them in place so restarting once before I punch is not a big deal.
                                      Just thought you might like to know.
                                      p
                                      • T
                                        trombe
                                        I wanted to try this script out, however checking the compatibility it only runs up to SU2017, however, pmolson, is saying he has it running on 2018, which is wonderful.
                                        After downloading and copy/pasting the script into the SU 2018 plug-ins folder, then opening SU 2018 Pro and testing, I cannot see any available evidence of the plug-in on the context menu after selecting the component - yes, the window component I made is set to "cut opening".
                                        Are you able to advise pmolson ?
                                        thanks in advance
                                        p
                                          Copying and pasting the downloaded file into the Plugins folder is not the correct way to install it. In fact, it doesn't install it at all. After downloading the RBZ file, go to Window>Extension Manager and click on Install Extension. Navigate to the downloaded file and click Open, then Yes.
                                            ARQUISAURIO
                                            FUNCIONANDO EN SU 2017!
                                            • 9 / 10
